Plugin Help
khurram23
Post Wed Jul 31, 2013 9:04 pm
Plugin Help
Hello -
I'm trying to create this plugin (based off to pre-existing plugins), mostly copy/paste and changing few things here and there to try and make it work.
The site is ebound.tv
I have managed to extract the URLs for various channels and even managed to extract the frame URL, but when i try to process the frame URL to identify RTMP stream, it kicks me back to their main page. I am not sure what's going on. The source can be viewed in chrome and if i hit the URL directly, it works (no re-direct). I have the output of the various pages hit being logged to txt files. Please see 3.txt.
Please help!
my draft of plugin is attached.
1.groovy
(6.18 KiB) Downloaded 800 times
Thanks,
Dropbox - Get 500MB bonus space.
My pre-compiled FFMPEG, X264 packages for Linux/Ubuntu - Dropbox
Post Wed Jul 31, 2013 9:54 pm
Re: Plugin Help
Maybe they check the userAgent. Try to use this method
String openURL(URL url, String userAgent)
and provide a Chrome-like user agent.
khurram23
Post Thu Aug 01, 2013 2:12 pm
Re: Plugin Help
zip -
Thanks! Getting me 1 step closer, however more issues I could use help with.
I've updated the function to include user agent and now it returns a NULL when i run the command.
final USER_AGENT = 'Mozilla/5.0 (Windows NT 5.1) AppleWebKit/535.1 (KHTML, like Gecko) Chrome/14.0.835.186 Safari/535.1'
channel_stream_url_text = openURL( new URL(current_url), USER_AGENT )
file
1.groovy
(6.62 KiB) Downloaded 774 times
Post Thu Aug 01, 2013 4:02 pm
Re: Plugin Help
Hmm.. it still returns 400 (should probably put some logging there). I'm not sure what the problem is, it works via CURL, but in the code it gives 400. They might have some additional checks, no idea.
khurram23
Post Thu Aug 01, 2013 7:35 pm
Re: Plugin Help
Thanks zip..
not sure what is going on... i'll continue to do more testing... but am stuck
.bismarck
Post Fri Aug 02, 2013 1:45 am
Re: Plugin Help
Referer is needed ;-)
Result:
so.addVariable('streamer','rtmp://streamer35.eboundservices.com/tv?wmsAuthSign=c2VydmVyX3RpbWU9OC8yLzIwMTMgMTozNzo0MCBBTSZoYXNoX3ZhbHVlPVlNRE5NVDh0b0lBNW5xSEpmNFdDV0E9PSZ2YWxpZG1pbnV0ZXM9MjA=');
.bismarck
1.groovy
(7.39 KiB) Downloaded 722 times
khurram23
Post Fri Aug 02, 2013 6:23 pm
Re: Plugin Help
.bismarck wrote:Referer is needed ;-)
.bismarck
Ha! You rock!!
Back to work... Thanks!
Return to Plugin development
