Unseen folder
woodrook
Post Tue Sep 22, 2015 10:02 am
Unseen folder
Hi everybody, i didn't find a solution using "serach" button so i write my question down.
I have a Serviio 4.1.2 installation on my Zyxel NAS (NSA325v2)...everything works good till two weeks ago.
After a simple reboot of the NAS serviio doesn't see a folder anymore. Before the reboot i had "films" "cartoons" and "TV series" folder......now i have just "films" and "cartoons"
The folder "TV series" does exist on the NAS but serviio has lost it.....i don't know why.
If i try to create a brand new folder Serviio doesn't see it.....
Nothing changed....just a reboot, and from the console everything seems to be OK
What can I do?
Thanks a lot
Post Wed Sep 23, 2015 10:35 pm
Re: Unseen folder
Check the permissions on the "TV Series" folder and compare to the others.
Ps if you add a file to the other folder (eg Films) is it added.
woodrook
Post Tue Oct 13, 2015 8:06 am
Re: Unseen folder
Hi, thanks for your reply. My spare time is not so much and i just tryied your suggestion.
The Permissions are right and nothing changend since first (working good) installation.
If I add a new folder under film or music serviio doesn't see the new folder. I don't know why......2 months ago it was working good.....this problem happened without any reason!
Gianluca
Users browsing this forum: Google [Bot] and 18 guests
