LG TV LV5500 dvd (vob) no fullscreen
I can not get DVD (vob) files to fit fullscreen on my LG TV through DLNA. Its killing me knowing how close I could be. Every movie is squished with letterboxing on the sides and a few have letterboxing all around. The TV has only to ratio settings which does not help. LG claims its a DLNA problem but the same files work fine on the USB port. Is there something I'm missing? Should I try to re-encode the DVD (vob) files differently or set serviio up differently? Is it possible without transcoding?
Thanks for any help,
Throck.
