Serviio ID does not display correctly
I recently updated from 1.6 to 1.10 (yeah, I know, but if it ain't broke, don't fix it) in order to enable the Alexa skill. Since the update I have two problems:
1) On the console page where my Serviio ID should display, it just says "tab_about_pc5dczc_id". So I can't connect to Alexa, because I can't get my ID. (Yes, I am a Pro subscriber)
EDIT: Disregard #2. I think it was just busy rebuilding the library.
Thanks,
Ric
Thanks,
Ric
