ALL transcoded videos dissappear from Sony's list
kot
Post Sun Mar 27, 2011 8:17 pm
Hello!
My setup has configured a strange problem recently... After a while, my Sony TV stops listing almost all of the videos. I know, Serviio continues to offer them, because the Serviio->Video->Titles still lists all of the first letters -- but nothing is shown, when I try to dive under any of the letters.
Nothing, except the handful of tape-dumps of our own videos and one DVD-dump... The log-file would be idle, when this happens. Disk-space seems plentiful...
If I go to my computer, bring serviio down, delete the DB-directory, restart it, and recreate the DB, things are fine -- for a while...
I first observed this, with 0.5 (but not immediately upon starting to use it). It was there with 0.5.1. I'm using the old database now with the 0.5.2 and have the same problem. Will go through the motions again (full reindexing takes hours here) and report later, whether the problem shows up again in 0.5.2.
Any ideas?
FreeBSD port of Serviio is now in the tree. Please, try using it and share your experience.
Post Sun Mar 27, 2011 8:35 pm
Re: ALL transcoded videos dissappear from Sony's list
no ideas, man. Unless you can find something dodgy in the log. Is it just transcoded files that disappear? Do you have the TV setup with static address to make sure it still uses the proper (Sony) profile?
kot
Post Mon Mar 28, 2011 3:41 am
zip wrote:Do you have the TV setup with static address to make sure it still uses the proper (Sony) profile?
Yep, this was it... I thought, I have a fixed IP set for the TV's MAC-address, but I did not... Works now. Thanks!
Users browsing this forum: Google [Bot] and 1 guest
