[Readme] Sony Bravia 2014
Post Sun Dec 28, 2014 3:52 pm
Re: [Readme] Sony Bravia 2014
Your stream seems weird.
Could you remux the file in same format with this tools : viewtopic.php?f=17&t=12136
Open Remux tab, select action: Remux to same container type.
Then add the resulting file to serviio library an try to play it.
Victorious
Post Sun Dec 28, 2014 9:11 pm
It didn't work. I use TV Scheduler Pro on my PC to record TV. I never had a problem playing any of these .ts files on my PC or Android or my 4 years old generic TV. But I can't play them on "smart" 2014 Sony TV nor Serviio with transcoding.
rioknight
Post Mon Dec 29, 2014 2:15 pm
Hello.
I have the same Problem wirh my Bravia32WG55A 2013, newest Software.
Over DLNA we are able to view mg4 files up to 90 minutes.
Have we longer and bigger files viewing will stop ever at 30 minutes from the beginning.
C:\Programme\serviio\lib>ffmpeg.exe -i "E:\Videos\Im_Rausch_der_Tiefe.mp4"
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'E:\Videos\Im_Rausch_der_Tiefe.mp4':
major_brand : isom
minor_version : 512
compatible_brands: isomiso2avc1mp41
title : Im Rausch der Tiefe
artist : 9709431_555887
Duration: 02:37:38.05, start: 0.000000, bitrate: 1720 kb/s
Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 720x576 [
SAR 64:45 DAR 16:9], 1482 kb/s, 25 fps, 25 tbr, 25 tbn, 50 tbc
handler_name : VideoHandler
Stream #0:1(und): Audio: aac (mp4a / 0x6134706D), 44100 Hz, stereo, fltp, 23
1 kb/s
handler_name : SoundHandler
vanel86
Post Thu Jan 08, 2015 6:49 pm
custom profile for W815
I've just bought a Bravia 55W815B and i've tried using the 2013/2014 custom profile to no avail, i've tried tinkering a bit and i've set up a working custom profile
Code is as follows
 <Profile id="sony2014" name="Sony Bravia TV (2014)" extendsProfileId="1">
        <!-- this is WIP, should be included in the inheritance tree if possible -->
        <!-- 2014 models
              Codec list supported : http://pdf.crse.com/manuals/14HM094111/EN/codeclist.html#10
              - Still images: JPEG (*.jpg / *.jpe / *.jpeg), MPO (*.mpo), RAW (*.arw)
              - Music: LPCM, MP1L1 / MP1L2 / MP1L3 / MP2L1 / MP2L2 / MP2L3 / MP2.5L3 (*.mp3), AAC-LC / HE-AAC v1/v2 (*.mp4 / *.m4a / *.3gp / *.3g2), WMA9 (*.wma)
              - Video: MPEG1 / MPEG2PS / AVCHD , MP4, Xvid, Motion JPEG, VC1, MKV, 3gpp, MOV, WebM
        <Detection>
            <UPnPSearch>
                <FriendlyName>BRAVIA (KDL-\d{2}W[56789]\d{2}[B].)|(KD-\d{2}X[89]\d{3}[B].)</FriendlyName>
            </UPnPSearch>
        </Detection>
        <DeviceDescription>
            <!-- act as WMP so that the TV doesn't show root categories -->
            <ModelName>Windows Media Player Sharing</ModelName>
            <ModelNumber>3.0</ModelNumber>
            <Manufacturer>Microsoft Corporation</Manufacturer>
        </DeviceDescription>
        <ContentDirectoryMessageBuilder>org.serviio.upnp.service.contentdirectory.SonyDLNAMessageBuilder</ContentDirectoryMessageBuilder>
        <ContentDirectoryDefinitionFilter>org.serviio.upnp.service.contentdirectory.definition.WMPContentDirectoryDefinitionFilter</ContentDirectoryDefinitionFilter>
        <MediaFormatProfiles>
            <!-- Rename native WMA formats to those supported by the tv -->
            <MediaFormatProfile mime-type="audio/x-ms-wma" name="WMABASE">WMA_BASE</MediaFormatProfile>
            <MediaFormatProfile mime-type="audio/x-ms-wma" name="WMAFULL">WMA_FULL</MediaFormatProfile>
            <!-- Rename 3gp profiles that can be played as AVC -->
            <MediaFormatProfile mime-type="video/mp4" name="AVC_MP4_MP_SD_AAC_MULT5">AVC_3GPP_BL_QCIF15_AAC</MediaFormatProfile>
            <!-- Rename native avi formats to those supported by the tv -->
            <MediaFormatProfile mime-type="video/avi" name="">AVI</MediaFormatProfile>
            <!-- Rename native mpeg2ts with h264+ac3/aac formats to those supported by the tv (aac support is not advertised by the renderer but it works) -->
            <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3,AVC_TS_HD_24_AC3,AVC_TS_HD_60_AC3,AVC_TS_HD_EU">AVC_TS_MP_HD_AC3</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3,AVC_TS_HD_24_AC3,AVC_TS_HD_60_AC3,AVC_TS_HD_EU">AVC_TS_MP_SD_AC3</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3,AVC_TS_HD_24_AC3,AVC_TS_HD_60_AC3,AVC_TS_HD_EU">AVC_TS_MP_HD_AAC_MULT5</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3,AVC_TS_HD_24_AC3,AVC_TS_HD_60_AC3,AVC_TS_HD_EU">AVC_TS_MP_SD_AAC_MULT5</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3_T,AVC_TS_HD_24_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_HD_AC3_T</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3_T,AVC_TS_HD_24_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_SD_AC3_T</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3_T,AVC_TS_HD_24_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_HP_HD_MPEG1_L2_T</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3_T,AVC_TS_HD_24_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_HP_SD_MPEG1_L2_T</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3_T,AVC_TS_HD_24_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_HD_AAC_MULT5_T</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3_T,AVC_TS_HD_24_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_SD_AAC_MULT5_T</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3_T,AVC_TS_HD_24_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_SD_MPEG1_L3</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3_T,AVC_TS_HD_24_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_SD_MPEG1_L3_T</MediaFormatProfile>
