No Playable file. Server suddendly stoped working
peter1212
Post Thu Jun 14, 2012 5:20 am
I was wondering if anyone could help, up until a few days ago, Serviio was working just fine, but lately when ever I open it, as soon as the folder show up, a message pops up that says "No Playable File". As far as I remember I didn't change anything, I just turned it on one day and it didn't work.
I'm using a sony blu ray player bdp s370
Post Thu Jun 14, 2012 6:44 am
Re: No Playable file. Server suddendly stoped working
For all folders ?
peter1212
Post Sat Jun 16, 2012 11:26 pm
Every single folder
JohninLA
Post Sun Jun 17, 2012 4:42 pm
Funny you mentioned the Sony Blu Ray. I have a Sony BD570, and almost everytime I power it up, Serviio shows up, but I can't open the server. I've learned that if I unplug my wireless router for 30 seconds, plug it back in, the BluRay rediscovers Serviio, and all the files are playable. Not sure why that happens, but I have to do it daily before using the Sony.
insane822
Post Sun Jun 17, 2012 4:49 pm
JohninLA wrote:Funny you mentioned the Sony Blu Ray. I have a Sony BD570, and almost everytime I power it up, Serviio shows up, but I can't open the server. I've learned that if I unplug my wireless router for 30 seconds, plug it back in, the BluRay rediscovers Serviio, and all the files are playable. Not sure why that happens, but I have to do it daily before using the Sony.
I had this problem before with my S370. Once I set the player to use a static IP instead of DHCP, I never had antoher problem.
peter1212
Post Mon Jun 18, 2012 6:55 am
I'm going to try both of these. How do I set my player to use a static IP, though?
Post Mon Jun 18, 2012 7:21 am
peter1212 wrote:I'm going to try both of these. How do I set my player to use a static IP, though?
On Bluray menu : Home -> setiing -> Network -> manual setting :
somethink like : 192.168.1.10, 255.255.255.0, 192.168.1.1
peter1212
Post Wed Jun 20, 2012 7:13 am
Well, neither option worked :cry:
Post Wed Jun 20, 2012 7:40 am
Could you check on serviio console, what is the profile selected ?
