Not binding to network adapter.
DaFerociousBeast
Post Wed Aug 21, 2019 5:32 pm
Using Serviio v1.10.1 Pro on Windows 10 Pro.
I have recently installed ProtonVPN, I now have Ethernet & Ethernet 2 listed as network adapters.
Ethernet 2 is the VPN. I tried to bind Serviio to the address of the Ethernet one, which is the IP w/ adapter name.
Whenever I use the VPN, Serviio service stops, and the console says that it is not running. Sometimes I have to
restart Windows in order to get the service to start back up.
ProtonVPN does have the option to only allow/block specific programs/apps from using the VPN.
I've tried both block and allow. Seems as if Serviio doesn't see the difference in network connections, I know that
the VPN is just a virtual adapter, so I don't think Serviio can distinguish between the physical and virtual.
Any help here. Thank You.
DaFerociousBeast
Post Fri Aug 23, 2019 10:51 pm
Re: Not binding to network adapter.
Anyone?
Something?
Post Sun Sep 15, 2019 12:43 pm
Yep, DLNA was never designed with multiple NIC's in mind... try:
  • Start your VPN
  • Ensure that ServiioService.exe is blocked from using the VPN
  • Stop your VPN
  • Bind Serviio to the IP address of your physical adaptor
  • Enable detailed logging and restart your PC
  • After Serviio has started, start your VPN
If this doesn't work (and I suspect that may be the case) post the log file so we can see what is happening.
DaFerociousBeast
Post Wed Sep 18, 2019 4:18 pm
Thanks for help. Problem was in the actual app. Got around it with OpenVPN configs.
Users browsing this forum: Google [Bot] and 71 guests
