S370: clean Win7 & serviio won't work
00Fish
Post Tue Apr 05, 2011 6:41 pm
Hallo ladies & gentleman,
i'm using on my first PC an old win7 installation with a lot of installed video software and codecs and serviio 0.5.2. It works really fine with my Sony S370.
Now I have a second PC with a new and clean windows7 Installation, the only video software installed is serviio 0.5.2 . And this won't work. I can see all the video files on my Bluray Player, but i can't start them. I just get a black screen, no error message or something else. The CPU load increases to 40-80%.
In short:
- 2 PC
- both with same security software
- both with serviio0.5.2 (serviio0.5.0 also won't work on new PC)
- same video files (*.mkv)
- PC with "old" win7 works fine
- PC with fresh and clean win7 won't work
- Sony S370 EU profile in use
- User: average gifted
Has anybody an idea to solve my problem? Nearby you'll find a ffmpeg log.
Thanks a lot
686-mingw32-
  libavutil     50.36. 0 / 50.36. 0
  libavcore      0.16. 0 /  0.16. 0
  libavcodec    52.108. 0 / 52.108. 0
  libavformat   52.92. 0 / 52.92. 0
  libavdevice   52. 2. 3 / 52. 2. 3
  libavfilter    1.72. 0 /  1.72. 0
  libswscale     0.12. 0 /  0.12. 0
[matroska,webm @ 0033bb30] max_analyze_duration reached
[matroska,webm @ 0033bb30] Estimating duration from bitrate, this may be inaccur
ate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (48000/
1001) -> 23.98 (48000/2002)
Input #0, matroska,webm, from 'e:\test.mkv':
    title           : Test
  Duration: 01:41:04.60, start: 0.000000, bitrate: 3072 kb/s
    Stream #0.0(ger): Video: h264, yuv420p, 1920x800, PAR 1:1 DAR 12:5, 23.98 fp
s, 23.98 tbr, 1k tbn, 47.95 tbc
      title           : Test
    Stream #0.1(ger): Audio: dca, 48000 Hz, 5.1, s16, 1536 kb/s
      title           : GERMAN - DTS
    Stream #0.2(eng): Audio: dca, 48000 Hz, 5.1, s16, 1536 kb/s
      title           : ENGLISH - DTS
    Stream #0.3(ger): Subtitle: [0][0][0][0] / 0x0000
      title           : GERMAN - FORCED
    Stream #0.4(ger): Subtitle: [0][0][0][0] / 0x0000
      title           : GERMAN - NORMAL
    Stream #0.5(eng): Subtitle: [0][0][0][0] / 0x0000
      title           : ENGLISH - FORCED
    Stream #0.6(eng): Subtitle: [0][0][0][0] / 0x0000
      title           : ENGLISH - NORMAL
Post Tue Apr 05, 2011 7:56 pm
Re: S370: clean Win7 & serviio won't work
What is your Java Version?
Post Tue Apr 05, 2011 10:04 pm
post the (detailed) log
00Fish
Post Tue Apr 12, 2011 6:16 pm
Hallo guys,
sorry for my late answer, but the trouble making PC is my fathers one and I only have limited access to it.
Installed Java:
Java 6 Update 24 (64-bit)
Java SE Development Kit 6 Update 24 (64-bit)
Detailed LogFile is attached.
Thanks for your help
00F
(118.7 KiB) Downloaded 729 times
Post Tue Apr 12, 2011 7:26 pm
Thks,
Sorry, but I see nothing wrong in the log file...
Post Wed Apr 13, 2011 8:29 am
is this the IP of the Serviio machine? 192.168.178.23
