Samsung LN46C630 OSX MKV and Serviio...
Bboy486
Post Tue Mar 15, 2011 4:01 am
First let me say that I have enabled the detailed logs in the xml file. Also as mentioned in my subject I am using a Samsung HDTV, Serviio 5.1 (Just upgraded from 4.2), OS X 10.5.8.
I recently updated Serviio and had a hell of a time getting the Samsung to see the program. I ended up deleting Rendering Profile and Reseting the Console. This gave me a green light and updated IP for my TV and After I bound my OS X IP and saved the changes, I then had to completely close both the Program and Console. Once I opened up the Serviio program my TV finally saw the Server (I also restarted the router just in case). I am not sure which solution worked, but my TV see serviio once again.
Now I have a few other issues going on...
1. I cannot play mkv's that are either 1080p or have DTS Audio. I have tried to use Handbrake to convert to mp4 (amd lose my 5.1 in the process) and create a lower resolution MKV (Apple TV 2) but the files do not play. I am curious if anyone know what settings I need to convert the files to get it to work on my TV? I want to keep my 5.1 audi as much as possible.
2. I am trying to follow the HOW TO to open up FFMPEG and run the -i command (HOWTO: Provide details of a video file that doesn't play). When I double click the ffmpeg in the serviio-console folder (it was not in the serviio folder, which is confusing trying to following the guides on this board), it just runs a command and does not allow me to insert the code to post on this board (detailed logs). I would like ot know what I am not doing correctly, and please note I am not a command line person so I do not have much experience. Also why are the files in the how to guides found in the console and not the serviio folder?
3. I have waited 2 hours after forcing the server to rescan my content. I have about 600 GB of content on a NAS. How long should I need to wait for all my files to index? When I bring up the contents of the drives I am trying to get back on my TV, they still are not there.
4. I should also note that I use my HTC EVO to "Beam" my DLNA content from my NAS to my TV. It does the same thing as the Media.P button, but I like using my phone better.
5. Since Serviio is transcoding files on the fly can it be set-up to stream content over 3g on an HTC EVO? I use Stream2Me on my iPod Touch, but because Android 2.2 doesnt support HTTP Streaming like iOS the developer cannot port the program. Has anyone got this to work? If so please post your set-up and results. I have been looking for this feature for a long time.
6. On my OS X Server I also have TWONKY running. I actually do not use this for anything other than my TV picks the server up without any issue (and Serviio has caused me problems). Serviio is much better but i noticed that if the Twonky GUI is not updated to see all of the files on my NAS neither is Serviio. I fail to see why one would be dependant on the other, but when I close the Twonky page, serviio has issues showing all of my files and folders.
Update.... I waited to post this to see if the log would generate in the serviio if i waited and it did. I cut it off of a long line of files that were added (so at least I know where to look to see the status of the server). A few files had header issues. I don't know what this meant.
According to the log it is saying my Samsung TV ip is 192.168.1.4 but in the console is says it is 192.168.1.7... I am not following why this is inconsistant.
2011-03-13 20:44:08,006 INFO [RendererManager] Stored a new renderer: uuid='48ef1df4-b435-6255-220b-05bb1f07e5e4', name = 'Samsung DTV DMR', ipAddress='192.168.1.4', profile = '7'
I also see that the server is constantly starting and stopping looking for new content. I do not see anything that is causing the search to fail.
Below is my log:
2011-03-13 20:43:46,377 INFO [MediaServer] ------------------------------------------------------------------------
2011-03-13 20:43:46,379 INFO [MediaServer] Serviio DLNA media streaming server v 0.5.1 (rev. 0c488c4fc651)
2011-03-13 20:43:46,379 INFO [MediaServer] Petr Nejedly 2009-2011
2011-03-13 20:43:46,379 INFO [MediaServer] http://www.serviio.org
2011-03-13 20:43:46,379 INFO [MediaServer] Java 1.6.0_22-Apple Inc.
