HELPPPPPP!!!!!!! Cannot connect to Serviio server
Alfaserviio
Post Sat Oct 24, 2015 10:17 am
"Cannot connect to Serviio server, it does not seem to be running: Exiting…"
I've Mac Os X 10.10.4
HELPPPPPP!!!!!!!
Miss Nobody
Post Sun Nov 01, 2015 3:00 pm
Re: HELPPPPPP!!!!!!! Cannot connect to Serviio server
Same here, was really impressed with Serviio having hopped across from UMS. 2 days into the trial I am now getting "Cannot connect to Serviio, it does not seem to be running. Exiting..."
I am running Win10.
Any help I would be really greatful, I was so happy with this until it stopped wotking :(
Post Sun Nov 01, 2015 8:47 pm
I assume you are receiving this error when attempting to start the console. The Serviio service must be running before the console is started.
I can't offer any suggestions for the Mac, all I can suggest is posting the log here to see if there's any issues.
With Windows you can check if the process is running by right-clicking anywhere on the taskbar and select "Task Manager". In Windows 10, Task Manager starts in a minimized version that doesn't show much. Click "More Details" to open the advanced view, select the Services tab, and scroll down to Serviio and verify it's running. If not, you can right-click and select "Start". If it won't stay running, there's something wrong. Find the log (usually in c:\program files\Serviio\log) and post the log here.
Alfaserviio
Post Fri Nov 06, 2015 8:32 pm
HELP......
2015-11-04 20:05:09,594 WARN [LibraryOneTimeScanner] Cannot search for updated metadata for title Shrimp Boats. Message: Cannot read MetadataDescriptor for MediaItem id = 41421 and extractor EMBEDDED
org.serviio.db.dao.PersistenceException: Cannot read MetadataDescriptor for MediaItem id = 41421 and extractor EMBEDDED
at org.serviio.library.dao.MetadataDescriptorDAOImpl.retrieveMetadataDescriptorForMedia(MetadataDescriptorDAOImpl.java:155)
at org.serviio.library.local.service.MediaService.getMetadataDescriptorForMediaItem(MediaService.java:93)
at org.serviio.library.local.indexing.LibraryOneTimeScanner.searchForRemovedAndUpdatedFiles(LibraryOneTimeScanner.java:248)
at org.serviio.library.local.indexing.LibraryOneTimeScanner.searchForUpdatesAndRemovals(LibraryOneTimeScanner.java:133)
at org.serviio.library.local.indexing.LibraryOneTimeScanner.scanLibrary(LibraryOneTimeScanner.java:82)
at org.serviio.library.local.indexing.LocalLibraryManager.performManualScan(LocalLibraryManager.java:186)
at org.serviio.library.local.indexing.LocalLibraryManager.startLibraryScanning(LocalLibraryManager.java:117)
at org.serviio.MediaServer.main(MediaServer.java:162)
Caused by: java.sql.SQLException: The conglomerate (1.696) requested does not exist.
at org.apache.derby.impl.jdbc.EmbedPreparedStatement.<init>(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedPreparedStatement42.<init>(Unknown Source)
at org.apache.derby.jdbc.Driver42.newEmbedPreparedStatement(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection.prepareStatement(Unknown Source)
at org.serviio.library.dao.MetadataDescriptorDAOImpl.retrieveMetadataDescriptorForMedia(MetadataDescriptorDAOImpl.java:149)
... 7 more
Caused by: ERROR XSAI2: The conglomerate (1.696) requested does not exist.
at org.apache.derby.impl.store.access.heap.HeapConglomerateFactory.readConglomerate(Unknown Source)
at org.apache.derby.impl.store.access.CacheableConglomerate.setIdentity(Unknown Source)
at org.apache.derby.impl.services.cache.ConcurrentCache.find(Unknown Source)
at org.apache.derby.impl.store.access.RAMAccessManager.conglomCacheFind(Unknown Source)
at org.apache.derby.impl.store.access.RAMTransaction.findConglomerate(Unknown Source)
at org.apache.derby.impl.store.access.RAMTransaction.findExistingConglomerate(Unknown Source)
at org.apache.derby.impl.store.access.RAMTransaction.openStoreCost(Unknown Source)
at org.apache.derby.impl.sql.compile.CompilerContextImpl.getStoreCostController(Unknown Source)
at org.apache.derby.impl.sql.compile.FromBaseTable.getStoreCostController(Unknown Source)
at org.apache.derby.impl.sql.compile.FromBaseTable.getBaseCostController(Unknown Source)
at org.apache.derby.impl.sql.compile.FromBaseTable.baseRowCount(Unknown Source)
at org.apache.derby.impl.sql.compile.FromBaseTable.estimateCost(Unknown Source)
at org.apache.derby.impl.sql.compile.OptimizerImpl.estimateTotalCost(Unknown Source)
at org.apache.derby.impl.sql.compile.OptimizerImpl.costBasedCostOptimizable(Unknown Source)
at org.apache.derby.impl.sql.compile.OptimizerImpl.costOptimizable(Unknown Source)
at org.apache.derby.impl.sql.compile.FromBaseTable.optimizeIt(Unknown Source)
