Metadata: How to not use embedded Metadata?
Joshi
Post Fri Aug 21, 2020 6:55 am
is it possible to use metadata only from XBMC .nfo files AND NOT FROM EMBEDDED METADATA OF THE VIDEO FILES?
At the moment I have only selected "XBMC .nfo files" in the Descriptive metadata setting of Serviio, but still embedded metadata is used.
freaknik
Post Fri Aug 21, 2020 9:14 pm
Re: Metadata: How to not use embedded Metadata?
Screenshot_2020-08-21 MediaBrowser.jpg (400.72 KiB) Viewed 4626 times
Are the nfo files present in the same folder as the movies? It works for me I have it set to xbmc nfo files and it reads them:
Here if you notice White House Down is showing the wrong poster, because there is no appropriate named jpg file with it.
Each movie needs an nfo and jpg of the same name for metadata to work in nfo mode.
Users browsing this forum: Baidu [Spider] and 70 guests
