Resume video playback on Samsung TVs
dr4x0n
Post Tue Mar 15, 2011 5:20 pm
Re: Resume video playback on Samsung TVs
Will this feature ever be available on the Samsung B series?
dr4x0n
Post Tue Mar 15, 2011 5:26 pm
dr4x0n wrote:Will this feature ever be available on the Samsung B series?
dr4x0n
No, the TV doesn't support it unfortunately.
riemen
Post Sun Mar 20, 2011 5:37 am
Thanks sooo much for adding this feature. Resume Playback was the only reason I was hanging on to PC Share Manager. I'm uninstalling it now for good!! That is, right after I send a Paypal donation to Servio.
Thanks for making this happen.
Pete R.
Post Sun Mar 20, 2011 12:24 pm
______ UPDATE ______
For some reason bookmark have stopped working or work erracticly and at the moment the serviio team have no idea why, we are working to get this sorted and will post back here once we fix this, if you find you can get bookmarks working consistantly and can explain exactly how you made this work then please post, otherwise you will just need to wait till its sorted. :)
see this post for updates : viewtopic.php?f=10&t=1981&start=30#p11208
Make sure you go all the way to end and read post by ZIP or myself.
dr4x0n
Post Sat Apr 02, 2011 12:48 am
Just wanted to run this by one more time. I have a UN46B8500 series TV. In order to get the Fast Forward and Rewind to work I run the .mkv 720p files through XenonMKV which strips the MKV wrapper and turns it into a MP4 file that can be FF and REW from the Serviio software. I do not get the Play Continuously (Resume) Press D Blue button when stopping and starting the file. If I copy the MKV or MP4 file over to a USB drive and run it directly from the TV then I also get FF and REW with the MKV file and both allow the Play Continuously (Resume) D Blue button option.
So the TV seems to be capable what is missing on the software side that would allow these options to be put in Serviio?
I have attached some screen shots of the files playing from a USB thumb drive.
Thanks for looking at this again Zip. I have been enjoying the software tremendously. Also since I could never ever get the Samsung software installed to my Windows 7 computer, your software has been awesome.
I have very little programming experience so I was just mainly looking for a more detailed explanation of why this is hard to make happen.
ImageIMAG0301 by dr4x0n, on Flickr
ImageIMAG0302 by dr4x0n, on Flickr
dr4x0n
Post Sat Apr 02, 2011 8:22 am
dr4x0n wrote:Just wanted to run this by one more time. I have a UN46B8500 series TV. In order to get the Fast Forward and Rewind to work I run the .mkv 720p files through XenonMKV which strips the MKV wrapper and turns it into a MP4 file that can be FF and REW from the Serviio software. I do not get the Play Continuously (Resume) Press D Blue button when stopping and starting the file. If I copy the MKV or MP4 file over to a USB drive and run it directly from the TV then I also get FF and REW with the MKV file and both allow the Play Continuously (Resume) D Blue button option.
dr4x0n
B series devices does NOT support it.
Previous
Return to Feature requests
