Transcoding wtv files for the C5500
RamKat
Post Sat Mar 26, 2011 3:36 am
Running 0.51 I found that I have to add forceVTranscoding="true" to the profile when trying to stream a wtv recorded file to the C5500, or else the player does not recognize the file (the thumbnial is displayed though)
   <Video targetContainer="mpegts" forceVTranscoding="true">
      <Matches container="wtv" vCodec="mpeg2video" />
Problem is that some "link" in the pipeline is apparently now too slow to handle the bit rate resulting in stuttering video and sound. Either the transcoding process (I have enabled all 4 of the cores and system idle is at 70%), or the wired ethernet or the player.
Here is the ffmpeg -i info
C:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i "c:\Temp\WTV.wtv"
686-mingw32-
  libavutil     50.36. 0 / 50.36. 0
  libavcore      0.16. 0 /  0.16. 0
  libavcodec    52.108. 0 / 52.108. 0
  libavformat   52.92. 0 / 52.92. 0
  libavdevice   52. 2. 3 / 52. 2. 3
  libavfilter    1.72. 0 /  1.72. 0
  libswscale     0.12. 0 /  0.12. 0
[wtv @ 013dbca0] Estimating duration from bitrate, this may be inaccurate
Input #0, wtv, from 'c:\Temp\WTV.wtv':
  Duration: 00:05:18.99, start: 210.644624, bitrate: 17862 kb/s
    Stream #0.0[0xd]: Subtitle: [0][0][0][0] / 0x0000
    Stream #0.1[0x19](eng): Audio: ac3, 48000 Hz, 5.1, s16, 384 kb/s
    Stream #0.2[0x1a]: Video: mpeg2video, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9],
 17498 kb/s, PAR 16:9 DAR 256:81, 29.97 fps, 29.97 tbr, 10000k tbn, 59.94 tbc
Any advice out there?
thanks
Post Sat Mar 26, 2011 10:50 am
Re: Transcoding wtv files for the C5500
enable detailed logging, try to play the file, find the ffmpeg command used for the transcode in the log and try to run that manually. then add the rusulting file into serviio library and try playing it natively.
RamKat
Post Sat Mar 26, 2011 3:55 pm
UPDATED:
Thank you for the quick response zip - much appreciated.
I enabled DEBUG in the logging.
I removed forceVTranscoding="true"
Without it, the file does not play, here is what I believe the important part of the log file is without forceVTranscoding="true"
2011-03-26 10:57:31,329 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: C:\Users\Public\Videos\MCEBuddy Conversions\Original\WTV.wtv
2011-03-26 10:57:31,330 DEBUG [ProcessExecutor] Starting C:\Program Files (x86)\Serviio\bin\\..\lib/ffmpeg.exe -i C:\Users\Public\Videos\MCEBuddy Conversions\Original\WTV.wtv -y -vcodec copy -acodec copy -map 0:2 -map 0:1 -sn -f mpegts C:\Windows\TEMP\Serviio\transcoding-temp-714-MPEG2TS.stf
2011-03-26 10:57:31,447 WARN  [ProcessExecutor] Process C:\Program Files (x86)\Serviio\bin\\..\lib/ffmpeg.exe has a return code of 1! This is a possible error.
