Diffusion on MULTI LAN
futuria
Post Thu Jan 03, 2019 2:26 pm
Hi, i need to diffuse my shared files on 3 differents network but with the same server (My Server got 3 network cards, 1 on each network)
But in the configuration i can only choose one network even if i choose "automaticaly".
So is there any solution to bypass this option and diffuse on all the 3 networks ? (Actually i have KooRaRoo DLNA who doing this... but it's not working as wall as serviio)
Thanks for your help.
Post Thu Jan 03, 2019 10:10 pm
Re: Diffusion on MULTI LAN
no, Serviio is single network only
coredump
Post Tue Feb 12, 2019 7:36 pm
iptables should be able to do the trick of port forwarding, see https://www.systutorials.com/816/port-f ... -iptables/
Post Tue Feb 12, 2019 8:23 pm
As alluded to, you would have to have a router between the three networks with port forwarding configured to permit access to Serviio. As Zip mentioned, Serviio can only bind to a single IP address. Depending on the computer that Serviio is running on, you might be able to configure something internal to the computer to let the other two NICs see the Serviio IP address. IPTABLES is generally used in routers, and may or may not be able to be used within a computer to bridge between the NICs. Of course, this might have unintended consequences if you configure it incorrectly and all traffic can cross between the networks. Routing like this is not for the faint of heart. :D
Users browsing this forum: No registered users and 71 guests
