Ubuntu - Serviio unable to login when run as service
ZK57
Post Thu Sep 29, 2016 5:23 am
So, I have been trying to get Serviio on Ubuntu 16.04 and have had a lot of problems. I finally managed to get it to work using
sudo sh serviio.sh
I am able to log in remotely, but when I tried setting it up to run as a service on boot up, it starts up and is running, but when I try to login to the Media Brower, it immediately comes back to the login screen.
/etc/init.d script
#! /bin/sh
    ### BEGIN INIT INFO
    # Provides:          serviio
    # Required-Start:    $local_fs $remote_fs $network $syslog
    # Required-Stop:     $local_fs $remote_fs $network $syslog
    # Default-Start:     2 3 4 5
    # Default-Stop:      0 1 6
    # X-Interactive:     true
    # Short-Description: Start/stop serviio media server
    # Description:       The Serviio media server makes your media available to
    #                    all kinds of networked devices.
    ### END INIT INFO
    #- Daemon Script Configuration for Serviio Media Server
    #- By Ian Laird; converted for Debian by Jacob Lundberg
    #- Updated and Merged for Ubuntu 14.04 by Matthew Bate
    . /lib/lsb/init-functions
    if [ -f /etc/default/rcS ]; then
            . /etc/default/rcS
    fi
    NAME="Serviio Media Server"
    DAEMON="/opt/serviio/bin/serviio.sh"      ## Update this to point at your serviio/bin/serviio.sh
    DAEMON_STOP=" -stop"
    SERVICE_ACCOUNT="serviio"            ## DON'T RUN UNDER ROOT!
    TIMEOUT=3
    # We have this because start-stop-daemon needs one and wont start without it.  Although it provides wrong PID ID of Java Client.
    PIDFILE="/var/run/serviiod.pid"
    if [ -f /etc/default/serviio ]; then
            . /etc/default/serviio
    fi
    [ -x "$DAEMON" ] || exit 0
    #  Status function check not only the PID file but if it has gone missing it will look for the Java Client manually.
    status() {
        if [ $1 = "PID" ]; then
       if [ ! -f $TPIDFILE ]; then
           PID=$(ps -ef | grep "org.serviio.MediaServer" | grep -v grep | awk "{ print \$2 }")
           echo $PID
       else
           PID=$(cat $TPIDFILE)
              echo $PID
       fi
        else
            if [[ -z $PID ]]; then
                if [ $1 = "status" ]; then log_daemon_msg "Serviio is currently offline."; else echo "0"; fi # Offline
            else
              if [ $1 = "status" ]; then log_daemon_msg "Serviio is currently online."; else echo "1"; fi # Online
            fi
        fi
    start() {
        RUNNING=$(status "0")
        if [ $RUNNING = "0" ]; then
       log_daemon_msg "Starting Serviio Media Server..."
       start-stop-daemon --start -q -b -p "$PIDFILE" -m -c "${SERVICE_ACCOUNT}" -x "${DAEMON}"
       log_end_msg $?
        else
       log_daemon_msg "Serviio Media Server is already running."
       log_end_msg 1
        fi
    stop() {
        if [ ${#RUNNING} = "1" ]; then
       log_daemon_msg "Shutting Down Serviio Media Server..."
       ${DAEMON} ${DAEMON_STOP}
       log_end_msg $?
        else
       log_daemon_msg "Serviio Media Server is already shutdown."
       log_end_msg 1
        fi
    force_stop() {
       RUNNING=$(status "PID")
       kill -TERM $RUNNING
       log_end_msg $?
        else
       log_end_msg 1
        fi
    case "${1:-}" in
            start)
                    start
            stop)
                    stop
            restart)
                    stop
                    start
            status)
                    status $1
       force-stop)
          force_stop
                    log_success_msg "Usage: /etc/init.d/$NAME {start|stop|force-stop|restart|status}"
                    exit 1
    esac
    exit 0
Post Thu Sep 29, 2016 8:04 pm
Re: Ubuntu - Serviio unable to login when run as service
did you set up a password in the console for the Remote (MediaBrowser) session?
ZK57
Post Fri Sep 30, 2016 12:04 am
zip wrote:did you set up a password in the console for the Remote (MediaBrowser) session?
Yes I did. If I shutdown the serviio service and just run the serviio.sh script in the bin directory, then I can login, but not if I run serviio as a service. I am wondering if it is a permission issue. I setup a serviio user and group, but when I run the script I do it with admin rights on my administrator account. My serviio folder though is setup as root as is the serviio.sh script.
Post Fri Sep 30, 2016 12:54 pm
It should not really matter. You could check the serviio log file if there are any errors (you might have to enable detailed logging), and also check the browser DevTools Console to see if there are any JavaScript errors.
Users browsing this forum: Baidu [Spider] and 14 guests
