[Sony] Problems on playing any media on KDL-48WD650
Saliba
Post Sun Jul 30, 2017 9:28 pm
Hi, I have a TV model KDL-48WD650 (2016) and Serviio is detecting it as KDL-32W700B with "Generic DLNA profile", I have tried to use profiles Sony Bravia 2013/2014, 2012 US and 2012 Non US.
Do I need to restart serviio or the TV when I change the profile ?
Is there any way to debug why I can't see any media ?
All the media works fine on my PS4.
Thanks !
calin1975
Post Sat Oct 07, 2017 4:56 pm
Re: [Sony] Problems on playing any media on KDL-48WD650
I’m experiencing the same with 40wd650 model...no one?
Post Sat Oct 07, 2017 11:08 pm
No, simply selecting a new profile does not require a restart. But you do have to click OK twice: once when you select the new profile, then again when you return to the status page there is another Save button at the bottom of the page. You have to hit that second button or it doesn't take effect.
Amader
Post Tue Dec 05, 2017 12:21 pm
Hi. What is your profile for KDL-48WD650? I have KDL-40WD653 (2016 year) and it is also identified as KDL-32W700B. I tried different profiles, but the TV in the server folders sees only .avi or nothing at all. For example, with the server Kodi, the TV in the folder sees all the files .avi, .mp4, .mkv and etc.
