Transcoding 720p Qnap Nas
spudy12
Post Sun Apr 28, 2013 8:02 pm
I've just bought a QNAP 869L which has a intel atom 2.13ghz dual core processor. Also has 3gb RAM in it
does anyone know / have any experience with weather this is powerful enough to transcode 720p video files for the media browser? mostly in .mkv format
Spud
slyguy42o
Post Mon Apr 29, 2013 4:06 pm
Re: Transcoding 720p Qnap Nas
only one way to find out :) give it a shot and see what it can do.
NX3
Post Tue Apr 30, 2013 6:07 pm
My dual core atom can transcode 720p real time (just!!!)
spudy12
Post Wed May 01, 2013 10:29 am
I will give it a go over the next few weeks and let you know how I get on.
Tempted to just keep a stripped out version of my server with a quadcore 3.2ghz in it and run serviio off of that using qnap as storage,
but still i'll give it a try,
On another note, anyone know how to reduce power consumption on a 24/7 server?
NX3
Post Wed May 01, 2013 11:50 am
Get a highly efficient PSU and don't over rate it 400w when you only need 100w as even on a efficient PSU you won't get a good efficient as low use.
Use power efficient components (stating the obvious really) but careful selection of cpu, mobo, hdd etc all add up.
slyguy42o
Post Wed May 01, 2013 5:00 pm
Getting a higher rated power supply wont actually affect the amount of power used. The components will draw however much they need. i.e. if you only have 100w draw then it's going to draw 100w regardless of the top end capacity of the PSU you have.
if anything a higher rated PSU running on lower specced hardware will run cooler as it's only using a small portion of it's overall rated capacity.
The key metric to look for in PSU's is their power efficiency rating. the higher the better!!
NX3
Post Wed May 01, 2013 9:30 pm
Efficient... Pretty sure that's what I was saying ;)
Sent from my HTC Desire S using Tapatalk 2
Users browsing this forum: Google [Bot] and 8 guests