2011-03-26 10:57:31,448 DEBUG [TranscodingJobListener] Transcoding finished; successful: false
2011-03-26 10:57:31,831 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
   at org.serviio.delivery.resource.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:116)
   at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:89)
   at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:116)
   at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:130)
   at org.serviio.upnp.webserver.AbstractRequestHandler.handle(AbstractRequestHandler.java:58)
2011-03-26 10:57:31,848 DEBUG [WebServer] Incoming connection from /192.168.2.22:35304
2011-03-26 10:57:31,848 DEBUG [ResourceTransportRequestHandler] HEAD /resource/714/MEDIA_ITEM/MPEG_TS_SD_KO_ISO$0 HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,Host: 192.168.2.13:8895]]
2011-03-26 10:57:31,849 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.22
2011-03-26 10:57:31,849 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.2.22, Profile=Samsung TV / player (C-series)'
2011-03-26 10:57:31,850 DEBUG [ResourceTransportRequestHandler] Request for resource 714 and type 'MEDIA_ITEM' received
2011-03-26 10:57:31,850 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 714)
2011-03-26 10:57:31,851 DEBUG [VideoDAOImpl] Reading a Video (id = 714)
2011-03-26 10:57:31,851 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 714, format MPEG_TS_SD_KO_ISO and profile Samsung TV / player (C-series)
2011-03-26 10:57:31,851 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file WTV.wtv
2011-03-26 10:57:31,852 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file WTV.wtv: MPEG_TS_SD_EU_ISO
2011-03-26 10:57:31,852 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file WTV.wtv: MPEG_TS_SD_NA_ISO
2011-03-26 10:57:31,852 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file WTV.wtv: MPEG_TS_SD_KO_ISO
2011-03-26 10:57:31,852 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2011-03-26 10:57:31,852 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 9000000000,Date: Sat, 26 Mar 2011 14:57:31 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-03-26 10:57:31,862 DEBUG [WebServer] Incoming connection from /192.168.2.22:46632
2011-03-26 10:57:31,862 DEBUG [ResourceTransportRequestHandler] GET /resource/714/MEDIA_ITEM/MPEG_TS_SD_KO_ISO$0 HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,getMediaInfo.sec: 1,TimeSeekRange.dlna.org: npt=0-,Host: 192.168.2.13:8895]]
2011-03-26 10:57:31,863 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.22
2011-03-26 10:57:31,863 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.2.22, Profile=Samsung TV / player (C-series)'
2011-03-26 10:57:31,864 DEBUG [ResourceTransportRequestHandler] Request for resource 714 and type 'MEDIA_ITEM' received
2011-03-26 10:57:31,864 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 714)
2011-03-26 10:57:31,864 DEBUG [VideoDAOImpl] Reading a Video (id = 714)
2011-03-26 10:57:31,865 DEBUG [VideoDeliveryEngine] Delivering item '714' for client 'IPAddress=/192.168.2.22, Profile=Samsung TV / player (C-series)'
2011-03-26 10:57:31,865 DEBUG [VideoDeliveryEngine] Delivering file 'WTV.wtv' using transcoding
2011-03-26 10:57:31,866 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.2.22, Profile=Samsung TV / player (C-series)'
2011-03-26 10:57:31,866 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
After adding forceVTranscoding="true" back, I tried it again
At the bottom of the post is the resulting log file - I hit the "play" button 11:09:30.
I believe you are referring to this command in the log file at the end of the post
ffmpeg.exe -i C:\Users\Public\Videos\MCEBuddy Conversions\Original\WTV.wtv -y -vcodec mpeg2video -sameq -r 29.97 -g 15 -acodec copy -map 0:2 -map 0:1 -sn -f mpegts C:\Windows\TEMP\Serviio\transcoding-temp-714-MPEG2TS.stf
I ran the above manually (had to move the .wtv file to a different directory)
I moved the resulting .stf file to my video library. Windows do see it as a video file (after changing the extention to .avi) and could play it. It also plays natively with serviio and it does play a lot better but still stutters, but less. I noticed that the dos logging mentions bit rates of 50mb/s - that sounds a tad hi and that maybe the issue
thanks
2011-03-26 11:09:30,995 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:05
2011-03-26 11:09:31,128 DEBUG [WebServer] Incoming connection from /192.168.2.22:53855
2011-03-26 11:09:31,128 DEBUG [ResourceTransportRequestHandler] HEAD /resource/714/MEDIA_ITEM/MPEG_TS_SD_KO_ISO$0 HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,Host: 192.168.2.13:8895]]
2011-03-26 11:09:31,129 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.22
