Cannot connect to the server, it doesn't seem to be running.
dockelektro
Post Tue Aug 28, 2018 3:26 pm
Re: Cannot connect to the server, it doesn't seem to be runn
Hi, I contacted Bullguard support, and they guided me through it, it seems servioservice.exe was being quarantined and not the other way around. I did two reboots and it seems to be working, I hope this is solved!
Thank you for you replies!
Post Wed Aug 29, 2018 12:13 am
Terrific, thanks for the update. :D
Hales Robert
Post Sat Nov 02, 2019 6:21 am
dockelektro wrote:I think we can assume Bullguard has something to do with it. My Serviio also goes down with every restart. The serviio folder is being ignored by the antivirus and the firewall. Is there a fix to this? Should we contact Bullguard? Does anyone have a suggestion? It pains me to have payed for a license for Serviio and not not being able to use it.
If we focus on Antivirus then we should consider the options with better security features. I have been using Avira and recently i read the comparison between Avast and Malwarebytes 2019 and i found good security options and tools and i wonder which one to choose.
Previous
Users browsing this forum: Google [Bot] and 47 guests