at org.apache.derby.impl.sql.compile.ProjectRestrictNode.optimizeIt(Unknown Source)
at org.apache.derby.impl.sql.compile.OptimizerImpl.costPermutation(Unknown Source)
at org.apache.derby.impl.sql.compile.SelectNode.optimize(Unknown Source)
at org.apache.derby.impl.sql.compile.DMLStatementNode.optimizeStatement(Unknown Source)
at org.apache.derby.impl.sql.compile.CursorNode.optimizeStatement(Unknown Source)
at org.apache.derby.impl.sql.GenericStatement.prepMinion(Unknown Source)
at org.apache.derby.impl.sql.GenericStatement.prepare(Unknown Source)
at org.apache.derby.impl.sql.conn.GenericLanguageConnectionContext.prepareInternalStatement(Unknown Source)
... 13 more
2015-11-04 20:05:09,597 WARN [LibraryOneTimeScanner] Cannot search for updated metadata for title BIG MAMOU. Message: Cannot read MetadataDescriptor for MediaItem id = 41422 and extractor EMBEDDED
org.serviio.db.dao.PersistenceException: Cannot read MetadataDescriptor for MediaItem id = 41422 and extractor EMBEDDED
... 7 more
... 13 more
2015-11-04 20:05:09,600 WARN [LibraryOneTimeScanner] Cannot search for updated metadata for title Lost In Loveliness. Message: Cannot read MetadataDescriptor for MediaItem id = 41423 and extractor EMBEDDED
org.serviio.db.dao.PersistenceException: Cannot read MetadataDescriptor for MediaItem id = 41423 and extractor EMBEDDED
... 7 more
... 13 more
2015-11-04 20:05:09,603 WARN [LibraryOneTimeScanner] Cannot search for updated metadata for title More! More! More. Message: Cannot read MetadataDescriptor for MediaItem id = 41424 and extractor EMBEDDED
org.serviio.db.dao.PersistenceException: Cannot read MetadataDescriptor for MediaItem id = 41424 and extractor EMBEDDED
... 7 more
... 13 more
2015-11-04 20:05:09,606 WARN [LibraryOneTimeScanner] Cannot search for updated metadata for title Thanks a Lot, But No Thanks. Message: Cannot read MetadataDescriptor for MediaItem id = 41425 and extractor EMBEDDED
org.serviio.db.dao.PersistenceException: Cannot read MetadataDescriptor for MediaItem id = 41425 and extractor EMBEDDED
... 7 more
... 13 more
2015-11-04 20:05:09,609 WARN [LibraryOneTimeScanner] Cannot search for updated metadata for title Close Your Eyes. Message: Cannot read MetadataDescriptor for MediaItem id = 41426 and extractor EMBEDDED
org.serviio.db.dao.PersistenceException: Cannot read MetadataDescriptor for MediaItem id = 41426 and extractor EMBEDDED
... 7 more
... 13 more
2015-11-04 20:05:09,612 WARN [LibraryOneTimeScanner] Cannot search for updated metadata for title Close Your Eyes (Version From Duet Album with Andre Previn). Message: Cannot read MetadataDescriptor for MediaItem id = 41427 and extractor EMBEDDED
org.serviio.db.dao.PersistenceException: Cannot read MetadataDescriptor for MediaItem id = 41427 and extractor EMBEDDED
... 7 more
... 13 more
2015-11-04 20:05:09,615 WARN [LibraryOneTimeScanner] Cannot search for updated metadata for title Control Yourself. Message: Cannot read MetadataDescriptor for MediaItem id = 41428 and extractor EMBEDDED
org.serviio.db.dao.PersistenceException: Cannot read MetadataDescriptor for MediaItem id = 41428 and extractor EMBEDDED
... 7 more
... 13 more
2015-11-04 20:05:09,618 WARN [LibraryOneTimeScanner] Cannot search for updated metadata for title Daydreaming. Message: Cannot read MetadataDescriptor for MediaItem id = 41429 and extractor EMBEDDED
org.serviio.db.dao.PersistenceException: Cannot read MetadataDescriptor for MediaItem id = 41429 and extractor EMBEDDED
... 7 more
... 13 more
2015-11-04 20:05:09,621 WARN [LibraryOneTimeScanner] Cannot search for updated metadata for title Falling In Love Again. Message: Cannot read MetadataDescriptor for MediaItem id = 41430 and extractor EMBEDDED
org.serviio.db.dao.PersistenceException: Cannot read MetadataDescriptor for MediaItem id = 41430 and extractor EMBEDDED
... 7 more
... 13 more
Post Sun Nov 08, 2015 2:46 am
OK, all I see in there is errors retrieving metadata for titles. Based on what is shown for your title names, that might explain what the metadata retrieval is failing. Movie titles should have the year at the end of the name like this "Animal House (1978).mpg".
This portion of the log doesn't show Serviio starting, so we can't tell what's going on at the beginning. However, since there are continuing entries it appears to be running.
You might close Serviio completely, delete the log, then restart Serviio. Let it run for a couple of minutes, then shut Serviio down again. Give us that complete log.
Users browsing this forum: Google [Bot] and 26 guests
