Unable to connect to a remote UPNP server
Shele
Post Fri Apr 05, 2019 7:01 am
Hi all
I have a problem with kodi (18.1) and a remote UPNP server (Serviio on a synology NAS)
I have successfully added the source and i can see my video but, after a reboot, if i try to open the source i receive this error: "unable to connect to the server".
If i go in system-->settings-->services-->UPnP/DLNA and disable and enable "Share my livraries" then i can accesso to the remote DLNA server.
This is the first debug log, when i get the error:
15:14:32 T:1833792432   DEBUG: PushCecKeypress - received key  b duration 0
15:14:32 T:1945346624   DEBUG: OnKey: 11 (0x0b) pressed, action is Select
15:14:32 T:1945346624   DEBUG: CGUIMediaWindow::GetDirectory (upnp://223a9375-eb61-3269-abcf-3ad9f2e63b1f/)
15:14:32 T:1945346624   DEBUG:   ParentPath = [sources://video/]
15:14:32 T:1760981936  NOTICE: Thread JobWorker start, auto delete: true
15:14:32 T:1760981936    INFO: Platinum [platinum.media.server.browser]: Device (223a9375-eb61-3269-abcf-3ad9f2e63b1f) not found in our list of servers
15:14:32 T:1945346624   ERROR: GetDirectory - Error getting upnp://223a9375-eb61-3269-abcf-3ad9f2e63b1f/
15:14:32 T:1945346624   ERROR: CGUIMediaWindow::GetDirectory(upnp://223a9375-eb61-3269-abcf-3ad9f2e63b1f/) failed
15:14:32 T:1945346624   DEBUG: CGUIMediaWindow::GetDirectory (sources://video/)
15:14:32 T:1945346624   DEBUG:   ParentPath = []
15:14:32 T:1852830640  NOTICE: Thread BackgroundLoader start, auto delete: false
15:14:32 T:1945346624   DEBUG: ------ Window Init (DialogOK.xml) ------
15:14:32 T:1833792432   DEBUG: PushCecKeypress - received key  b duration 70
15:14:32 T:1852830640   DEBUG: Thread BackgroundLoader 1852830640 terminating
15:14:34 T:1833792432   DEBUG: PushCecKeypress - received key  b duration 0
15:14:34 T:1945346624   DEBUG: OnKey: 11 (0x0b) pressed, action is Select
15:14:34 T:1833792432   DEBUG: PushCecKeypress - received key  b duration 70
15:14:34 T:1945346624   DEBUG: ------ Window Deinit (DialogOK.xml) ------
This is the second debug log, when i can access to the source:
15:16:01 T:1833792432   DEBUG: PushCecKeypress - received key  b duration 0
15:16:01 T:1945346624   DEBUG: OnKey: 11 (0x0b) pressed, action is Select
15:16:01 T:1945346624   DEBUG: CGUIMediaWindow::GetDirectory (upnp://223a9375-eb61-3269-abcf-3ad9f2e63b1f/)
15:16:01 T:1945346624   DEBUG:   ParentPath = [sources://video/]
15:16:01 T:1760981936    INFO: Platinum [neptune.threads.posix]: NPT_PosixThread::NPT_PosixThread
15:16:01 T:1623184304    INFO: Platinum [neptune.http]: requesting URL http://192.168.1.6:8895/serviceControl
15:16:01 T:1623184304    INFO: Platinum [neptune.http]: calling connector (proxy:no) (http 1.1:yes) (url:http://192.168.1.6:8895/serviceControl)
15:16:01 T:1623184304    INFO: Platinum [neptune.tls]: looking for a connection to reuse
15:16:01 T:1623184304    INFO: Platinum [neptune.tls]: reusing connection
15:16:01 T:1623184304    INFO: Platinum [neptune.http]: got connection (reused: true)
15:16:01 T:1623184304    INFO: Platinum [neptune.http]: sending body stream, 949 bytes
15:16:01 T:1623184304    INFO: Platinum [platinum.media.server.didl]: Parsing Didl...
