LN32C550 Subtitles size
patanpatan
Post Fri Mar 04, 2011 2:04 am
Hi there, great dlna server :-)
I have a Samsung C550, and serviio is way better than Samsung PC Manager, except for one detail. With PC Manager I'm able to change subtitles size using the remote. I really don't need to be able to change it, if it could be greater it's ok.
Is there a way to set font size? or will be in future releases?
Thanks in advance
Post Fri Mar 04, 2011 11:03 am
Re: LN32C550 Subtitles size
Yeah, I was trying to get the subtitle menu working, but cannot find a way. If I do in the future then it'll obviously be added.
patanpatan
Post Thu Mar 17, 2011 11:00 pm
Hey, I think I've found a workaround for this.
I started using Samsung PC Manager because of the font size issue, and set the font size in big. Later, I've used serviio, and the font size remains big, so there's some memory on my TV side or something like this.
I don't know if I'm right, if someone can give it a try let me know
