Netgear EVA2000 profile
Post Thu Apr 28, 2011 11:49 am
I need help to create a profile for a Netgear EVA2000 DLNA/UPNP, I tried to get the information with device spy but there was none. Here is the specs I could find. Before I found Serviio I used TVersity and this device worked very good with FF/RE. But I cannot get the FF/RE to work with Serviio.
It says it is DLNA/UPNP ready.
http://www.pcworld.idg.com.au/review/home_entertainment/netgear/digital_entertainer_live_eva2000/354630/specs
Audio files AAC, MP3, OGG, WMA.
Image files JPEG.
Video files ASF, AVI, DivX, H.264, MKV, MOV, MPEG-2, MPEG-4, WMV, XviD.
Post Thu Apr 28, 2011 1:39 pm
Re: Netgear EVA2000 profile
Did you try the Generic DLNA profile? What's the results? If ff/rev doesn't work with that it won't work with a specific profile, unless we remux everything.
Post Thu Apr 28, 2011 1:48 pm
The generic one, would not play the files. I selected the Direct TV DVR profile and the files play video and sound is great, but cannot fast forward.
Post Thu Apr 28, 2011 2:14 pm
That profile transcodes everything into mpeg2, which is not ideal, as according to the list the device should play almost everything.
Really no files can be played using the Generic one?
Post Thu Apr 28, 2011 2:46 pm
Here detail Supported Media File formats of your EVA2000
The only HD format supported is : MPEG-2 MP@HL 8 mbps 30 fps 1280x720
Post Thu Apr 28, 2011 3:19 pm
zip wrote:That profile transcodes everything into mpeg2, which is not ideal, as according to the list the device should play almost everything.
I tried about 10 files last night. I will check them again when I get home and get the information on them.
I also downloaded the firmware source code from the netgear site. I am going to see if it has any information about the DLNA.
Users browsing this forum: Google [Bot] and 13 guests
