Http Stream Issue
• Page 1 of 1
Im new here so if im posting in the wrong section delete my post
I installed serviio trial version and added a http stream in a .ts format from my windows machine . My Philips TV is connecting with Serviio and i found in the video folder under the categories ONLINE the http i added from my machine put when i press play it does not load . Stream is working 100% . What can be the issue . Thanks in advance
Re: Http Stream Issue
Did you installed the Serviio plugin?
Try using Serviio plug-ins.
@Mariad which serviio plug-ins?
Tubefox might help, works for Youtube streaming.
mariad wrote:Tubefox might help, works for Youtube streaming.
Alright will try thanks
Yup just tried it and it is working!
Good to go then i guess, you can thank me anytime.
mariad wrote:Good to go then i guess, you can thank me anytime.
haha, thanks a lot dear.
You're welcome. Glad to help.
• Page 1 of 1
