Samsung UE48H6400 TV not connecting to Serviio
Sparky
Post Fri Apr 05, 2019 5:29 pm
I don't tend to stream from the TV that often, preferring the interface from the Sony Bluray player. However for some reason I tried it from the TV only to find that the TV will show Serviio as a media server and then gave a "cannot connect" error.
I know it used to work some time ago, but that was several versions ago - back in the v1.5 era. Nothing I do can make it connect and display a menu. I see the logo, select it and get a connection error.
A work colleague suffers in the same way I discovered a few days ago, different TV though. He's still using a version in the 1.3 code stream and it works fine for him.
Any ideas..?
Windows 10 Pro 64-bit, Asus Sabertooth P67, Core i7-2600 3.4GHz, 16Gb DDR3-14900, Nvidia GeForce 8800GT 512Mb, HL-DT-ST GH22LS50, System: Intel SSD 520 Series 240Gb, VM: Intel SSD 330 Series 240Gb, Data: Seagate Barracuda ST31500341AS 1500GB 32Mb Cache, DLNA: Hitachi Deskstar P7K500 320GB 16Mb Cache
Samsung UE48H6400, Sony BDP-S490, PlayStation 3, Xbox 360, Xbox One.
Meelis
Post Fri Apr 05, 2019 9:33 pm
Re: Samsung UE48H6400 TV not connecting to Serviio
Please upgrade to latest versions with clean install.
Uninstall the old version and install the new version.