2011-03-26 11:09:31,130 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.2.22, Profile=Samsung TV / player (C-series)'
2011-03-26 11:09:31,130 DEBUG [ResourceTransportRequestHandler] Request for resource 714 and type 'MEDIA_ITEM' received
2011-03-26 11:09:31,130 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 714)
2011-03-26 11:09:31,131 DEBUG [VideoDAOImpl] Reading a Video (id = 714)
2011-03-26 11:09:31,132 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 714, format MPEG_TS_SD_KO_ISO and profile Samsung TV / player (C-series)
2011-03-26 11:09:31,132 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file WTV.wtv
2011-03-26 11:09:31,132 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file WTV.wtv: MPEG_TS_SD_EU_ISO
2011-03-26 11:09:31,132 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file WTV.wtv: MPEG_TS_SD_NA_ISO
2011-03-26 11:09:31,132 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file WTV.wtv: MPEG_TS_SD_KO_ISO
2011-03-26 11:09:31,133 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2011-03-26 11:09:31,133 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 9000000000,Date: Sat, 26 Mar 2011 15:09:31 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-03-26 11:09:31,153 DEBUG [WebServer] Incoming connection from /192.168.2.22:51354
2011-03-26 11:09:31,153 DEBUG [ResourceTransportRequestHandler] GET /resource/714/MEDIA_ITEM/MPEG_TS_SD_KO_ISO$0 HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,getMediaInfo.sec: 1,TimeSeekRange.dlna.org: npt=0-,Host: 192.168.2.13:8895]]
2011-03-26 11:09:31,153 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.22
2011-03-26 11:09:31,154 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.2.22, Profile=Samsung TV / player (C-series)'
2011-03-26 11:09:31,155 DEBUG [ResourceTransportRequestHandler] Request for resource 714 and type 'MEDIA_ITEM' received
2011-03-26 11:09:31,155 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 714)
2011-03-26 11:09:31,155 DEBUG [VideoDAOImpl] Reading a Video (id = 714)
2011-03-26 11:09:31,156 DEBUG [VideoDeliveryEngine] Delivering item '714' for client 'IPAddress=/192.168.2.22, Profile=Samsung TV / player (C-series)'
2011-03-26 11:09:31,156 DEBUG [VideoDeliveryEngine] Delivering file 'WTV.wtv' using transcoding
2011-03-26 11:09:31,157 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/192.168.2.22, Profile=Samsung TV / player (C-series)'
2011-03-26 11:09:31,158 DEBUG [MediaItemDAOImpl] Getting file of media item 714
2011-03-26 11:09:31,160 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: C:\Users\Public\Videos\MCEBuddy Conversions\Original\WTV.wtv
2011-03-26 11:09:31,160 DEBUG [ProcessExecutor] Starting C:\Program Files (x86)\Serviio\bin\\..\lib/ffmpeg.exe -i C:\Users\Public\Videos\MCEBuddy Conversions\Original\WTV.wtv -y -vcodec mpeg2video -sameq -r 29.97 -g 15 -acodec copy -map 0:2 -map 0:1 -sn -f mpegts C:\Windows\TEMP\Serviio\transcoding-temp-714-MPEG2TS.stf
2011-03-26 11:09:31,660 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file WTV.wtv: MPEG_TS_SD_EU_ISO
2011-03-26 11:09:31,660 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file WTV.wtv: MPEG_TS_SD_NA_ISO
2011-03-26 11:09:31,660 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file WTV.wtv: MPEG_TS_SD_KO_ISO
2011-03-26 11:09:31,660 DEBUG [AbstractTranscodingDeliveryEngine] Sending transcoding stream
2011-03-26 11:09:31,661 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 714) as read
2011-03-26 11:09:31,671 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2011-03-26 11:09:31,671 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 9000000000
2011-03-26 11:09:31,671 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-03-26 11:09:31,672 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,TimeSeekRange.dlna.org: npt=0.0-318.0/318,Content-Length: 9000000000,Date: Sat, 26 Mar 2011 15:09:31 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,MediaInfo.sec: SEC_Duration=318000;]]
2011-03-26 11:09:33,088 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2011-03-26 11:09:33,090 DEBUG [WebServer] Incoming connection from /192.168.2.22:46647
2011-03-26 11:09:33,090 DEBUG [ResourceTransportRequestHandler] HEAD /resource/714/MEDIA_ITEM/MPEG_TS_SD_KO_ISO$0 HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,Host: 192.168.2.13:8895]]
2011-03-26 11:09:33,091 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.22
2011-03-26 11:09:33,091 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.2.22, Profile=Samsung TV / player (C-series)'
2011-03-26 11:09:33,091 DEBUG [ResourceTransportRequestHandler] Request for resource 714 and type 'MEDIA_ITEM' received
2011-03-26 11:09:33,092 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 714)
