Vizio M55-E0 not showing up in Connected Device list
JtruzmaH
Post Tue Feb 13, 2018 6:48 am
I just purchased a new Vizio M55-E0, connected everything just like my old TV. Fired up the internet and ran Serviio. It doesn’t show up in CONNECTED DEVICES list. I keep hitting the little refresh button but nothing. The new tv shows up in my network devices on my PC. My Chromecast works fine from my PC to the new TV. Plex runs without a problem as well. What am I missing here with Serviio? I really like this 4K TV but without Serviio working, it loses a lot of its appeal for me because I stream a lot of content. I am running Windows 10 and I’ve checked all my connections. Everything is running on the same network. I have an Ethernet cable from my PC to the router and another Ethernet cable from my tv to the router. That’s how I had it setup previously with my Samsung and had no problems with Serviio. Any ideas would be appreciated!
Post Tue Feb 13, 2018 10:51 am
Re: Vizio M55-E0 not showing up in Connected Device list
JtruzmaH
Post Wed Feb 14, 2018 2:26 am
Sorry about that, please let me know if this is enough or if you need more.
2018-02-13 17:47:58,831 WARN [MultiCastUtils] Host IP address 10.0.0.185 is not available, will try again 9 times
2018-02-13 17:48:03,887 WARN [MultiCastUtils] Host IP address 10.0.0.185 is not available, will try again 8 times
2018-02-13 17:48:08,931 WARN [MultiCastUtils] Host IP address 10.0.0.185 is not available, will try again 7 times
2018-02-13 17:48:13,974 WARN [MultiCastUtils] Host IP address 10.0.0.185 is not available, will try again 6 times
2018-02-13 17:48:18,540 WARN [MultiCastUtils] Host IP address 10.0.0.185 is not available, will try again 9 times
2018-02-13 17:48:19,009 WARN [MultiCastUtils] Host IP address 10.0.0.185 is not available, will try again 5 times
2018-02-13 17:48:23,572 WARN [MultiCastUtils] Host IP address 10.0.0.185 is not available, will try again 8 times
2018-02-13 17:48:24,041 WARN [MultiCastUtils] Host IP address 10.0.0.185 is not available, will try again 4 times
2018-02-13 17:48:28,630 WARN [MultiCastUtils] Host IP address 10.0.0.185 is not available, will try again 7 times
2018-02-13 17:48:29,084 WARN [MultiCastUtils] Host IP address 10.0.0.185 is not available, will try again 3 times
2018-02-13 17:48:33,678 WARN [MultiCastUtils] Host IP address 10.0.0.185 is not available, will try again 6 times
2018-02-13 17:48:34,131 WARN [MultiCastUtils] Host IP address 10.0.0.185 is not available, will try again 2 times
2018-02-13 17:48:38,725 WARN [MultiCastUtils] Host IP address 10.0.0.185 is not available, will try again 5 times
2018-02-13 17:48:39,162 WARN [MultiCastUtils] Host IP address 10.0.0.185 is not available, will try again 1 times
2018-02-13 17:48:43,757 WARN [MultiCastUtils] Host IP address 10.0.0.185 is not available, will try again 4 times
2018-02-13 17:48:44,210 WARN [RendererSearchSender] Cannot acquire NIC for current bound IP address 10.0.0.185, will re-acquire new IP
2018-02-13 17:48:44,210 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2018-02-13 17:48:44,210 INFO [EventDispatcher] Leaving EventDispatcher
2018-02-13 17:48:44,210 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2018-02-13 17:48:44,241 WARN [MultiCastUtils] Host IP address 10.0.0.185 is not available, will try again 3 times
2018-02-13 17:48:44,241 WARN [MultiCastUtils] Could not find NIC with name 'eth4-0'
2018-02-13 17:48:44,241 WARN [LocalAddressResolverStrategy] Haven't found IP address for NIC eth4-0, will try again 9 times
2018-02-13 17:48:49,288 WARN [MultiCastUtils] Host IP address 10.0.0.185 is not available, will try again 2 times
2018-02-13 17:48:49,288 WARN [MultiCastUtils] Could not find NIC with name 'eth4-0'
