Vertical phone videos on the TV through Serviio?
isajarv55
Post Wed Nov 18, 2026 2:45 pm
General question about a slightly odd use case.
My wife watches short drama series filmed vertically for phones, one minute per episode. Some of the apps let you download episodes, and she asked whether we could watch them on the living room TV instead of squinting at the phone.
I copied a few test files to the NAS and Serviio picks them up fine, but on the Samsung they play as a thin strip in the middle with huge black bars, and some refuse to play at all because of the odd resolution.
Has anyone dealt with portrait video through Serviio? Is there a transcoding profile that pads or rotates sensibly, or is it a lost cause on a 16:9 screen?
Post Wed Nov 18, 2026 9:19 pm
Re: Vertical phone videos on the TV through Serviio?
I don't believe there's any way for Serviio (or any other home media server package) to auto-rotate videos. You could probably create a profile to adjust an odd resolution issue, but to provide any further help we'd need to know more about the media file contents. Seeing that it's a portrait orientation on a landscape display, I'm doubtful any other adjustment of the image would result in something watchable.
I did a quick search for software that can rotate videos to landscape, but I would be concerned what the final video looked like. Would it simply lay it on its side, which would make it nearly unwatchable? Or would it attempt to center the image on the center and crop content from the other areas? That might not leave an acceptable video either. Only way to really know would be to give one or more a try. Most software offers trial versions, and it appears that there are a number of cheap or free apps for Windows in their app store.
Return to General discussion
