ffmpeg high cpu usage
karlsus
Post Mon Oct 22, 2012 12:15 pm
Re: ffmpeg high cpu usage
When I stream live video feeds (using rtmp and the Livefeeds plugin) to my Sony Bravia TV (2011) transcoding continues after I have stopped watching the video in my TV. The only way to free the CPU is to shut Serviio down. (In the Serviio.log I have started and stopped Sky News.) Is this how it should work?
Post Mon Oct 22, 2012 12:55 pm
Yes because there is no way for serviio to know you have stopped watching it.
Post Mon Oct 22, 2012 4:26 pm
In case of a live stream it should stop the FFMpeg process after 1 minute of inactivity.
karlsus
Post Tue Oct 23, 2012 9:21 pm
That's true, the FFMpeg process stops but the high CPU usage just goes on and on. The CPU usage won't go down to normal until Serviio is shut down.
spudy12
Post Wed Oct 24, 2012 10:57 am
is there anyway to set serviio to kill the transocde after someone stops watching the stream?
When more than 4 people are watching streams / switching between programs my server is completely maxed out.
If not is there anyway to add this? Mostly on web streams.
Edit: Just to add I'm talking about files stored on the server, not live streams from the pluggins
yaro
Post Sun Oct 28, 2012 9:23 pm
I am in that situation again:
(465.9 KiB) Downloaded 568 times
yaro
Post Sun Oct 28, 2012 11:13 pm
It happens when I switch from video to video. Ffmpeg does not get a chance to finish the first video before the start of the second video.
yaro
Post Fri Mar 08, 2013 1:09 am
Sorry for the trouble. I have come to the conclusion that the high cpu usage is caused by faulty plugin coding. I think you should review these plugins before they are posted.
Post Fri Mar 08, 2013 4:21 pm
yaro wrote:Sorry for the trouble. I have come to the conclusion that the high cpu usage is caused by faulty plugin coding. I think you should review these plugins before they are posted.
I don't have time for that...
grolschie
Post Sun Mar 10, 2013 7:53 pm
Have you let the author of the plugin know?
Previous
