Samsung la40c650 Allshare sees nothing.
lusk
Post Thu Mar 17, 2011 1:34 pm
First off I'd like to say thanks for this great program. Sorry I am here whinging about not being able to get it to work properly.
Ok so as the title states, my problem is that Serviio is not being found on my Samsung la40c650. I am using version 0.5.1 and I have forwarded the ports 8895 (TCP) and 1900 (UDP). I have the latest firmware installed on my router (Billion 5200nrc) and also on my TV. Serviio itself can see my television and it has a green light next to it as it should but when i go into allshare on my TV, it is unable to find Serviio. I have included my most recent log for you perusal. I hope it is sufficient.
Thanks heaps and sorry for being a noob. :(
2011-03-17 22:57:42,265 INFO [MediaServer] ------------------------------------------------------------------------
2011-03-17 22:57:42,265 INFO [MediaServer] Serviio DLNA media streaming server v 0.5.1 (rev. 0c488c4fc651)
2011-03-17 22:57:42,265 INFO [MediaServer] Petr Nejedly 2009-2011
2011-03-17 22:57:42,265 INFO [MediaServer] http://www.serviio.org
2011-03-17 22:57:42,265 INFO [MediaServer] Java 1.6.0_24-Sun Microsystems Inc.
2011-03-17 22:57:42,265 INFO [MediaServer] OS Windows XP x86 5.1
2011-03-17 22:57:42,265 INFO [MediaServer] File encoding: windows-1252
2011-03-17 22:57:42,328 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2011-03-17 22:57:42,359 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-03-17 22:57:43,234 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-03-17 22:57:43,390 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-03-17 22:57:43,468 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-03-17 22:57:43,500 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-03-17 22:57:43,546 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-03-17 22:57:43,593 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-03-17 22:57:43,609 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-03-17 22:57:43,687 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C-series)' (id=7)
2011-03-17 22:57:43,718 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-03-17 22:57:43,828 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-03-17 22:57:44,046 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-03-17 22:57:44,093 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-03-17 22:57:44,140 INFO [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-03-17 22:57:44,171 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-03-17 22:57:44,171 INFO [WebServer] Socket buffer set to 65535 bytes
2011-03-17 22:57:44,203 INFO [WebServer] WebServer starting on port 8895
2011-03-17 22:57:44,343 INFO [Device] Created UPnP Device with UUID: e34d6a1f-d9fb-341f-afe4-1c8537729210, bound address: 5.52.183.27
2011-03-17 22:57:44,359 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-03-17 22:57:44,359 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-03-17 22:57:44,359 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-03-17 22:57:44,359 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-03-17 22:57:44,359 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-17 22:57:44,359 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-03-17 22:57:44,359 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1300366664359, LastAccessTime = 1300366664359, getTimeToLiveSeconds() = -1, createTime = 1300366664359 ]
2011-03-17 22:57:44,359 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-03-17 22:57:44,375 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-03-17 22:57:44,375 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-17 22:57:44,375 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-03-17 22:57:44,375 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-03-17 22:57:44,375 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-17 22:57:44,375 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-03-17 22:57:44,375 INFO [CompositeCacheConfigurator] Finished configuration in 16 ms.
2011-03-17 22:57:44,375 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-03-17 22:57:44,375 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-03-17 22:57:44,375 INFO [EventDispatcher] Starting EventDispatcher
2011-03-17 22:57:44,375 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (Hamachi Network Interface) and address 5.52.183.27, timeout = 0
2011-03-17 22:57:44,375 INFO [RendererSearchSender] Searching for Renderer devices
2011-03-17 22:57:44,375 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-03-17 22:57:48,406 INFO [ServiioConsole] Starting Serviio Console
2011-03-17 22:57:48,468 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-03-17 22:57:49,140 INFO [Messages] Loaded console message bundle for locale: en
2011-03-17 22:57:51,609 INFO [Messages] Loaded console message bundle for locale: en
2011-03-17 22:57:51,718 INFO [UpdateChecker] Checking if a new version is available
2011-03-17 22:57:57,796 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-03-17 22:57:58,000 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-03-17 22:58:10,437 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-03-17 22:58:10,437 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
Post Thu Mar 17, 2011 4:46 pm
Re: Samsung la40c650 Allshare sees nothing.
It picks up your Hamachi network card (5.52.183.27), use the bound IP address field in the console to bind Serviio to your proper IP address
lusk
Post Thu Mar 17, 2011 5:04 pm
zip wrote:It picks up your Hamachi network card (5.52.183.27), use the bound IP address field in the console to bind Serviio to your proper IP address
That seems to have done the trick. Thanks a lot mate. I swear I put my ip address on this network into bound ip before but maybe i hadn't shut down the serviio service and console down properly. Anyway, thanks alot.