2011-03-26 11:09:33,092 DEBUG [VideoDAOImpl] Reading a Video (id = 714)
2011-03-26 11:09:33,093 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 714, format MPEG_TS_SD_KO_ISO and profile Samsung TV / player (C-series)
2011-03-26 11:09:33,093 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file WTV.wtv
2011-03-26 11:09:33,093 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file WTV.wtv: MPEG_TS_SD_EU_ISO
2011-03-26 11:09:33,093 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file WTV.wtv: MPEG_TS_SD_NA_ISO
2011-03-26 11:09:33,093 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file WTV.wtv: MPEG_TS_SD_KO_ISO
2011-03-26 11:09:33,093 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2011-03-26 11:09:33,093 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 9000000000,Date: Sat, 26 Mar 2011 15:09:33 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-03-26 11:09:33,099 DEBUG [WebServer] Incoming connection from /192.168.2.22:53244
2011-03-26 11:09:33,100 DEBUG [ResourceTransportRequestHandler] GET /resource/714/MEDIA_ITEM/MPEG_TS_SD_KO_ISO$0 HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,getMediaInfo.sec: 1,TimeSeekRange.dlna.org: npt=0-,Host: 192.168.2.13:8895]]
2011-03-26 11:09:33,100 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.22
2011-03-26 11:09:33,100 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.2.22, Profile=Samsung TV / player (C-series)'
2011-03-26 11:09:33,101 DEBUG [ResourceTransportRequestHandler] Request for resource 714 and type 'MEDIA_ITEM' received
2011-03-26 11:09:33,101 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 714)
2011-03-26 11:09:33,101 DEBUG [VideoDAOImpl] Reading a Video (id = 714)
2011-03-26 11:09:33,102 DEBUG [VideoDeliveryEngine] Delivering item '714' for client 'IPAddress=/192.168.2.22, Profile=Samsung TV / player (C-series)'
2011-03-26 11:09:33,102 DEBUG [VideoDeliveryEngine] Delivering file 'WTV.wtv' using transcoding
2011-03-26 11:09:33,102 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.2.22, Profile=Samsung TV / player (C-series)'
2011-03-26 11:09:33,102 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file WTV.wtv: MPEG_TS_SD_EU_ISO
2011-03-26 11:09:33,102 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file WTV.wtv: MPEG_TS_SD_NA_ISO
2011-03-26 11:09:33,102 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file WTV.wtv: MPEG_TS_SD_KO_ISO
2011-03-26 11:09:33,102 DEBUG [AbstractTranscodingDeliveryEngine] Sending transcoding stream
2011-03-26 11:09:33,103 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 714) as read
2011-03-26 11:09:33,104 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2011-03-26 11:09:33,104 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 9000000000
2011-03-26 11:09:33,104 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-03-26 11:09:33,104 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,TimeSeekRange.dlna.org: npt=0.0-318.0/318,Content-Length: 9000000000,Date: Sat, 26 Mar 2011 15:09:33 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,MediaInfo.sec: SEC_Duration=318000;]]
2011-03-26 11:09:33,116 DEBUG [WebServer] Incoming connection from /192.168.2.22:49370
2011-03-26 11:09:33,117 DEBUG [ResourceTransportRequestHandler] HEAD /resource/714/MEDIA_ITEM/MPEG_TS_SD_KO_ISO$0 HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2011-03-26 11:09:33,117 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.22
2011-03-26 11:09:33,118 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.2.22, Profile=Samsung TV / player (C-series)'
2011-03-26 11:09:33,119 DEBUG [ResourceTransportRequestHandler] Request for resource 714 and type 'MEDIA_ITEM' received
2011-03-26 11:09:33,119 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 714)
2011-03-26 11:09:33,120 DEBUG [VideoDAOImpl] Reading a Video (id = 714)
2011-03-26 11:09:33,121 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 714, format MPEG_TS_SD_KO_ISO and profile Samsung TV / player (C-series)
2011-03-26 11:09:33,121 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file WTV.wtv
2011-03-26 11:09:33,121 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file WTV.wtv: MPEG_TS_SD_EU_ISO
2011-03-26 11:09:33,121 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file WTV.wtv: MPEG_TS_SD_NA_ISO
2011-03-26 11:09:33,121 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file WTV.wtv: MPEG_TS_SD_KO_ISO
2011-03-26 11:09:33,121 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 714)
2011-03-26 11:09:33,122 DEBUG [MediaItemDAOImpl] Getting file of media item 714
