Strange Audio Async Problem
TRMxDEVIL
Post Sat Aug 01, 2015 9:41 pm
Hey Guys,
i´ve got a strange problem with my Bravia KDL-32EX500.
I´ve upgraded my server on which serviio runs from Windows Server 2008 to Windows Server 2012 and reinstalled serviio, all fine.
Because my media files are on an other partition threy´re untouched.
My TV used to stream all files from the server correct.
But now after the upgrade all files are AV-Asnyc.
Same files on an other device (KDL-55W955) are fine.
I´ve tried "downmix to stereo" and all suitable sony profiles and "generic DLNA" without success.
I hope somebody can help me.
Post Mon Aug 03, 2015 6:36 pm
Re: Strange Audio Async Problem
No problem with my 42EX500.
Check on serviio console that proper Sony 2010 profile was selected.
TRMxDEVIL
Post Mon Aug 03, 2015 8:16 pm
I doubled checked that option.
I attach the current profile and delivery config.
I also tried to disable transcoding as result no mkv file could be played, as expected.
Could it be a FFmpeg "problem"?
Post Tue Aug 04, 2015 6:12 am
TRMxDEVIL wrote:Could it be a FFmpeg "problem"?
Yes, do you change the ffmpeg.exe binary (./serviio/lib)?
TRMxDEVIL
Post Tue Aug 04, 2015 10:44 am
No I didn´t touched any file of "C:\Program Files\Serviio"
The ffmpeg.exe as well as all other files is from - 21 May 2015 - 09:54
Thats not the date I installed serviio, that must be the date on which the serviio setup has been compiled.
Users browsing this forum: Google [Bot] and 12 guests
