Implement seeking content in the Mediabrowser
nobody511
Post Sun Jun 16, 2024 6:56 pm
Add the ability to seek content when using the mediabrowser, that would be a good thing.
If course if transcoding is in effect it is not simple to implement (but with serviio-go it does work already), but for me it would be ok if it worked only when transcoding is off.
TIA.
Post Sun Jun 16, 2024 11:13 pm
Re: Implement seeking content in the Mediabrowser
Are you referring to a search function? That exists. Once you move into the category (video, music, pictures) there's a search button in the upper right corner. If you mean something different, I believe you need to be more specific about what you mean.
nobody511
Post Tue Jun 18, 2024 6:07 pm
Sorry, I should have been more specific:
My request is about to be able to seek while playing back a movie when using the MediaBrowser.
Currently, when you playback a movie, dragging the slider which represents the position of the playback of the file has no effect. It will, after a little wait time jump just back to the current time.
However, when using the Serviio mobile player for android seeking works - even if the content is not fully rendered and transcoding is in effect.
For me that means, the server itself i able to seek, the problem is on the client side.
It would be much nicer if I could do seeking
I do not use serviio with TVs, only android client and on windows Desktop, therefore I dont know how it behaves on other platforms.
Post Wed Jun 19, 2024 1:56 am
I just tried MediaBrowser on my Windows 11 laptop using Chrome as the browser. When you move the cursor over the playback window a time bar appears along the bottom of the window. I tried dragging the position indicator further along and while it took a few seconds to buffer it continued playing from the new position. It doesn't have any buttons to FF/rewind playback, and that would likely require using a different media player. I doubt that is an expense the Serviio developer can handle.
nobody511
Post Wed Jun 19, 2024 12:04 pm
It seems you tried a file encapsulated in a different container or codec then I use.
Ok, when I try a .mp4 file, I am able to seek. However an mkv containter with h264 or 265 seeking does not work (it still works when I use the android serviioGo app).
Post Thu Jun 20, 2024 1:11 am
OK, I tried it with some MKV files with MPEG-2, H.264 and H.265 video. The MEPG-2 files I could FF fine, but I had the same issue you did with the H.264/265 content. When I tried H.264 in the M2TS container, the play bar wasn't even visible. Hopefully Zip will see this thread and investigate. I know he switched to this video player a number of years ago to improve playback over the previous player. But it seems you have identified an issue with it.
nobody511
Post Thu Jun 20, 2024 9:31 pm
Remember this thread?
viewtopic.php?f=5&t=30426
Post Fri Jun 21, 2024 1:17 pm
Over a year ago? Nah, I can't remember stuff that long... :lol:
Anyway, hopefully Zip sees this and looks into it.
nobody511
Post Thu Aug 08, 2024 6:17 pm
I have now made a post in the bitbucket serviio issues tracker.
Maybe, this helps to gain attention.
Return to Feature requests
