[PL] WEEB.TV (Web Resource)
plugindev
Post Tue Apr 07, 2015 5:15 pm
WEEB.TV is a Polish streaming service. This plugin allows to grab and add all premium live channels and watch them as online sources on DLNA devices.
Source type: Web Resource
Media type: Video
Version: 1.0
URL example:
    http://weeb.tv
Notes:
- At first fill your credentials in plugin source
- Add only this single url http://weeb.tv and set it as a Web Resource.
weeb.groovy
(6.05 KiB) Downloaded 8788 times
greengo
Post Wed Apr 29, 2015 9:40 am
Re: [PL] WEEB.TV (Web Resource)
Hi, first of all, thank you for your work regarding Weeb.tv plugin. I installed it, works ok, fetches TV streams, can watch it no problem,
but either I am total idiot or there are some issues regarding logging to weeb.tv servers.
It seems like whatever login or password I type in credentials section in the plugin it does not update channel list with premium channels.
Most of movie,sports or polish TV streams are missing.
I have two questions for you Mr Developer, firstly where exactly in the plugin
should we insert login and password for weeb.tv? Only in CREDENTIALS section or further below too?
Secondly should we use whole email address for login for just username before @ sign in email address?
If I am doing something I apologise for wasting your time. This is first plugin which allowed me to watch weeb.tv streams on my tv without
any hiccups although I miss all the premium channels I can access via browser or XBMC/ Kodi.
Thank you again and please respond whenever you can or anyone else who has trouble with his plugin.
Pozdrawiam :)
plugindev
Post Sun May 03, 2015 5:52 pm
sorry for late response, I visit this forum very rarely...
Just for checking... are you sure that your premium account is valid? Are you able to watch premium channels on weeb.tv site or xbmc/kodi plugin?
Btw, please notice that you are still limited to one session at the same time - you can watch the channels only on one device at the same time.
Regarding first question - you need to put your weeb.tv username and password only in CREDENTIALS section.
Regarding second question - username is your e-mail (in most cases) so you need to use whole address
It should look like:
/* -------------- CREDENTIALS -------------------------------- */
final static USERNAME = 'weebtv@username.pl'
final static PASSWORD = 'weebtvpassword'
For me it grabs 143 channels:
For further support I'll need logs (see http://www.wiki.serviio.org/doku.php?id=servio_plugins#logging).
Hope that helps.
Pozdrawiam :)
greengo
Post Wed May 06, 2015 3:35 pm
thank you for clarifying the issue. I am happy to annouce that everything works well, I now have access to complete channel list.
My problem was, I didn't put quote sign and the end of my username and password. It was weird because I could watch streams
without being cut off , your plugin let me watch channels when not logged it. Maybe it is some kind of workaround for users not having
premium accounts :)
Anyway , thank you again for this plugin. It will get very popular because as for now, it is only fully working way to watch online content from Weeb.tv
without too much hassle. It will soon get all the recognition it deserves so again thanks your putting your time into it.
Also, from few hours of testing I realized I get much less lag watching weeb.tv trough serviio. Browser is the worst, Kodi/XBMC is little better.
Anyone who want to watch Weeb.tv on your TV download this plugin and use it!
PS. Check your inbox.
ImagoX86
Post Mon Oct 26, 2015 5:31 pm
I cannot get this plugin to work. As far as I can tell everything is configured correctly however the weeb.tv stream is simply not showing under Online section of Serviio interface (dlna). Is anyone else experience similar issues?
Jurijlv
Post Fri Nov 06, 2015 10:44 pm
Hi everyone, is this plugin is developed only for windows? Because I am using NAS and this plugin does not work. Can someone answer or explain?
Thank you in advance.
plugindev
Post Sun Jan 31, 2016 1:08 pm
I just checked and can confirm that plugin works with the newest Serviio 1.6.
The plugin supports the same platforms as Serviio server.
If you have any problems please describe yours scenarios, steps to reproduce and some useful information from logs.
Regards.
neas
Post Sun Mar 13, 2016 7:57 pm
I downloaded it, put it in servioo plugin area (which isn't stated on this thread).
Then added an online source in 1.6 servioo:
Source Type - Web Resource
Source URL - http:/weeb.tv
Media Type - Video
DIsplay Name Weeb TV
All as suggested in this post.
I got some streams with 1.4 but an error (see next post).
neas
Post Sun Mar 13, 2016 9:27 pm
2016-03-13 21:21:39,841 WARN [FeedUpdaterThread] Failed to retrieve online item information for rtmp://37.48.65.10/channel/2257/live live=true pageUrl=token swfUrl=326295974. It might not play.
java.io.IOException: org.serviio.library.local.metadata.extractor.InvalidMediaFormatException: Unknown video codec.
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:320)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:237)
at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:116)
Caused by: org.serviio.library.local.metadata.extractor.InvalidMediaFormatException: Unknown video codec.
at org.serviio.library.metadata.FFmpegMetadataRetriever.validateMandatoryMetadata(FFmpegMetadataRetriever.java:470)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:100)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:138)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:299)
... 2 more
adekk
Post Thu Dec 17, 2020 8:39 pm
Is there any update to tv online weeb-tv?
Crazyman32
Post Wed Jul 28, 2021 8:39 am
plugindev wrote:WEEB.TV is a Polish streaming service. This plugin allows to grab and add all premium live channels and watch them as online sources on DLNA devices.
Media type: Video
Version: 1.0
URL example:
    http://weeb.tv
Notes:
cara
Post Wed Sep 07, 2022 8:23 am
Media type: Video nyt wordle
Version: 1.0
URL example:
    http://weeb.tv
Notes:
WEEBTV allows you to easily create your own multimedia channel! Create your own TV or radio. Broadcast live from your home PC with the simple Adobe Flash Media Live Encoder (free download from adobe.com). Everyone will be able to watch your own channel or listen to your radio!
Return to Available plugins
Users browsing this forum: Google [Bot] and 4 guests