2011-03-26 11:09:33,123 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2011-03-26 11:09:33,123 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 9000000000,Date: Sat, 26 Mar 2011 15:09:33 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.1,Cache-control: no-cache,transferMode.dlna.org: Streaming,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000]]
2011-03-26 11:09:33,951 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2011-03-26 11:09:33,953 DEBUG [WebServer] Incoming connection from /192.168.2.22:36852
2011-03-26 11:09:33,953 DEBUG [ResourceTransportRequestHandler] GET /resource/714/MEDIA_ITEM/MPEG_TS_SD_KO_ISO$0 HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,TimeSeekRange.dlna.org: npt=0-,Host: 192.168.2.13:8895]]
2011-03-26 11:09:33,953 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.22
2011-03-26 11:09:33,954 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.2.22, Profile=Samsung TV / player (C-series)'
2011-03-26 11:09:33,954 DEBUG [ResourceTransportRequestHandler] Request for resource 714 and type 'MEDIA_ITEM' received
2011-03-26 11:09:33,954 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 714)
2011-03-26 11:09:33,955 DEBUG [VideoDAOImpl] Reading a Video (id = 714)
2011-03-26 11:09:33,955 DEBUG [VideoDeliveryEngine] Delivering item '714' for client 'IPAddress=/192.168.2.22, Profile=Samsung TV / player (C-series)'
2011-03-26 11:09:33,955 DEBUG [VideoDeliveryEngine] Delivering file 'WTV.wtv' using transcoding
2011-03-26 11:09:33,956 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.2.22, Profile=Samsung TV / player (C-series)'
2011-03-26 11:09:33,956 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file WTV.wtv: MPEG_TS_SD_EU_ISO
2011-03-26 11:09:33,956 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file WTV.wtv: MPEG_TS_SD_NA_ISO
2011-03-26 11:09:33,956 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file WTV.wtv: MPEG_TS_SD_KO_ISO
2011-03-26 11:09:33,956 DEBUG [AbstractTranscodingDeliveryEngine] Sending transcoding stream
2011-03-26 11:09:33,956 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 714) as read
2011-03-26 11:09:33,958 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2011-03-26 11:09:33,958 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 9000000000
2011-03-26 11:09:33,958 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-03-26 11:09:33,958 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,TimeSeekRange.dlna.org: npt=0.0-318.0/318,Content-Length: 9000000000,Date: Sat, 26 Mar 2011 15:09:33 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-03-26 11:09:34,561 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.2.13:51998
2011-03-26 11:09:37,561 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.2.13:51998
2011-03-26 11:09:40,561 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.2.13:51998
2011-03-26 11:09:43,577 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.2.13:51998
2011-03-26 11:09:44,104 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:84468511-c582-35ee-8a2b-b9fb199d4b80 from address /192.168.2.22:1025
2011-03-26 11:09:44,105 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.2.22:1025
2011-03-26 11:09:44,405 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:84468511-c582-35ee-8a2b-b9fb199d4b80 from address /192.168.2.22:1025
2011-03-26 11:09:44,405 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.2.22:1025
2011-03-26 11:09:44,705 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:84468511-c582-35ee-8a2b-b9fb199d4b80 from address /192.168.2.22:1025
2011-03-26 11:09:44,705 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.2.22:1025
2011-03-26 11:09:46,577 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.2.13:51998
2011-03-26 11:09:49,578 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.2.13:51998
2011-03-26 11:09:55,104 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:84468511-c582-35ee-8a2b-b9fb199d4b80 from address /192.168.2.22:1025
2011-03-26 11:09:55,105 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.2.22:1025
2011-03-26 11:09:55,404 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:84468511-c582-35ee-8a2b-b9fb199d4b80 from address /192.168.2.22:1025
2011-03-26 11:09:55,405 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.2.22:1025
2011-03-26 11:09:55,705 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:84468511-c582-35ee-8a2b-b9fb199d4b80 from address /192.168.2.22:1025
2011-03-26 11:09:55,705 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.2.22:1025
2011-03-26 11:09:57,622 DEBUG [WebServer] Incoming connection from /192.168.2.22:35534
2011-03-26 11:09:57,623 DEBUG [ResourceTransportRequestHandler] HEAD /resource/714/MEDIA_ITEM/MPEG_TS_SD_KO_ISO$0 HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2011-03-26 11:09:57,623 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.22
