Playback device selection
bickleigh
Post Tue May 21, 2013 1:52 pm
Is it possible using any of the api functions to select which device a video or piece of music is played back on? Example: I have a web interface that is hooked into Serviio I choose a video or music file and I can decide to play back on the local device or send to another device such as a DNLA enabled tv.
I have had a quick look through the API docs and nothing springs out at me but that doesn't mean that a way doesn't exist; there may be some hack around for it.
If not are there any plans to implement this kind of feature?
Many thanks
Bick
...if it ain't broke don't fix it!
Post Tue May 21, 2013 6:36 pm
Re: Playback device selection
You are talking about DLNA controller, Serviio doesn't have this feature.
bickleigh
Post Wed May 22, 2013 8:52 pm
Ok thanks for the reply.
Is this feature on the future road map?
thanks
Bick
Post Wed May 22, 2013 9:39 pm
Nope.
Return to Plugin development
