Fast forward not working in low and medium resolutions
leocharrua
Post Tue Jun 06, 2017 10:28 pm
Hello. I have installed serviio 1.5.1 in a windows 10 pc. I'm playing video files in android with ServiiGo. When I choose original resolution all works fine, but setting low or medium resolution, backwarding or forwarding the video not works (do nothing when I click in the forward line of MxPlayer).
Help please.
Post Wed Jun 07, 2017 8:31 am
Re: Fast forward not working in low and medium resolutions
That's because they are transcoded and the player doesn't support time based seeking for Serviio.
leocharrua
Post Thu Jun 08, 2017 1:37 pm
Thanks Petr for you answer. And what player I must use to get this function working?
Post Fri Jun 09, 2017 6:54 pm
It will most likely not work in any player.
leocharrua
Post Fri Jun 09, 2017 7:29 pm
Thanks again. Do you always have to watch the movie from the beginning with you don't choose the original resolution?
Is There any other way?
Post Sat Jun 10, 2017 12:32 am
leocharrua wrote:Thanks again. Do you always have to watch the movie from the beginning with you don't choose the original resolution?
Nope. Transcoded files are stuck with beginning to end play, without the ability to FF or Rewind. There's one possible exception, and that applehttp (HLS) transcoded files can be played with trick play functions. But that depends on the player to still support it. However, even with HLS you probably can't move forward beyond where the file has been transcoded to.
