Hisense TV Profile 50A6100UW
strug
Post Sun Jul 19, 2020 9:13 am
Is there any howto for turning the device spy dump into a usable profile?
I have followed instructions 50A6100UW and produced the below file but have no idea how to interpret this in a profile.
Any help will be appreciated
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3;DLNA.ORG_FLAGS=8D100000000000000000000000000000,
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE;DLNA.ORG_FLAGS=8D100000000000000000000000000000,
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAFULL;DLNA.ORG_FLAGS=8D100000000000000000000000000000,
http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS_320;DLNA.ORG_FLAGS=8D100000000000000000000000000000,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN;DLNA.ORG_FLAGS=8C900000000000000000000000000000,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM;DLNA.ORG_FLAGS=8C900000000000000000000000000000,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED;DLNA.ORG_FLAGS=8C900000000000000000000000000000,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG;DLNA.ORG_FLAGS=8C900000000000000000000000000000,
http-get:*:image/gif:*,http-get:*:image/bmp:*,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL;DLNA.ORG_FLAGS=8D100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC;DLNA.ORG_FLAGS=8D100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA;DLNA.ORG_FLAGS=8D100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_T;DLNA.ORG_FLAGS=8D100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_ISO;DLNA.ORG_FLAGS=8D100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_ISO;DLNA.ORG_FLAGS=8D100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO;DLNA.ORG_FLAGS=8D100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_FLAGS=8D100000000000000000000000000000,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVHIGH_FULL;DLNA.ORG_FLAGS=8D100000000000000000000000000000,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVHIGH_PRO;DLNA.ORG_FLAGS=8D100000000000000000000000000000,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_FULL;DLNA.ORG_FLAGS=8D100000000000000000000000000000,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_BASE;DLNA.ORG_FLAGS=8D100000000000000000000000000000,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_PRO;DLNA.ORG_FLAGS=8D100000000000000000000000000000,
http-get:*:video/MP4V-ES:*,http-get:*:video/quicktime:*,
http-get:*:video/x-msvideo:*,http-get:*:video/x-matroska:*,
http-get:*:video/x-ms-asf:DLNA.ORG_PN=WMVSPML_BASE;DLNA.ORG_FLAGS=8D100000000000000000000000000000,
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_AAC_520;DLNA.ORG_FLAGS=8D100000000000000000000000000000,
http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO_320;DLNA.ORG_FLAGS=8D100000000000000000000000000000,
http-get:*:audio/3gpp:DLNA.ORG_PN=AAC_ISO_320;DLNA.ORG_FLAGS=8D100000000000000000000000000000,
http-get:*:image/png:DLNA.ORG_PN=PNG_TN;DLNA.ORG_FLAGS=8C900000000000000000000000000000,
http-get:*:image/png:DLNA.ORG_PN=PNG_SM_ICO;DLNA.ORG_FLAGS=8C900000000000000000000000000000,
http-get:*:image/png:DLNA.ORG_PN=PNG_LRG_ICO;DLNA.ORG_FLAGS=8C900000000000000000000000000000,
http-get:*:image/png:DLNA.ORG_PN=PNG_LRG;DLNA.ORG_FLAGS=8C900000000000000000000000000000,
http-get:*:audio/wav;rate=44100;channels=2:*,
http-get:*:audio/wav;rate=48000;channels=2:*,
http-get:*:audio/wav;rate=44100;channels=1:*,
http-get:*:audio/wav;rate=48000;channels=1:*,
http-get:*:audio/x-wav;rate=44100;channels=2:*,
http-get:*:audio/x-wav;rate=48000;channels=2:*,
http-get:*:audio/x-wav;rate=44100;channels=1:*,
http-get:*:audio/x-wav;rate=48000;channels=1:*,
http-get:*:audio/x-wav:*,http-get:*:audio/wav:*,
http-get:*:audio/wave:*,http-get:*:audio/avi:*,
http-get:*:video/3gpp:*,http-get:*:video/flv:*,
http-get:*:video/x-flv:*,http-get:*:audio/aac:*,
http-get:*:audio/x-aac:*,http-get:*:audio/x-ac3:*,
Post Sun Jul 19, 2020 8:56 pm
Re: Hisense TV Profile 50A6100UW
I believe that's an Android based OS in that model. Sony uses Android TV, so you might try some of those profiles. The Roku 4K TV might also work fairly well, although your TV probably supports some containers that Roku doesn't, so there could be unneeded transcoding at times.
Basically, I suggest trying several different profiles, see if you have any files that won't play or transcode unnecessarily. I would start with the Generic profile, as it transcodes nothing, and see what doesn't play.
My Shield is an Android TV, but supports virtually all containers and codecs, so it's not a true comparison. But it doesn't need transcoding for anything.
Users browsing this forum: Baidu [Spider], Google [Bot] and 31 guests