2011-03-13 20:43:46,379 INFO [MediaServer] OS Mac OS X x86_64 10.6.6
2011-03-13 20:43:46,380 INFO [MediaServer] File encoding: UTF-8
2011-03-13 20:43:46,380 INFO [MediaServer] ------------------------------------------------------------------------
2011-03-13 20:43:47,018 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2011-03-13 20:43:47,248 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-03-13 20:43:53,777 INFO [DBSchemaUpdateExecutor] Updating DB schema
2011-03-13 20:44:01,287 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-03-13 20:44:02,481 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-03-13 20:44:02,898 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-03-13 20:44:03,160 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-03-13 20:44:03,314 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-03-13 20:44:03,494 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-03-13 20:44:03,658 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-03-13 20:44:03,929 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C-series)' (id=7)
2011-03-13 20:44:04,023 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-03-13 20:44:04,603 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-03-13 20:44:05,659 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-03-13 20:44:05,894 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-03-13 20:44:06,106 INFO [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-03-13 20:44:06,492 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-03-13 20:44:06,631 INFO [WebServer] Socket buffer set to 65535 bytes
2011-03-13 20:44:06,811 INFO [WebServer] WebServer starting on port 8895
2011-03-13 20:44:06,865 INFO [Device] Created UPnP Device with UUID: 513a8a93-a8c3-3fcc-9ac9-a10c60a0cd84, bound address: 192.168.76.1
2011-03-13 20:44:06,976 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-03-13 20:44:07,017 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-03-13 20:44:07,026 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-03-13 20:44:07,026 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-03-13 20:44:07,028 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-13 20:44:07,028 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-03-13 20:44:07,028 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1300074247028, LastAccessTime = 1300074247028, getTimeToLiveSeconds() = -1, createTime = 1300074247028 ]
2011-03-13 20:44:07,031 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-03-13 20:44:07,085 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-03-13 20:44:07,085 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-13 20:44:07,086 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-03-13 20:44:07,086 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-03-13 20:44:07,086 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-13 20:44:07,086 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-03-13 20:44:07,086 INFO [CompositeCacheConfigurator] Finished configuration in 64 ms.
2011-03-13 20:44:07,095 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-03-13 20:44:07,097 INFO [EventDispatcher] Starting EventDispatcher
2011-03-13 20:44:07,099 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface vmnet1 (vmnet1) and address 192.168.76.1, timeout = 0
2011-03-13 20:44:07,101 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-03-13 20:44:07,119 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-03-13 20:44:07,120 INFO [RendererSearchSender] Searching for Renderer devices
2011-03-13 20:44:33,227 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-03-13 20:44:33,280 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-03-13 20:45:42,418 INFO [UpdateChecker] Checking if a new version is available
2011-03-13 20:45:52,024 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-03-13 20:45:53,585 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-03-13 20:47:26,816 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-03-13 20:47:27,106 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-03-13 20:47:27,130 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-03-13 20:48:32,206 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-03-13 20:48:32,409 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-03-13 20:48:32,427 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-03-13 20:52:56,580 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-03-13 20:52:56,855 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-03-13 20:52:56,859 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-03-13 20:53:00,069 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-03-13 20:53:00,217 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-03-13 20:53:00,221 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-03-13 21:10:13,894 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-03-13 21:10:14,009 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-03-13 21:10:14,015 INFO [WebServer] WebServer shutting down
2011-03-13 21:10:14,017 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-03-13 21:10:14,018 INFO [EventDispatcher] Leaving EventDispatcher
2011-03-13 21:10:14,025 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-03-13 21:10:14,040 INFO [DatabaseManager] Shutting down database
2011-03-13 21:10:14,199 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-03-13 21:10:29,471 INFO [MediaServer] ------------------------------------------------------------------------
2011-03-13 21:10:29,473 INFO [MediaServer] Serviio DLNA media streaming server v 0.5.1 (rev. 0c488c4fc651)
2011-03-13 21:10:29,473 INFO [MediaServer] Petr Nejedly 2009-2011
2011-03-13 21:10:29,473 INFO [MediaServer] http://www.serviio.org
2011-03-13 21:10:29,473 INFO [MediaServer] Java 1.6.0_22-Apple Inc.
2011-03-13 21:10:29,473 INFO [MediaServer] OS Mac OS X x86_64 10.6.6
2011-03-13 21:10:29,473 INFO [MediaServer] File encoding: UTF-8
2011-03-13 21:10:29,473 INFO [MediaServer] ------------------------------------------------------------------------
2011-03-13 21:10:29,761 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2011-03-13 21:10:29,924 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-03-13 21:10:35,294 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-03-13 21:10:36,575 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-03-13 21:10:36,849 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-03-13 21:10:36,986 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-03-13 21:10:37,128 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-03-13 21:10:37,277 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-03-13 21:10:37,389 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-03-13 21:10:37,846 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C-series)' (id=7)
2011-03-13 21:10:37,890 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-03-13 21:10:38,422 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-03-13 21:10:39,072 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-03-13 21:10:39,351 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-03-13 21:10:39,663 INFO [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-03-13 21:10:40,010 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-03-13 21:10:40,041 INFO [WebServer] Socket buffer set to 65535 bytes
2011-03-13 21:10:40,106 INFO [WebServer] WebServer starting on port 8895
2011-03-13 21:10:40,129 INFO [Device] Created UPnP Device with UUID: 513a8a93-a8c3-3fcc-9ac9-a10c60a0cd84, bound address: 192.168.76.1
2011-03-13 21:10:40,169 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-03-13 21:10:40,183 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-03-13 21:10:40,191 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-03-13 21:10:40,192 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-03-13 21:10:40,195 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-13 21:10:40,195 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-03-13 21:10:40,195 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1300075840195, LastAccessTime = 1300075840195, getTimeToLiveSeconds() = -1, createTime = 1300075840195 ]
2011-03-13 21:10:40,198 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-03-13 21:10:40,219 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-03-13 21:10:40,219 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-13 21:10:40,219 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-03-13 21:10:40,220 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-03-13 21:10:40,220 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-13 21:10:40,220 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-03-13 21:10:40,220 INFO [CompositeCacheConfigurator] Finished configuration in 30 ms.
