MED600X3D - need transcoding on a couple of cases
ajmg
Post Tue Aug 09, 2016 10:37 am
Hi all…
Use Serviio long time ago and now just took a MED600X3D.
I need to use them together for a couple of cases…
MED600X3D reads almost everything I tested so, basically, I want access Serviio from MED600X3D, just to read RAW photos and everything 4K related.
For that, I know I need a profile that I guess will not be much complicated, but I’m not reaching there…
Given the MED600X3D deals very well with Full HD, just need transcode RAW photos and 4K related files to a format that not “loose” more quality than the necessary to make it compatible.
Can someone help me, please?
Thank you very much…
ajmg
Post Tue Aug 09, 2016 12:38 pm
Re: MED600X3D - need transcoding on a couple of cases
Sorry guys...
RAW (NEF) it's working... I don't know what was the problem the first time i tried...
So... The question is now only about everything related to 4K...
Thank you...
Post Tue Aug 09, 2016 12:47 pm
Try the WDTV Live profile. This profile only transcodes a few video formats (including HEVC which I presume your 4K files are - check with MediaInfo).
If it works use this as the basis to create your own profile.
attonyzhou
Post Wed Aug 10, 2016 6:54 am
ajmg wrote:Sorry guys...
Thank you...
If it's MP4 4K video, try profile like this:
                        <!-- transcode 4K video to 1080*1920 H264 -->
                        <!-- transcode with H264 video -->
                        <Video targetContainer="mpeg" targetVCodec="h264" targetACodec="ac3" maxHeight="1080" maxVBitrate="20000">
ajmg
Post Wed Aug 10, 2016 1:50 pm
Hi again!
Thank you for your help… :-)
After see your advices and check some other things, I ended up with the following profile:
   <Profile id="MED600X3D" name="Mede8er MED600X3D" extendsProfileId="1">
            <Matches container="*" vCodec="h264" profile="high_10" />
            <Matches container="*" vCodec="h264" profile="high_444" />
            <Matches container="*" vCodec="h264" profile="high_422" />
            <Matches container="*" vCodec="h264" profile="high" levelGreaterThan="4.2" />
            <Matches container="*" vCodec="h264" profile="main" levelGreaterThan="4.2" />
            <Matches container="*" vCodec="h265" />
            <Matches container="matroska" vCodec="vp9" />
I get sound but no image.
Then I remember to check and using my Sony BDP S790 with its own profile, I have exactly the same problem.
After this, I tried to change the ffmpeg to the last build. The problem remains…
What else should I check?
Any idea of what can be the problem?
Thank you very much again…
ajmg
Post Wed Aug 10, 2016 6:01 pm
Ok...
Was reading this http://forum.serviio.org/viewtopic.php?f=7&t=22049 and i ended up solving my problem...
Just changed the corresponding line to:
<Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="ac3" maxHeight="1080" maxVBitrate="20000">
This worked to MED600X3D.
Later i will check the Sony BDP profile to something similar...
Thank you all... :P
Users browsing this forum: Google [Bot] and 76 guests
