SRT over DLNA Not working with Java update
elementxstyle
Post Mon May 18, 2015 1:45 am
The issue is pretty simple. As soon as I installed a java update - subtitles no longer work. I've tried on my Android phone using VLC + Airwire, and my Samsung UN55ES6100. It has always worked up to now and nothing has changed. Movie file and SRT file are the same. The only thing that has changed in this is that I upgraded to the latest version.
Can anyone else confirm the same results or if anyone has found a fix?
Post Wed May 20, 2015 8:34 am
Re: SRT over DLNA Not working with Java update
Make sure you're using the right profile.
elementxstyle
Post Sat May 23, 2015 11:34 am
The profile is correct for Samsung TV it is set as Samsung E/F Series TV Player. For my Xperia Z3 I use PlayStation 3 profile.
But now it seems my library files aren't even showing up anymore. I have Videos (Display Category) Folders (Display Category) on - like usual. Only now, none of the files are showing - just the folders they are in.