2018-02-13 17:48:49,288 WARN [LocalAddressResolverStrategy] Haven't found IP address for NIC eth4-0, will try again 8 times
2018-02-13 17:48:54,338 WARN [MultiCastUtils] Host IP address 10.0.0.185 is not available, will try again 1 times
2018-02-13 17:48:54,338 WARN [MultiCastUtils] Could not find NIC with name 'eth4-0'
2018-02-13 17:48:54,338 WARN [LocalAddressResolverStrategy] Haven't found IP address for NIC eth4-0, will try again 7 times
2018-02-13 17:48:59,385 WARN [DiscoveryAdvertisementNotifier] Cannot acquire NIC for current bound IP address 10.0.0.185, will re-acquire new IP
2018-02-13 17:48:59,385 WARN [MultiCastUtils] Could not find NIC with name 'eth4-0'
2018-02-13 17:48:59,385 WARN [LocalAddressResolverStrategy] Haven't found IP address for NIC eth4-0, will try again 6 times
2018-02-13 17:48:59,416 WARN [MultiCastUtils] Could not find NIC with name 'eth4-0'
2018-02-13 17:48:59,416 WARN [LocalAddressResolverStrategy] Haven't found IP address for NIC eth4-0, will try again 9 times
2018-02-13 17:48:59,432 WARN [MultiCastUtils] Could not find NIC with name 'eth4-0'
2018-02-13 17:48:59,432 WARN [LocalAddressResolverStrategy] Haven't found IP address for NIC eth4-0, will try again 8 times
2018-02-13 17:49:04,432 WARN [MultiCastUtils] Could not find NIC with name 'eth4-0'
2018-02-13 17:49:04,432 WARN [LocalAddressResolverStrategy] Haven't found IP address for NIC eth4-0, will try again 5 times
2018-02-13 17:49:04,448 WARN [MultiCastUtils] Could not find NIC with name 'eth4-0'
2018-02-13 17:49:04,448 WARN [LocalAddressResolverStrategy] Haven't found IP address for NIC eth4-0, will try again 7 times
2018-02-13 17:49:09,479 WARN [MultiCastUtils] Could not find NIC with name 'eth4-0'
2018-02-13 17:49:09,479 WARN [LocalAddressResolverStrategy] Haven't found IP address for NIC eth4-0, will try again 4 times
2018-02-13 17:49:09,479 WARN [LocalAddressResolverStrategy] Haven't found IP address for NIC eth4-0, will try again 6 times
2018-02-13 17:49:14,527 WARN [MultiCastUtils] Could not find NIC with name 'eth4-0'
2018-02-13 17:49:14,527 WARN [LocalAddressResolverStrategy] Haven't found IP address for NIC eth4-0, will try again 5 times
2018-02-13 17:49:14,527 WARN [LocalAddressResolverStrategy] Haven't found IP address for NIC eth4-0, will try again 3 times
2018-02-13 17:49:19,576 WARN [MultiCastUtils] Could not find NIC with name 'eth4-0'
2018-02-13 17:49:19,576 WARN [LocalAddressResolverStrategy] Haven't found IP address for NIC eth4-0, will try again 2 times
2018-02-13 17:49:19,576 WARN [LocalAddressResolverStrategy] Haven't found IP address for NIC eth4-0, will try again 4 times
2018-02-13 17:49:24,623 WARN [MultiCastUtils] Could not find NIC with name 'eth4-0'
2018-02-13 17:49:24,623 WARN [LocalAddressResolverStrategy] Haven't found IP address for NIC eth4-0, will try again 3 times
2018-02-13 17:49:24,623 WARN [LocalAddressResolverStrategy] Haven't found IP address for NIC eth4-0, will try again 1 times
2018-02-13 17:49:29,670 INFO [Device] Updated bound IP address of Device with UUID: 932f708c-66cb-30e2-8655-e8cdd5873d15, bound address: 10.0.0.185
2018-02-13 17:49:29,670 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2018-02-13 17:49:29,670 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2018-02-13 17:49:29,670 INFO [EventDispatcher] Starting EventDispatcher
2018-02-13 17:49:29,676 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2018-02-13 17:49:29,676 INFO [EventDispatcher] Starting EventDispatcher
2018-02-13 17:49:29,676 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2018-02-13 17:49:29,695 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth4 (Killer e2200 Gigabit Ethernet Controller) and address 10.0.0.185, timeout = 0
