using .srt subtitle with VIDEO_TS map
vloemans
Post Sun Feb 27, 2011 12:19 pm
How / where should I save the .srt file in order to make it work for watching a streaming DVD (VIDEO_TS and AUDIO_TS) on my LG TV?
Post Sun Feb 27, 2011 1:18 pm
Re: using .srt subtitle with VIDEO_TS map
I doubt the srt file is made for the files copied from the DVD. If it is, you'd have to join the DVD files into one and then name the srt file the same as the video file.
Return to LG