2011-03-26 11:09:57,624 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.2.22, Profile=Samsung TV / player (C-series)'
2011-03-26 11:09:57,624 DEBUG [ResourceTransportRequestHandler] Request for resource 714 and type 'MEDIA_ITEM' received
2011-03-26 11:09:57,624 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 714)
2011-03-26 11:09:57,625 DEBUG [VideoDAOImpl] Reading a Video (id = 714)
2011-03-26 11:09:57,626 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 714, format MPEG_TS_SD_KO_ISO and profile Samsung TV / player (C-series)
2011-03-26 11:09:57,626 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file WTV.wtv
2011-03-26 11:09:57,626 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file WTV.wtv: MPEG_TS_SD_EU_ISO
2011-03-26 11:09:57,626 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file WTV.wtv: MPEG_TS_SD_NA_ISO
2011-03-26 11:09:57,626 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file WTV.wtv: MPEG_TS_SD_KO_ISO
2011-03-26 11:09:57,626 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 714)
2011-03-26 11:09:57,627 DEBUG [MediaItemDAOImpl] Getting file of media item 714
2011-03-26 11:09:57,628 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2011-03-26 11:09:57,628 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 9000000000,Date: Sat, 26 Mar 2011 15:09:57 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.1,Cache-control: no-cache,transferMode.dlna.org: Streaming,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000]]
2011-03-26 11:09:57,986 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2011-03-26 11:09:58,717 DEBUG [WebServer] Incoming connection from /192.168.2.22:58772
2011-03-26 11:09:58,718 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"' from 192.168.2.22:
2011-03-26 11:09:58,718 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.22
2011-03-26 11:09:58,723 DEBUG [ServiceControlRequestHandler] Returning error SOAP message
2011-03-26 11:09:59,263 DEBUG [WebServer] Incoming connection from /192.168.2.22:42775
2011-03-26 11:09:59,263 DEBUG [ResourceTransportRequestHandler] GET /resource/792/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.2.13:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2011-03-26 11:09:59,264 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.22
2011-03-26 11:09:59,264 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.2.22, Profile=Samsung TV / player (C-series)'
2011-03-26 11:09:59,264 DEBUG [ResourceTransportRequestHandler] Request for resource 792 and type 'COVER_IMAGE' received
2011-03-26 11:09:59,264 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 792)
2011-03-26 11:09:59,265 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 792
2011-03-26 11:09:59,266 DEBUG [ResourceTransportRequestHandler] Entity will be consumed till the end
2011-03-26 11:09:59,266 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: -1
2011-03-26 11:09:59,266 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-03-26 11:09:59,266 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Date: Sat, 26 Mar 2011 15:09:59 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive]]
2011-03-26 11:10:04,103 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:d1fc93c9-dfe6-4aad-bddb-0645ca5fd9ea from address /192.168.2.22:1025
2011-03-26 11:10:04,405 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:d1fc93c9-dfe6-4aad-bddb-0645ca5fd9ea from address /192.168.2.22:1025
2011-03-26 11:10:04,705 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:d1fc93c9-dfe6-4aad-bddb-0645ca5fd9ea from address /192.168.2.22:1025
2011-03-26 11:10:06,104 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:84468511-c582-35ee-8a2b-b9fb199d4b80 from address /192.168.2.22:1026
2011-03-26 11:10:06,104 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.2.22:1026
2011-03-26 11:10:06,404 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:84468511-c582-35ee-8a2b-b9fb199d4b80 from address /192.168.2.22:1026
2011-03-26 11:10:06,405 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.2.22:1026
2011-03-26 11:10:06,704 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:84468511-c582-35ee-8a2b-b9fb199d4b80 from address /192.168.2.22:1026
2011-03-26 11:10:06,705 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.2.22:1026
thanks again
RamKat
Post Sat Mar 26, 2011 10:33 pm
Problem solved :D
Replaced "mpegts" in the targetcontainer field with "mpeg". No need for forceVTranscoding="true"
Will have to run a few more files to ensure that this is the solution.
UPDATE: Looks like this solved the problem 99% - althought I have also experienced limited stutter with longer videos I believe it has to do with my PC that does other tasks. Will have to at least disable sleep or shut down.
