ServiiDroid (Android Console) - Get it on Google Play
3.3 has now been released to testers and will be made available for all users in a few days.
Re: ServiiDroid (Android Console) - Get it on Google Play
3.3 is now available for everyone and includes a minor fix.
3.3.2 has now been released to google play.
I've uploaded a new beta to Google play*, please give it a test it (with 1.6 and 1.7) and report back any issues, hoping to release it for everyone very soon.
* To get beta versions, sign up as a tester at https://play.google.com/apps/testing/com.serviidroid
Release version is now out for everyone.
After a big delay, here is the next beta with some initial support for Serviio 1.8. Please test with 1.8 and older and report back any issues.
Didn't get any feedback on the beta and haven't found any problems so I've made it available for everyone now.
Thanks Will, working fine for me.
Keep up all the good work!
There are some missing translations (czech) in new version. In GetLocalization Czech is 100% translated but in 3.5 I see some english texts. E.g. Language settings, Prefer miltichannel audio, Falllback to "Default" etc.
hans wrote:There are some missing translations (czech) in new version. In GetLocalization Czech is 100% translated but in 3.5 I see some english texts. E.g. Language settings, Prefer miltichannel audio, Falllback to "Default" etc.
Sorry have been very busy recently and forgot to update them, will try to do that this weekend.
ServiiDroid Won't Open After Android O Update
The ServiiDroid app has been running fine on Note 8 running Android N however as I have updated to Android O today when I open the app it only loads a blank screen during the start up and crashes after a while automatically. How do I fix it??
Re: ServiiDroid Won't Open After Android O Update
dixitarjun wrote:The ServiiDroid app has been running fine on Note 8 running Android N however as I have updated to Android O today when I open the app it only loads a blank screen during the start up and crashes after a while automatically. How do I fix it??
Sent from my HTC U11 using Tapatalk
Still working on Google Pixel Android O
Still working on Google Pixel Android O. Although, some setting changes causes app to crash.
Ask in the ServiiDroid forum. viewtopic.php?f=17&t=5056
Petr
Help translate Serviio
Update: I've been able to fix the issue. On uninstall and reinstalling the latest version it's working just fine again
3.6 is now rolling out on Google Play with very limited support for 2.0 (you can't use the app to view/change new things such as users but it shouldn't undo any changes made by the official console).
I'm intending to add full support once I've got ServiiGo updated.
Clearing cached data can free up needed space by removing temporary files. This is a short-term solution. Over time, cached data will build up again.
Open your phone's Settings app.
Tap Apps & notifications.
Tap the app. If you don't see it, first tap See all apps or App info.
Tap Storage & cache and then Clear cache.
get-shareit.com get-vidmateapk.com
any plans to add new indexed file notification? thanks
