LE40C630 settings profiles.xml
fragglerock
Post Tue Mar 01, 2011 8:28 am
Hi All,
First congratulations for this great software. I tried dit with my Samsung (LE40C630) using trial movies and most of them seem to work correctly. Other are causing troubles but they are very specific.
I have red a big part of the forum and couldn’t find answers to these questions or informations are too complicated for my small brain.
1 - The first one is the setup of profiles.xml. The MediaFormatProfiles part of the file includes generic DLNA specifications for « standard » device. This can be completed with more settings for specific device (number 7 for me with my C series Samsung). So i did that using Intel Upnp tool.
The result is here under. Sould i add these lines to profiles.xml for C series Samsung and especialy last lines with « * » that are in the getprotocolinfo ?
<MediaFormatProfile mime-type="audio/L16;rate=44100;channels=1">LPCM</MediaFormatProfile>
<MediaFormatProfile mime-type="audio/L16;rate=44100;channels=2">LPCM</MediaFormatProfile>
<MediaFormatProfile mime-type="audio/L16;rate=48000;channels=1">LPCM</MediaFormatProfile>
<MediaFormatProfile mime-type="audio/L16;rate=48000;channels=2">LPCM</MediaFormatProfile>
<MediaFormatProfile mime-type="audio/mpeg">MP3</MediaFormatProfile>
<MediaFormatProfile mime-type="image/jpeg">JPEG_SM</MediaFormatProfile>
<MediaFormatProfile mime-type="image/jpeg">JPEG_MED</MediaFormatProfile>
<MediaFormatProfile mime-type="image/jpeg">JPEG_LRG</MediaFormatProfile>
<MediaFormatProfile mime-type="image/jpeg">JPEG_TN</MediaFormatProfile>
<MediaFormatProfile mime-type="image/jpeg">JPEG_SM_ICO</MediaFormatProfile>
<MediaFormatProfile mime-type="image/jpeg">JPEG_LRG_ICO</MediaFormatProfile>
<MediaFormatProfile mime-type="audio/mpeg">MP3X</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">MPEG1</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">MPEG_PS_NTSC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">MPEG_PS_NTSC_XAC3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">MPEG_PS_PAL</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">MPEG_PS_PAL_XAC3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_SD_NA</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_SD_NA_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">MPEG_TS_SD_NA_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_HD_NA</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_HD_NA_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">MPEG_TS_HD_NA_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_SD_EU</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_SD_EU_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">MPEG_TS_SD_EU_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_SD_KO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_SD_KO_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">MPEG_TS_SD_KO_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_HD_KO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_HD_KO_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">MPEG_TS_HD_KO_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_HD_KO_XAC3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_HD_KO_XAC3_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">MPEG_TS_HD_KO_XAC3_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_HD_NA_XAC3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_HD_NA_XAC3_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">MPEG_TS_HD_NA_XAC3_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_SD_KO_XAC3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_SD_KO_XAC3_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">MPEG_TS_SD_KO_XAC3_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_SD_NA_XAC3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_SD_NA_XAC3_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">MPEG_TS_SD_NA_XAC3_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_MP_LL_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_MP_LL_AAC_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">MPEG_TS_MP_LL_AAC_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">MPEG_ES_PAL</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">MPEG_ES_NTSC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">MPEG_ES_PAL_XAC3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">MPEG_ES_NTSC_XAC3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">MPEG4_P2_MP4_SP_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">MPEG4_P2_MP4_SP_AAC_LTP</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">MPEG4_P2_MP4_SP_L2_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">MPEG4_P2_MP4_SP_L2_AMR</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">MPEG4_P2_MP4_ASP_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">MPEG4_P2_MP4_ASP_L5_SO_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">MPEG4_P2_MP4_ASP_L4_SO_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/3gpp">MPEG4_P2_3GPP_SP_L0B_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">MPEG4_P2_3GPP_SP_L0B_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_SD_AAC_MULT5</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_SD_AAC_MULT5_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_SD_AAC_MULT5_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_SD_MPEG1_L3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_SD_MPEG1_L3_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_SD_MPEG1_L3_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_SD_AC3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_SD_AC3_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_SD_AC3_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_SD_AAC_LTP</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_SD_AAC_LTP_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_SD_AAC_LTP_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_SD_AAC_LTP_MULT5</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_SD_AAC_LTP_MULT5_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_SD_AAC_LTP_MULT5_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_SD_AAC_LTP_MULT7</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_SD_AAC_LTP_MULT7_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_SD_AAC_LTP_MULT7_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_SD_AAC_MULT5</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_SD_AC3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_SD_AAC_LTP</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_SD_AAC_LTP_MULT5</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_SD_AAC_LTP_MULT7</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">AVC_MP4_BL_L3L_SD_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">AVC_MP4_BL_L3_SD_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_BL_CIF30_AAC_MULT5</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_BL_CIF30_