No Playable file. Server suddendly stoped working
I'm using a sony blu ray player bdp s370
JohninLA wrote:Funny you mentioned the Sony Blu Ray. I have a Sony BD570, and almost everytime I power it up, Serviio shows up, but I can't open the server. I've learned that if I unplug my wireless router for 30 seconds, plug it back in, the BluRay rediscovers Serviio, and all the files are playable. Not sure why that happens, but I have to do it daily before using the Sony.
insane822 wrote:JohninLA wrote:Funny you mentioned the Sony Blu Ray. I have a Sony BD570, and almost everytime I power it up, Serviio shows up, but I can't open the server. I've learned that if I unplug my wireless router for 30 seconds, plug it back in, the BluRay rediscovers Serviio, and all the files are playable. Not sure why that happens, but I have to do it daily before using the Sony.
I had this problem before with my S370. Once I set the player to use a static IP instead of DHCP, I never had antoher problem.
peter1212 wrote:I'm going to try both of these. How do I set my player to use a static IP, though?
