Cannot connect to the server, it doesn't seem to be runnig..
klejbroda
Post Fri Dec 19, 2025 2:53 pm
I am having issues when opening the app on Mac, this happens immediately after the start and there’s no way around it. Please see the attached screenshot. This happens in both legacy and the latest versions, it just won’t open. Restarts of the app or the computer don’t help. Can you please advise on how to troubleshoot this?
Cheers
Piotr
https://imgur.com/a/Tf7U5u8
Post Sat Dec 20, 2025 1:15 am
Re: Cannot connect to the server, it doesn't seem to be runn
Have you attempted to use the web interface instead of the console app? On the computer running Serviio, just try localhost:23423/console and see if it opens. If it does, then Serviio is running. Many people have issues with the console app but can use the web version without any issues.
If the web console doesn't work, then open the Serviio log and look for error messages. The log is located within the file structure you installed Serviio to in the Logs folder.
normski
Post Fri Feb 27, 2026 8:27 pm
I also have this problem. The installer says all has been correctly completed BUT only the console is actually present.
The server files in OSX mavericks V9 - Library have not been put in place.
Maybe its the version of OSX but pre-requisite is OSX V8.
I would really like to try serviio so if you have any ideas then please let me know.
megaspaz
Post Fri Mar 13, 2026 10:33 pm
This has been unsolved since the early sequoia days. Maybe something in updating to sequoia had some permission change, no one knows...
viewtopic.php?f=5&t=30914
Nothing seemingly in the logs so nothing much could be done. Well there was something about derby but the derby log looks clean... Anyway, just waiting to see if 2.5 would work in the current macos.
Attaching my latest attempt if needed, but don't think there's anything there...
https://imgur.com/a/serviio-woe-TxTGc6I
derby.log
(717 Bytes) Downloaded 272 times
(359.42 KiB) Downloaded 254 times
Post Sat Mar 14, 2026 1:35 am
Based on what that log shows, Serviio should be running. I'd first check if the computer is using the IP address that is listed in the Serviio log (I think it was 192.168.0.60, but I've closed the file and going on memory). My next question is if you're trying to use the Serviio console that is installed with Serviio, or using the web interface (http://localhost:23423/console from the computer running Serviio, otherwise using the computer name or IP address in place of localhost). Many times I've had the console app not work but the web interface works fine. I stopped even trying the console app before Serviio reached version 1.0.
megaspaz
Post Sat Mar 14, 2026 7:13 pm
IP Addy is correct. IP/computer name/localhost, all work for access for web app. No difference in console desktop application or console web app. Both fail with same can't connect to server message.
https://imgur.com/a/PSBmR78
Post Sat Mar 14, 2026 7:22 pm
Thank you for that confirmation. From what I can see, Serviio is running normally on your computer. All I can think of is some sort of firewall setting that is blocking access, something outside of Serviio's control. Are you using a VPN by any chance? Those will block it as well.
megaspaz
Post Sat Mar 14, 2026 9:34 pm
No VPN or FW...
Post Sat Mar 14, 2026 10:03 pm
megaspaz wrote:No VPN or FW...
I can't speak to MacOS, but Windows and most Linux distros has a built-in firewall that is activated by default, and to access Serviio ports need to be opened.
megaspaz
Post Sat Mar 14, 2026 10:31 pm
That is true, but I always disable firewall. VPN is also inactive unless I need to do something like torrent, etc.
https://imgur.com/a/kzbdk8s
Post Sun Mar 15, 2026 1:49 am
Sorry, then I'm at a loss. I'm not the developer, just a moderator on the forum with a bit of knowledge and experience. Zip is the developer and would likely need to help further. He does have some Mac experience as well. My experience is mostly with Windows, and a hair of dabbling with Linux.
megaspaz
Post Sun Mar 15, 2026 10:10 pm
Yeah... tis odd. The only guess I got is the OS upgrade introduced something with something directly breaking serviio or maybe broke something with the serviio provided java... :ugeek:
Godsbusy
Post Sat Jun 13, 2026 7:58 pm
I just updated.. and am getting this message... going to localhost:23423/console comes back fro safari as safari cannot open page because safari cannot connect to locol host.. any fix for this???
JunJun
Post Sun Jun 14, 2026 3:46 pm
I just upgraded Serviio with the new version (2.5) and the app doesn’t want to start anymore.
All I get is the « Cannot connect to the server, it doesn't seem to be running… » message , even after I restarted the Mac…
Tried the localhost:23423/console/ thing, with no success.
Checked the log and it shows this error :
2026-06-14T14:41:44,783 ERROR [MediaServer] An unexpected error occurred. Ending the application. Message: /Library/Application Support/Serviio/jre/lib/libosx.dylib: dlopen(/Library/Application Support/Serviio/jre/lib/libosx.dylib, 0x0001): Library not loaded: '@rpath/JavaNativeFoundation'
Referenced from: '/Library/Application Support/Serviio/jre/lib/libosx.dylib'
Reason: tried: '/Library/Application Support/Serviio/jre/lib/./JavaNativeFoundation' (no such file), '/Library/Application Support/Serviio/jre/lib/./JavaNativeFoundation' (no such file), '/Library/Application Support/Serviio/jre/lib/server/./JavaNativeFoundation' (no such file), '/Library/Application Support/Serviio/jre/lib/server/../JavaNativeFoundation' (no such file), '/Library/Application Support/Serviio/jre/bin/./JavaNativeFoundation' (no such file), '/usr/lib/JavaNativeFoundation' (no such file)
java.lang.UnsatisfiedLinkError: /Library/Application Support/Serviio/jre/lib/libosx.dylib: dlopen(/Library/Application Support/Serviio/jre/lib/libosx.dylib, 0x0001): Library not loaded: '@rpath/JavaNativeFoundation'
Anything I can do ??
So, I’m on Mac, with Monterey, java version "24.0.1"
Thanks !
