Profile for Panasonic 2018 TV
milansmart
Post Tue Aug 27, 2019 8:15 am
I'm looking for a profile for 2018 Panasonic TV TX-65FX780E. If I use the integrated older Panasonic profile. x265 gets converted and avi doesnt. What I need would be to NOT convert x265 video and convert avi, or DTS sound, because the new TV doesn't support those. Would it be possible to integrate the new Panasonic TV profiles into the Serviio App.
Milan
Post Tue Aug 27, 2019 12:40 pm
Re: Profile for Panasonic 2018 TV
milansmart wrote:Hi,
Milan
I suggest first trying some of the other TV profiles for other brands. The Roku 4K TV might work for you, and I believe there are some other profiles that allow H.265 but transcode AVIs. It's really tough to create a profile when you don't have that TV to test it on, so it you can identify a profile that offers what you need it helps identify the correct transcoding lines.
Post Thu Aug 29, 2019 11:23 am
milansmart
Post Fri Aug 30, 2019 8:52 am
Thanks, I will try that