2018-02-13 18:06:52,140 INFO [UserDataUpdater] Updating user data
2018-02-13 18:06:52,515 INFO [PortMappingChecker] Running a check for external mapping of port 23524 on '73.96.88.67'
2018-02-13 18:07:12,678 WARN [UserDataUpdater] There was an error updating user data
java.net.SocketTimeoutException: connect timed out
at java.net.TwoStacksPlainSocketImpl.socketConnect(Native Method)
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:172)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
at java.net.Socket.connect(Socket.java:589)
at sun.net.NetworkClient.doConnect(NetworkClient.java:175)
at sun.net.www.http.HttpClient.openServer(HttpClient.java:463)
at sun.net.www.http.HttpClient.openServer(HttpClient.java:558)
at sun.net.www.http.HttpClient.<init>(HttpClient.java:242)
at sun.net.www.http.HttpClient.New(HttpClient.java:339)
at sun.net.www.http.HttpClient.New(HttpClient.java:357)
at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(HttpURLConnection.java:1202)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect0(HttpURLConnection.java:1138)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:1032)
at sun.net.www.protocol.http.HttpURLConnection.connect(HttpURLConnection.java:966)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1546)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1474)
at java.net.HttpURLConnection.getResponseCode(HttpURLConnection.java:480)
at org.serviio.util.HttpClient.retrieveStreamFromConnection(HttpClient.java:173)
at org.serviio.util.HttpClient.getStreamFromURL(HttpClient.java:103)
at org.serviio.util.HttpClient.retrieveTextFileFromURL(HttpClient.java:42)
at org.serviio.upnp.service.contentdirectory.rest.access.TuqPortCheckerProvider.isPortOpen(TuqPortCheckerProvider.java:20)
at org.serviio.upnp.service.contentdirectory.rest.access.PortMappingChecker.isPortOpen(PortMappingChecker.java:39)
at org.serviio.upnp.service.contentdirectory.rest.access.UserDataUpdater.isSSLPortOpen(UserDataUpdater.java:178)
at org.serviio.upnp.service.contentdirectory.rest.access.UserDataUpdater.doUpdateUserData(UserDataUpdater.java:101)
at org.serviio.upnp.service.contentdirectory.rest.access.UserDataUpdater.access$200(UserDataUpdater.java:32)
at org.serviio.upnp.service.contentdirectory.rest.access.UserDataUpdater$UserDataUpdaterRunner.run(UserDataUpdater.java:193)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:748)
2018-02-13 18:15:56,300 INFO [AbstractAVTranscodingDeliveryEngine] Cleaning transcode engine and its data
2018-02-13 18:15:56,300 INFO [WebServer] WebServer shutting down
2018-02-13 18:15:56,300 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2018-02-13 18:15:56,300 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2018-02-13 18:15:56,300 INFO [EventDispatcher] Leaving EventDispatcher
2018-02-13 18:15:56,300 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2018-02-13 18:15:56,321 INFO [WebServer] WebServer starting on port 8895
2018-02-13 18:15:56,340 INFO [Device] Updated bound IP address of Device with UUID: 932f708c-66cb-30e2-8655-e8cdd5873d15, bound address: 10.0.0.185
2018-02-13 18:15:56,340 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2018-02-13 18:15:56,340 INFO [EventDispatcher] Starting EventDispatcher
2018-02-13 18:15:56,340 INFO [RendererSearchSender] Starting Renderer searcher process
2018-02-13 18:15:56,340 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2018-02-13 18:15:56,360 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth4 (Killer e2200 Gigabit Ethernet Controller) and address 10.0.0.185, timeout = 0
2018-02-13 18:15:56,378 INFO [EventDispatcher] Leaving EventDispatcher
