portrait jpg no display
johans
Post Sun Mar 27, 2011 10:21 pm
I have a canon G7 camera - before v5* all pictures (jpg) whatever the orientation are displayed ok (sony bravia through sony BD 570)
since v5* : very very slow picture slide show and portrait pictures are not loaded (keeps on "loading" )
i tried several configurations but nothing seems to help
it looks as if servio cannot reorientate the picture
suggestions ? :(
Post Mon Mar 28, 2011 7:28 am
Re: portrait jpg no display
Could you post "ffmpeg -i" result of your file?
johans
Post Mon May 02, 2011 11:05 pm
to illico
output ffmpeg of an example problematic file
can you make something out of it ? Wnever a picture is in portrait position dlna streaming takes continues endlessly
Microsoft Windows XP [versie 5.1.2600] servicepack 3
(C) Copyright 1985-2001 Microsoft Corp.
C:\Program Files\Serviio\lib>ffmpeg.exe -i "c:\temp\testffmpeg\img_3272.jpg"
686-mingw32-
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
Input #0, image2, from 'c:\temp\testffmpeg\img_3272.jpg':
Duration: 00:00:00.04, start: 0.000000, bitrate: N/A
Stream #0.0: Video: mjpeg, yuvj422p, 3648x2736, 25 tbr, 25 tbn, 25 tbc
Post Sat May 07, 2011 5:24 pm
johans wrote:to illico
This portrait file is in Motion JPEG, this is a video, select and browse into the proper section on Sony XMB menu : Video.
or rename this file with *.avi extension and browse in Sony Video section
Post Sat May 07, 2011 6:21 pm
No, it actually is jpeg. Serviio doesn't use FFmpeg to detect images or audio files, so no point looking at this output.
You could only play with
where the first will rotate the image if the EXIF metadata include the rotation of the image. But it's possible that the TV can do it automatically, in that case it should be false.
The second will resize images with resolution higher than 4096x4096, which doesn't seem to be the case of this file.
Post Sat May 07, 2011 8:05 pm
zip wrote:No, it actually is jpeg. Serviio doesn't use FFmpeg to detect images or audio files, so no point looking at this output.
Ooh, so how Serviio detect images or audio type files, only with file extension and EXIF (if embedded)?
Post Sat May 07, 2011 8:33 pm
It uses other (Java) libraries to extract metadata from audio/images.
palmerdarron
Post Wed Aug 28, 2019 8:33 am
Is there any way of detecting image or audio file type without extension?
Samydalien
Post Wed Aug 28, 2019 10:06 am
The browser File API in the quite powerful for detecting image and audio files.
Emileroure
Post Sat Oct 19, 2019 2:00 pm
Dear All,
How to read a big JPG by steps and display instantly
This is to decrease the waiting time to display the image in LAN.
Users prefer to hv the screen change gradually than waiting for
loading complete and image come out.
Thks n rgds
Chang
Post Sat Oct 19, 2019 4:51 pm
Emileroure wrote:Dear All,
Users prefer to have the screen change gradually than waiting for loading complete and image come out.
Thks n rgds
Chang
I believe this is something this is player dependent. I don't think there's anything on the Serviio side that can do this.
valad59459
Post Thu Jan 30, 2020 6:31 pm
I got the same problem when I ported out big image. I am not sure whether I need to replace my 5-year old laptop (i5-4210+GTX840) to fix this issue.
Users browsing this forum: Google [Bot] and 8 guests