2011-03-13 21:10:40,232 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface vmnet1 (vmnet1) and address 192.168.76.1, timeout = 0
2011-03-13 21:10:40,234 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-03-13 21:10:40,247 INFO [EventDispatcher] Starting EventDispatcher
2011-03-13 21:10:40,248 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-03-13 21:10:40,265 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-03-13 21:10:40,267 INFO [RendererSearchSender] Searching for Renderer devices
2011-03-13 21:11:06,344 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-03-13 21:11:06,376 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-03-13 21:23:06,073 INFO [UpdateChecker] Checking if a new version is available
2011-03-13 21:23:13,476 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-03-13 21:23:14,581 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-03-13 21:25:05,414 INFO [WebServer] WebServer shutting down
2011-03-13 21:25:05,414 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-03-13 21:25:05,414 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-03-13 21:25:05,414 INFO [EventDispatcher] Leaving EventDispatcher
2011-03-13 21:25:05,424 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-03-13 21:25:07,079 INFO [WebServer] WebServer starting on port 8895
2011-03-13 21:25:07,084 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface vmnet1 (vmnet1) and address 192.168.76.1, timeout = 0
2011-03-13 21:25:07,089 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-03-13 21:25:07,105 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-03-13 21:25:07,095 INFO [EventDispatcher] Starting EventDispatcher
2011-03-13 21:25:07,110 INFO [RendererSearchSender] Searching for Renderer devices
2011-03-13 21:25:10,352 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2011-03-13 21:59:01,473 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-03-13 21:59:01,643 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-03-13 21:59:01,652 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-03-13 22:14:25,519 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-03-13 22:14:25,523 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-03-13 22:14:25,523 INFO [EventDispatcher] Leaving EventDispatcher
2011-03-13 22:14:25,525 INFO [WebServer] WebServer shutting down
2011-03-13 22:14:25,527 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-03-13 22:14:25,553 INFO [Device] Updated bound IP address of Device with UUID: 513a8a93-a8c3-3fcc-9ac9-a10c60a0cd84, bound address: 192.168.1.8
2011-03-13 22:14:25,554 INFO [WebServer] WebServer starting on port 8895
2011-03-13 22:14:25,557 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface en0 (en0) and address 192.168.1.8, timeout = 0
2011-03-13 22:14:25,563 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-03-13 22:14:25,563 INFO [EventDispatcher] Starting EventDispatcher
2011-03-13 22:14:25,564 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-03-13 22:14:25,564 INFO [RendererSearchSender] Searching for Renderer devices
2011-03-13 22:14:40,378 INFO [WebServer] WebServer shutting down
2011-03-13 22:14:40,378 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-03-13 22:14:40,378 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-03-13 22:14:40,378 INFO [EventDispatcher] Leaving EventDispatcher
2011-03-13 22:14:40,386 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-03-13 22:14:41,668 INFO [WebServer] WebServer starting on port 8895
2011-03-13 22:14:41,680 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface en0 (en0) and address 192.168.1.8, timeout = 0
2011-03-13 22:14:41,683 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-03-13 22:14:41,695 INFO [EventDispatcher] Starting EventDispatcher
2011-03-13 22:14:41,695 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-03-13 22:14:41,695 INFO [RendererSearchSender] Searching for Renderer devices
2011-03-13 22:40:23,037 INFO [LibraryAdditionsCheckerThread] Added file 'DSCN1177.AVI' (title: DSCN1177) to Library
2011-03-13 22:59:32,445 INFO [LibraryAdditionsCheckerThread] Added file 'AndroMoteTemp36186.avi' (title: AndroMoteTemp36186) to Library
2011-03-13 22:59:56,986 INFO [LibraryAdditionsCheckerThread] Added file 'IMG_0661.MOV' (title: IMG_0661) to Library
