SONY KDL-42W805A does not find Serviio
martindoin
Post Sun Apr 23, 2017 2:05 am
Hello!
I've been using serviio in my Bravia without any problem for a long time, but now Serviio doesn't appear in the server list.
There is a very important issue:
if i deactivate the "Remote device Renderer" Option at the Bravia Home Network Setup then Serviio is found and works perfectly, but
if I activate the "Remote device Renderer" then Serviio doesn't appear and it shows me "Cannot connect to the server"
Well, you may think "take the first option" but the problem is that when Remote Device Renderer is Off many other apps like TV Side View stop working.
please help me, I've been reading a lot of Blogs but cannot find the answer.
The log file is attached
Thanks!
(358.56 KiB) Downloaded 973 times
martindoin
Post Thu Apr 27, 2017 12:56 pm
Re: SONY KDL-42W805A does not find Serviio
Can anyone help me!
Post Thu Apr 27, 2017 1:02 pm
You need someone who is familiar with Sony and the Bravia Home Network function. I am not. I don't have a name to suggest, but someone will see your post, I'm sure.
