my share folders doesnt work
carajo82
Post Thu Jan 07, 2021 9:55 pm
Captura de Pantalla 2021-01-06 a la(s) 14.28.39.png (213.56 KiB) Viewed 6255 times
i dont know why in Serviio i cant see the data folder, and only the system folders.
in fact when i paste the route appears with a symbol.
carajo82
Post Thu Jan 07, 2021 9:56 pm
Re: my share folders doesnt work
the other pic
Captura de Pantalla 2021-01-07 a la(s) 15.54.35.png (111.51 KiB) Viewed 6254 times
Post Thu Jan 07, 2021 10:31 pm
My apologies, but I can't read the other language on the second post, and since it's an image I can't copy the text into a translation page.
Is this Linux, or Mac? I know, both have a -nix base. I've played a bit with Linux just to experiment, and had a lot of issues when trying to connect to a shared folder on the network. From what I can see of your file structure, it appears to be complete for a Linux based system. Is the share folder you are attempting to use just a link to another device? If so, that could be it. I had to actually mount the remote shared folder to a local folder on my file system, and then it appeared as an available location in Serviio.
If that's the case, I don't think you have any options. I believe that Zip said it was a limitation of Java, which is what Serviio runs under.
carajo82
Post Fri Jan 08, 2021 1:26 am
its not linux i use mac.
if you said that Serviio runs under java maybe that´s the problem, because i remember some notificacions that java will stop working in mac in december.
too bad, i suppose i cant do anything right?
The second pic that i upload is in spanish and only want to show you the icon that appears aside the name of the route.
Post Fri Jan 08, 2021 2:45 am
I know absolutely nothing about the Mac OS. That would surprise me if they are truly dropping support for the MacOS. I just did a quick web search and I could find no such claim. Perhaps they are referring to a default install, and users have to install it themselves. But the fact that you see the Serviio console means that Java is on your Mac and working.