2018-02-13 18:15:57,871 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2018-02-13 18:16:06,489 INFO [AbstractAVTranscodingDeliveryEngine] Cleaning transcode engine and its data
2018-02-13 18:16:06,489 INFO [WebServer] WebServer shutting down
2018-02-13 18:16:06,490 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2018-02-13 18:16:06,490 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2018-02-13 18:16:06,490 INFO [EventDispatcher] Leaving EventDispatcher
2018-02-13 18:16:07,623 INFO [WebServer] WebServer starting on port 8895
2018-02-13 18:16:07,645 INFO [Device] Updated bound IP address of Device with UUID: 932f708c-66cb-30e2-8655-e8cdd5873d15, bound address: 10.0.0.185
2018-02-13 18:16:07,645 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2018-02-13 18:16:07,645 INFO [RendererSearchSender] Starting Renderer searcher process
2018-02-13 18:16:07,645 INFO [EventDispatcher] Starting EventDispatcher
2018-02-13 18:16:07,645 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2018-02-13 18:16:07,665 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth4 (Killer e2200 Gigabit Ethernet Controller) and address 10.0.0.185, timeout = 0
2018-02-13 18:16:16,424 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2018-02-13 18:16:26,197 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2018-02-13 18:18:01,864 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2018-02-13 18:19:02,694 INFO [AbstractAVTranscodingDeliveryEngine] Cleaning transcode engine and its data
2018-02-13 18:19:02,694 INFO [WebServer] WebServer shutting down
2018-02-13 18:19:02,694 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2018-02-13 18:19:02,695 INFO [EventDispatcher] Leaving EventDispatcher
2018-02-13 18:19:02,695 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2018-02-13 18:19:02,695 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2018-02-13 18:19:07,396 INFO [WebServer] WebServer starting on port 8895
2018-02-13 18:19:07,417 INFO [Device] Updated bound IP address of Device with UUID: 932f708c-66cb-30e2-8655-e8cdd5873d15, bound address: 10.0.0.185
2018-02-13 18:19:07,418 INFO [RendererSearchSender] Starting Renderer searcher process
2018-02-13 18:19:07,418 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2018-02-13 18:19:07,418 INFO [EventDispatcher] Starting EventDispatcher
2018-02-13 18:19:07,418 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2018-02-13 18:19:07,440 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth4 (Killer e2200 Gigabit Ethernet Controller) and address 10.0.0.185, timeout = 0
2018-02-13 18:20:12,060 INFO [AbstractAVTranscodingDeliveryEngine] Cleaning transcode engine and its data
2018-02-13 18:20:12,060 INFO [WebServer] WebServer shutting down
2018-02-13 18:20:12,060 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2018-02-13 18:20:12,060 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2018-02-13 18:20:12,060 INFO [EventDispatcher] Leaving EventDispatcher
2018-02-13 18:20:12,060 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2018-02-13 18:20:13,503 INFO [WebServer] WebServer starting on port 8895
2018-02-13 18:20:13,524 INFO [Device] Updated bound IP address of Device with UUID: 932f708c-66cb-30e2-8655-e8cdd5873d15, bound address: 10.0.0.185
2018-02-13 18:20:13,525 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2018-02-13 18:20:13,525 INFO [RendererSearchSender] Starting Renderer searcher process
2018-02-13 18:20:13,525 INFO [EventDispatcher] Starting EventDispatcher
2018-02-13 18:20:13,525 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2018-02-13 18:20:13,544 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth4 (Killer e2200 Gigabit Ethernet Controller) and address 10.0.0.185, timeout = 0
