Capture StreamTorrent Port
Limon
Post Mon Nov 22, 2021 2:44 pm
Hello everyone! Someone knows how to capture in service at a port (may be 15900, at least that's what I see)
as we do from StreamTorrent or Sopcast AceStream?
https://showbox.tools/
A baseball fan...
shyam
Post Tue Feb 08, 2022 5:39 am
Re: Capture StreamTorrent Port
Torrent client that can be used for proper streaming.
I've been using uTorrent and so far and have been happy with its copy stream url option and pasting that into MPC for streaming video torrents as soon as I start to download them.
However, uTorrent has became a steaming peace of adware and bull manure.
I'm looking for a alternative p2p client to use, which is capable of streaming. Note that I'm not talking about the sequential download, but the actual streaming. The former will cause the player to skip the non-downloaded parts while the latter method will cause it to wait.
I tried qBittorrent, but it's only able to sequentially download. Which clients are capable of that?
P.S. Search doesn't work, I've been trying for a while.
mshakurov
Post Sun Sep 22, 2024 7:48 am
https://github.com/YouROK/TorrServer
this is a server that can be installed on any platform, even on some routers.
this server immediately downloads and outputs the stream via a torrent link, and, by default, does not save data to disk, everything is in memory, only in RAM. but you can also specify a disk, if there is little memory. You only need 64 megabytes of memory to play a single torrent.
to download a torrent to this server, you connect to it via the web interface, add a link to a torrent on the Internet or to a local torrent file, and you can get a link to play from the added torrenta. almost all well-known players support this link.
the solution is simply gorgeous - you can not use disk storage at all, all players play its links, you can play thousands of torrents at the same time, this is OPEN SOURCE.
Return to Available plugins
