Mediabrowser thumbnails size
dominotes
Post Fri Oct 14, 2016 9:51 am
New to Serviio (I discovered it yesterday), I try to tune an archlinux Serviio server.
The thumbnail size can be set with
serviio.hdThumbnailResoulution - specifies the dimension (width in pixels) to be used for HD thumbnails; defaults to 320
And I'm supposed to (FAQ)
System properties are provided to the server in the form of -D<property_name>=<property_value>.
Edit file serviio.sh and add the variable to JAVA_OPTS property.
In my serviio.sh file, I only get one line containing JAVA_OPTS :
exec "$JAVA" -Xmx512M -Xms20M -XX:+UseG1GC -XX:GCTimeRatio=1 -XX:MinHeapFreeRatio=10 -XX:MaxHeapFreeRatio=20 $JAVA_OPTS -classpath "$SERVIIO_CLASS_PATH" org.serviio.MediaServer "$@"
So, for a 240 thumbnail size, I suppose I should add somewhere :
-D serviio.hdThumbnailResoulution = 240
My question : where should I write this line.
Thanks in advance
I do not open a new topic for my 3 comments :
1) is there a file number limitation (I do have many cds and discs)
2) I'd like a midi file support (.mid files)
3) Lyrics support. This can be very easy :
suppose in an x folder you get an y.flac file AND lyrics as y.txt correspondings to the y.flac (or any supported extension)
Serviio matches the audio, and can display the lyrics.
No .txt match -> no lyrics ! as simple as that.
I do have almost all lyrics in txt files ... same title, .txt extension
Thanks in advance to study this suggestion.
Note : I'm about to buy the pro version. Price is OK for me.
Post Fri Oct 14, 2016 2:11 pm
Re: Mediabrowser thumbnails size
how did you get this distribution? Is it the Linux from serviio.org or repackaged from somewhere else? The official one has this line:
# Setup Serviio specific properties
JAVA_OPTS="-Djava.net.preferIPv4Stack=true -Djava.awt.headless=true -Dorg.restlet.engine.loggerFacadeClass=org.restlet.ext.slf4j.Slf4jLoggerFacade -Dderby.system.home=$SERVIIO_HOME/library -Dserviio.home=$SERVIIO_HOME -Dffmpeg.location=ffmpeg -Ddcraw.location=dcraw"
so you'd just add
-Dserviio.hdThumbnailResoulution=xxx
at the end of the line.
BTW, just noticed the property name is not spelled right, but that's what Serviio currently expects. Might change it in future to the correct spelling.
Also, this setting is only used when adding the files to the library, once your files are already there they will have thumbnail with the previous resolution. You will have to re-add the files to the library.
dominotes
Post Fri Oct 14, 2016 3:47 pm
Thank you for your help.
To get serviio-1.7.1, I did : "yaourt -S serviio" in a terminal, and pacman/yaourt did the job (archlinux)
I've just downloaded serviio-1.7.1 from http://serviio.org/download and now I do find the
lines.
Concerning my number of files, all of them are included in the database, so point 1) is solved too.
What about midi support ?
dominotes
Post Fri Oct 21, 2016 7:22 am
The -D serviio.hdThumbnailResoulution =xxx parameter does not work with 1.7.1 : the console error is
./serviio.sh
Erreur : impossible de trouver ou charger la classe principale serviio.hdThumbnailResoulution
Same problem with -D serviio.hdThumbnailResolution = xxx
(of course, xxx is a value, not letters)
The serviio.sh script does not find the hdThumbnailResoulution class.
Maybe it's name has changed.
Post Fri Oct 21, 2016 2:35 pm
remove any spaces you have in the command, it should be for example
-DhdThumbnailResoulution=640
dominotes
Post Sun Oct 23, 2016 8:18 am
Thank you zip :
correct parameter is
-DhdThumbnailResoulution=xxx
and not
-D serviio.hdThumbnailResoulution=xxx
or
-D serviio.hdThumbnailResoulution =xxx (spaces before / after "=")
All my cover.jpg files have a high resolution.
Thumbnail quality is good with a 285 value instead of 320 (default)
285 is the maximum width thumbnail size on my Hd monitors.
Now, I've got a problem with the quality of a cover while playing a song :
here is what serviio displays
Note that we cannot see the top and the bottom of the cover on the serviio display
Can we improve this quality ?
Edit : in fullscreen, the cover is displayed normally (X/Y sizes) - just picture quality is too compressed !
Mukes
Post Fri Nov 25, 2016 9:27 am
Hi zip,
Hi Serviio-Community,
I'm running Serviio v 1.7.1.1 on a Windos 8 PC and i'm trying to increase the Thumbnailresolution.
I tried to add
to serviio.bat and/or to ServiioService.exe.vmoptions but it doesn't work.
The Imageresolution is set to HD (not DLNA) for each Profile.
I restarted the PC, removed the Media from the Folder, scanned for new Files, then put the Media back into the Folder an scanned again.
Am i missing something?
Mukes
Post Fri Nov 25, 2016 10:15 am
After a lot of trial and error i finally got it. (The last two days i spent about 3 hours for this :roll: )
i added
-Dserviio.hdThumbnailResoulution=640
to
But i'm wondering why the command is different to the one that worked for @dominotes ?!
Oubadah
Post Fri Aug 18, 2017 8:13 am
I finally managed to get this working. Serviio now displays my art at its native resolution, but I see that it's heavily compressed (jpeg compression artifacts). Is there any way to reduce the amount of compression Serviio applies to the images?
Post Fri Aug 18, 2017 2:11 pm
Nope
Pir8pete
Post Mon May 27, 2019 3:58 pm
Mukes wrote:After a lot of trial and error i finally got it. (The last two days i spent about 3 hours for this :roll: )
i added
to
Yes sir this is what worked for me too, thx