15:16:01 T:1639961520  NOTICE: Thread BackgroundLoader start, auto delete: false
15:16:01 T:1639961520   DEBUG: Thread BackgroundLoader 1639961520 terminating
15:16:01 T:1833792432   DEBUG: PushCecKeypress - received key  b duration 69
this is what appen when i disable and enable "share my libraries"
15:15:27 T:1852830640  NOTICE: Platinum [platinum.core.ctrlpoint]: Inspecting device "223a9375-eb61-3269-abcf-3ad9f2e63b1f" detected @ http://192.168.1.6:8895/deviceDescription/223a9375-eb61-3269-abcf-3ad9f2e63b1f
15:15:27 T:1852830640    INFO: Platinum [neptune.threads.posix]: NPT_PosixThread::NPT_PosixThread
15:15:28 T:1852830640  NOTICE: Platinum [platinum.core.ctrlpoint]: Inspecting device "52554976-3247-5265-6D6F-0019fb33b1f0" detected @ http://192.168.1.102:49153/description0.xml
15:15:28 T:1852830640    INFO: Platinum [neptune.threads.posix]: NPT_PosixThread::NPT_PosixThread
15:15:28 T:1639961520    INFO: Platinum [neptune.http]: requesting URL http://192.168.1.6:8895/deviceDescription/223a9375-eb61-3269-abcf-3ad9f2e63b1f
15:15:28 T:1639961520    INFO: Platinum [neptune.http]: calling connector (proxy:no) (http 1.1:yes) (url:http://192.168.1.6:8895/deviceDescription/223a9375-eb61-3269-abcf-3ad9f2e63b1f)
15:15:28 T:1639961520    INFO: Platinum [neptune.tls]: looking for a connection to reuse
15:15:28 T:1639961520    INFO: Platinum [neptune.tls]: TLS connector will connect to 192.168.1.6:8895
15:15:28 T:1639961520    INFO: Platinum [neptune.http]: got connection (reused: false)
15:15:28 T:1639961520  NOTICE: Platinum [platinum.core.ctrlpoint]: Device "223a9375-eb61-3269-abcf-3ad9f2e63b1f" is now known as "Serviio (DiskStation)" (http://192.168.1.6:8895/deviceDescription/223a9375-eb61-3269-abcf-3ad9f2e63b1f)
15:15:28 T:1639961520    INFO: Platinum [neptune.threads.posix]: NPT_PosixThread::NPT_PosixThread
15:15:28 T:1744204720    INFO: Platinum [neptune.http]: requesting URL http://192.168.1.6:8895/serviceDescription/ConnectionManager
it's a bug?
Meelis
Post Fri Apr 05, 2019 9:45 pm
Re: Unable to connect to a remote UPNP server
Its a question probably to Kodi forum. Use serviio in nas. I have them both actually and they both are working. I would recommend serviio in this situation. Less problems. Kodi is not use serviio server at all. Kodi just reading files from shared folders. There own tricks how to setup it correctly in nas.
Post Fri Apr 05, 2019 10:07 pm
Are you using Kodi as your player connected to a display, or is it acting as a server, and you are connecting to Serviio as a media source? I use Kodi and MrMC (a Kodi fork) on my Shield as a player for accessing Serviio, and have no issues.
My only gripe with Kodi and its various forks is that it ignores the file sort that Serviio offers and instead sorts the media on its own selection. That's fine for the Titles, Movies and Folders presentations, but it's terrible for Last Added and Playlists.
manipathaktech
Post Sun Sep 27, 2026 9:44 am
I had a similar issue with Kodi and a remote Serviio UPnP server. It looks like the UPnP service isn’t reconnecting properly after reboot. Disabling and re-enabling “Share my libraries” forces Kodi to refresh the UPnP connection and fixes it.