AAC_MULT5_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">AVC_TS_BL_CIF30_AAC_MULT5_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_BL_CIF30_MPEG1_L3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_BL_CIF30_MPEG1_L3_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">AVC_TS_BL_CIF30_MPEG1_L3_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_BL_CIF30_AC3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_BL_CIF30_AC3_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">AVC_TS_BL_CIF30_AC3_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_BL_CIF30_AAC_LTP</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_BL_CIF30_AAC_LTP_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">AVC_TS_BL_CIF30_AAC_LTP_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_BL_CIF30_AAC_LTP_MULT5</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_BL_CIF30_AAC_LTP_MULT5_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">AVC_TS_BL_CIF30_AAC_LTP_MULT5_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_BL_CIF30_AAC_940</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_BL_CIF30_AAC_940_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">AVC_TS_BL_CIF30_AAC_940_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">AVC_MP4_BL_CIF30_AAC_MULT5</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">AVC_MP4_BL_CIF30_MPEG1_L3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">AVC_MP4_BL_CIF30_AC3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">AVC_MP4_BL_CIF30_AAC_LTP</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">AVC_MP4_BL_CIF30_AAC_LTP_MULT5</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">AVC_MP4_BL_L2_CIF30_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">AVC_MP4_BL_CIF30_BSAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">AVC_MP4_BL_CIF30_BSAC_MULT5</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">AVC_MP4_BL_CIF30_AAC_912</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_AAC_MULT5</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_AAC_MULT5_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_HD_AAC_MULT5_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_MPEG1_L3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_MPEG1_L3_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_HD_MPEG1_L3_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_AC3</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_AC3_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_HD_AC3_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_AAC_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_HD_AAC_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_AAC_LTP</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_AAC_LTP_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_HD_AAC_LTP_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_AAC_LTP_MULT5</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_AAC_LTP_MULT5_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_HD_AAC_LTP_MULT5_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_AAC_LTP_MULT7</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_AAC_LTP_MULT7_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_HD_AAC_LTP_MULT7_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_BL_CIF15_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_BL_CIF15_AAC_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">AVC_TS_BL_CIF15_AAC_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_BL_CIF15_AAC_540</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_BL_CIF15_AAC_540_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">AVC_TS_BL_CIF15_AAC_540_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_BL_CIF15_AAC_LTP</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_BL_CIF15_AAC_LTP_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">AVC_TS_BL_CIF15_AAC_LTP_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_BL_CIF15_BSAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_BL_CIF15_BSAC_T</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">AVC_TS_BL_CIF15_BSAC_ISO</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">AVC_MP4_BL_CIF15_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">AVC_MP4_BL_CIF15_AAC_520</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">AVC_MP4_BL_CIF15_AAC_LTP</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">AVC_MP4_BL_CIF15_AAC_LTP_520</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">AVC_MP4_BL_CIF15_BSAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/3gpp">AVC_3GPP_BL_QCIF15_AAC</MediaFormatProfile>
<MediaFormatProfile mime-type="video/3gpp">AVC_3GPP_BL_QCIF15_AAC_LTP</MediaFormatProfile>
<MediaFormatProfile mime-type="video/x-ms-wmv">WMVMED_BASE</MediaFormatProfile>
<MediaFormatProfile mime-type="video/x-ms-wmv">WMVMED_FULL</MediaFormatProfile>
<MediaFormatProfile mime-type="video/x-ms-wmv">WMVHIGH_FULL</MediaFormatProfile>
<MediaFormatProfile mime-type="video/x-ms-wmv">WMVSPLL_BASE</MediaFormatProfile>
<MediaFormatProfile mime-type="video/x-ms-wmv">WMVSPML_BASE</MediaFormatProfile>
<MediaFormatProfile mime-type="video/x-ms-wmv">WMVSPML_MP3</MediaFormatProfile>
<MediaFormatProfile mime-type="image/jpeg">*</MediaFormatProfile>
<MediaFormatProfile mime-type="audio/mpeg">*</MediaFormatProfile>
<MediaFormatProfile mime-type="video/x-msvideo">*</MediaFormatProfile>
<MediaFormatProfile mime-type="video/x-ms-asf">*</MediaFormatProfile>
<MediaFormatProfile mime-type="video/x-divx">*</MediaFormatProfile>
<MediaFormatProfile mime-type="video/x-ms-wmv">*</MediaFormatProfile>
<MediaFormatProfile mime-type="video/x-mkv">*</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mp4">*</MediaFormatProfile>
<MediaFormatProfile mime-type="video/x-avi">*</MediaFormatProfile>
<MediaFormatProfile mime-type="video/avi">*</MediaFormatProfile>
<MediaFormatProfile mime-type="video/x-flv">*</MediaFormatProfile>
<MediaFormatProfile mime-type="video/mpeg">*</MediaFormatProfile>
<MediaFormatProfile mime-type="video/3gpp">*</MediaFormatProfile>
2 - In the device profile i understood that all remuxing or transcoding cases should be listed (combination of video/audio codec).
Maybe a more simple way could have been to setup all audio/video codec that the device can handle ? And so to remux or transcode all other combinations ?
For example here's compatibility of my TV.
3 – i use a library with a very small amount of trial files. Nowhere i could find a way to view list of files included in the library.
Maybe i have missed something ?
Thank’s for answer.
Post Tue Mar 01, 2011 9:40 am
Re: LE40C630 settings profiles.xml
You can just use Samsung C series profile that is included in Serviio and you'll be set for most of the files. If you still have some that don't play read this: viewtopic.php?f=5&t=1123
To view the library you can use Intel's AV Media Controller (link in my signature)