2018-02-13 18:21:39,252 INFO [AbstractAVTranscodingDeliveryEngine] Cleaning transcode engine and its data
2018-02-13 18:21:39,252 INFO [WebServer] WebServer shutting down
2018-02-13 18:21:39,252 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2018-02-13 18:21:39,253 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2018-02-13 18:21:39,253 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2018-02-13 18:21:39,253 INFO [EventDispatcher] Leaving EventDispatcher
2018-02-13 18:21:39,272 INFO [WebServer] WebServer starting on port 8895
2018-02-13 18:21:39,371 INFO [Device] Updated bound IP address of Device with UUID: 932f708c-66cb-30e2-8655-e8cdd5873d15, bound address: 10.0.0.185
2018-02-13 18:21:39,371 INFO [RendererSearchSender] Starting Renderer searcher process
2018-02-13 18:21:39,371 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2018-02-13 18:21:39,371 INFO [EventDispatcher] Starting EventDispatcher
2018-02-13 18:21:39,371 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2018-02-13 18:21:39,389 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth4 (Killer e2200 Gigabit Ethernet Controller) and address 10.0.0.185, timeout = 0
2018-02-13 18:21:43,326 INFO [AbstractAVTranscodingDeliveryEngine] Cleaning transcode engine and its data
2018-02-13 18:21:43,326 INFO [WebServer] WebServer shutting down
2018-02-13 18:21:43,326 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2018-02-13 18:21:43,327 INFO [EventDispatcher] Leaving EventDispatcher
2018-02-13 18:21:43,327 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2018-02-13 18:21:43,326 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2018-02-13 18:21:44,458 INFO [WebServer] WebServer starting on port 8895
2018-02-13 18:21:44,553 INFO [Device] Updated bound IP address of Device with UUID: 932f708c-66cb-30e2-8655-e8cdd5873d15, bound address: 10.0.0.185
2018-02-13 18:21:44,553 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2018-02-13 18:21:44,553 INFO [RendererSearchSender] Starting Renderer searcher process
2018-02-13 18:21:44,553 INFO [EventDispatcher] Starting EventDispatcher
2018-02-13 18:21:44,553 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2018-02-13 18:21:44,573 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth4 (Killer e2200 Gigabit Ethernet Controller) and address 10.0.0.185, timeout = 0
2018-02-13 18:21:57,474 INFO [AbstractAVTranscodingDeliveryEngine] Cleaning transcode engine and its data
2018-02-13 18:21:57,474 INFO [WebServer] WebServer shutting down
2018-02-13 18:21:57,474 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2018-02-13 18:21:57,475 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2018-02-13 18:21:57,475 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2018-02-13 18:21:57,475 INFO [EventDispatcher] Leaving EventDispatcher
2018-02-13 18:21:57,500 INFO [WebServer] WebServer starting on port 8895
2018-02-13 18:21:57,590 INFO [Device] Updated bound IP address of Device with UUID: 932f708c-66cb-30e2-8655-e8cdd5873d15, bound address: 10.0.0.185
2018-02-13 18:21:57,591 INFO [RendererSearchSender] Starting Renderer searcher process
2018-02-13 18:21:57,591 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2018-02-13 18:21:57,591 INFO [EventDispatcher] Starting EventDispatcher
2018-02-13 18:21:57,591 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2018-02-13 18:21:57,609 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth4 (Killer e2200 Gigabit Ethernet Controller) and address 10.0.0.185, timeout = 0
Post Wed Feb 14, 2018 10:08 am
Did you set a preferred network interface for Serviio? On the Status tab. If yes, it's wrong.
Either set it to Automatic detection, or chose the IP that is available on your network card.