            <!-- Rename transcoded mpeg2ts with h264 to one of the TV's supported profiles -->
            <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_HD_AC3_ISO</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_SD_AC3_ISO</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_HP_HD_MPEG1_L2_ISO</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_HP_SD_MPEG1_L2_ISO</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_HD_AAC_MULT5_ISO</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_SD_AAC_MULT5_ISO</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_SD_MPEG1_L3_ISO</MediaFormatProfile>
        </MediaFormatProfiles>
        <H264LevelCheck>FILE_ATTRIBUTES</H264LevelCheck>
            <!-- Transcode all h264 video with HIGH/MAIN > Level 4.0 on MPEG-TS stream with MPEG2VIDEO and ac3 audio transcoding -->
            <!-- expected profile MPEG_TS_SD_EU/MPEG_TS_SD_NA/MPEG_TS_SD_KO -->
            <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" DAR="16:9" forceInheritance="true">
                <Matches container="*" vCodec="h264" profile="high_10" />
                <Matches container="*" vCodec="h264" profile="high_444" />
                <Matches container="*" vCodec="h264" profile="high_422" />
                <Matches container="*" vCodec="h264" profile="high" levelGreaterThan="4.0" />
                <Matches container="*" vCodec="h264" profile="main" levelGreaterThan="4.0" />
            <!-- Remux containers with h264 video + AC3 audio to MPEG-TS stream without transcoding -->
            <!-- Remux matroska/mpeg2video + AC3 audio to MPEG-TS stream without transcoding -->
            <Video targetContainer="mpegts" forceInheritance="true">
                <Matches container="avi" vCodec="h264" aCodec="ac3" />
                <Matches container="flv" vCodec="h264" aCodec="ac3" />
                <Matches container="wtv" vCodec="h264" aCodec="ac3" />
                <Matches container="matroska" vCodec="mpeg2video" aCodec="ac3" />
            <!-- Remux all other h264 video to MPEG-TS stream with ac3 audio transcoding -->
            <!-- Remux all other matroska/mpeg2video to MPEG-TS stream with ac3 audio transcoding -->
            <Video targetContainer="mpegts" targetACodec="ac3" forceInheritance="true">
                <Matches container="mpegts" vCodec="h264" aCodec="mp3" />
                <Matches container="*" vCodec="h264" aCodec="truehd" />
                <Matches container="*" vCodec="h264" aCodec="flac" />
                <Matches container="wtv" vCodec="h264" />
            <!-- All Others video/audio codec will be transcoded into mpeg2ts, mpeg2video and ac3 audio -->
                <Matches container="mpegts" vCodec="vc1" />
                <Matches container="flv" />
                <!-- example: flv/vp6/mp3 -->
                <Matches container="wtv" />
                <Matches container="ogg" />
                <Matches container="rm" />
                <!--Matches container="3gp" vCodec="mpeg4" /-->
                <!--Matches container="3gp" vCodec="h263" /-->
                <!-- digital camera video formats -->
                <Matches container="asf" vCodec="vc1" aCodec="wmapro" />
                <Matches container="mp4" vCodec="dvvideo" />
            <Audio targetContainer="lpcm" forceInheritance="true">
                <Matches container="rtp" />
                <Matches container="rtsp" />
                <Matches container="flac" />
                <Matches container="adts" />
            </Audio>
        <HardSubsTranscoding>
            <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" DAR="16:9" />
        </HardSubsTranscoding>
The sole modification i've done is to forcefully trim h264 on level 4.0 upwards rather than on level 4.2 as in the official profile in the first post.
Gwenouille
Post Sat May 16, 2015 12:53 pm
Hi there,
I just updated to Serviio 1.5.2 from 1.4.*, and it seems that my profiles are gone.
I had to make a few changes so that my KDL 32W705B could get nice transcoded signals, and everything is now through the window…
I have found that thread, in which i exposed my problems earlier (page 1), in the hope that i could find the solution…
Surely enough the 2013/2014 profile doesn't work…
Does someone know a profile that really works with the KDL 32W705B ?
EDIT: the 2012 US profile works but isn't it an overkill ?
sdss
Post Mon Aug 22, 2016 6:55 pm
the Sony 2013/2014 profile isn't working for me (not playing xvid)
i was keen to try vanel86's Sony 2014 profile but every time i edit the profiles.xml file there's a problem, does anyone have a copy of the profiles.xml file with the above code in it already?
Previous