2011-03-13 23:00:15,139 INFO [LibraryAdditionsCheckerThread] Added file 'IMG_0733.MOV' (title: IMG_0733) to Library
2011-03-13 23:04:10,463 INFO [LibraryAdditionsCheckerThread] Added file 'He Got Game.avi' (title: He Got Game) to Library
2011-03-13 23:57:30,122 WARN [VideoExtractionStrategy] Couldn't resolve H264 profile/level for file 'Raging.Bull.1980.BluRay.720p.H264.mp4' because Sequence parameter set header was not recognized
2011-03-14 00:00:14,368 INFO [LibraryAdditionsCheckerThread] Added file 'Raging.Bull.1980.BluRay.720p.H264.mp4' (title: Raging Bull) to Library
2011-03-14 01:47:13,586 WARN [LibraryManager] Cannot read metadata of file /Volumes/USB_Storage/Movies/Family Guy/Family.Guy.S09E21.Its.a.TrapReGeN.mkv via extractor ONLINE_VIDEO_SOURCES. Message: Cannot retrieve episode details (series = 75978, season = 9, episode = 21), file not found
2011-03-14 01:47:14,130 INFO [LibraryAdditionsCheckerThread] Added file 'Family.Guy.S09E21.Its.a.TrapReGeN.mkv' (title: Family.Guy.S09E21.Its.a.TrapReGeN) to Library
2011-03-14 03:07:30,766 INFO [LibraryAdditionsCheckerThread] Added file 'Crank.m4v' (title: Crank) to Library
2011-03-14 03:10:11,906 WARN [OutputTextReader] Error reading output of an external command:Bad file descriptor
2011-03-14 04:06:30,711 WARN [VideoExtractionStrategy] Couldn't resolve H264 profile/level for file '1sthalf.mp4' because Sequence parameter set header was not recognized
2011-03-14 04:07:19,825 INFO [LibraryAdditionsCheckerThread] Added file '1sthalf.mp4' (title: 1sthalf) to Library
2011-03-14 04:07:20,746 WARN [VideoExtractionStrategy] Couldn't resolve H264 profile/level for file '2ndhalf.mp4' because Sequence parameter set header was not recognized
2011-03-14 05:42:36,650 INFO [LibraryAdditionsCheckerThread] Added file 'Walt Disney - Pixar - Cars.avi' (title: Walt Disney - Pixar - Cars) to Library
2011-03-14 05:42:37,668 WARN [VideoExtractionStrategy] Couldn't resolve H264 profile/level for file 'Walt Disney - Pixar - Despicable Me.mp4' because Sequence parameter set header was not recognized
2011-03-14 05:44:30,450 INFO [LibraryAdditionsCheckerThread] Added file 'Walt Disney - Pixar - Despicable Me.mp4' (title: Walt Disney - Pixar - Despicable Me) to Library
2011-03-14 06:40:34,642 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-03-14 06:40:34,855 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-03-14 06:40:34,858 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-03-14 17:44:12,645 INFO [LibraryAdditionsCheckerThread] Added file 'Aliens [1986] [Special Edition] Handbrake.mkv' (title: Aliens) to Library
2011-03-14 18:17:48,033 INFO [RendererManager] Stored a new renderer: uuid='6bff1ad8-fb24-494b-9e29-1a809e592fd1', name = 'Samsung', ipAddress='192.168.1.4', profile = '1'
2011-03-14 18:17:48,035 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-03-14 18:17:48,035 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-03-14 18:17:48,038 INFO [EventDispatcher] Leaving EventDispatcher
2011-03-14 18:17:48,037 INFO [WebServer] WebServer shutting down
2011-03-14 18:17:48,040 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-03-14 18:17:48,052 INFO [WebServer] WebServer starting on port 8895
2011-03-14 18:17:48,061 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface en0 (en0) and address 192.168.1.8, timeout = 0
2011-03-14 18:17:48,071 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-03-14 18:17:48,083 INFO [EventDispatcher] Starting EventDispatcher
2011-03-14 18:17:48,084 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-03-14 18:17:48,084 INFO [RendererSearchSender] Searching for Renderer devices
Post Tue Mar 15, 2011 1:01 pm
Re: Samsung LN46C630 OSX MKV and Serviio...
You have a couple of IP addresses in the log:
192.168.76.1 .. this should be the IP of your Mac, is that right (i suppose not, looks like VMWare IP)? If not, enter the proper IP into the Bound IP address field.
.4 vs .7 IP addresses ... Maybe it's just because your router gives the TV a new IP address everytime it starts and the console view is not up to date (try clicking Refresh). I'd suggest to setup the Mac and the TV with static IP addresses on your router.
Regarding FFmpeg, you'll have to open Terminal, find the ffmpeg file on your file system and execute it, like:
cd /bla/bla/Serviio.app/bla
./ffmpeg -i <file>
Users browsing this forum: No registered users and 49 guests
