serving 3d films to vt30 doesn't run
soldurio
Post Fri May 27, 2011 3:02 pm
Hi:
i have a Panna 50vt30.
i'm traying to serve 3d films from serviio dlna server, but all film i traied doesn't active 3d view on tv.
info from one of them (a 3d demo film from samsung)
"C:\Archivos de programa\Serviio\lib>ffmpeg.exe -i H:\BDMV\STREAM\00000.m2ts
686-mingw32-
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
Input #0, mpegts, from 'H:\BDMV\STREAM\00000.m2ts':
Duration: 00:00:41.49, start: 11.651011, bitrate: 19073 kb/s
Program 1
Stream #0.0[0x1011]: Video: h264, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 23.
98 fps, 23.98 tbr, 90k tbn, 47.95 tbc
Stream #0.1[0x1100]: Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
¿any clues¿?
Post Fri May 27, 2011 11:42 pm
Re: serving 3d films to vt30 doesn't run
i dont think 3D is supported over dlna..
Post Fri May 27, 2011 11:52 pm
it should be, as it's just another codec. Some people confirmed they got it working.
Post Sat May 28, 2011 3:25 am
zip wrote:it should be, as it's just another codec. Some people confirmed they got it working.
really ???? id of though it would have been a resource as it can be turned on or off but ok learn something new everyday.
soldurio
Post Sat May 28, 2011 9:08 am
excusme, zip, but i've tried more than three 3d blu-ray .iso and no one have worked. the files appear on tv menu, and run... but 2d mode only.
i know is another code, but something is wrong. of course can be a tv mediacenter problem, but ¿?how test it¿?
normally .mkv SBS film worked well, but, on my trials, no .iso 3d run (on tv i only view on 2D mode)
tia
gabychou
Post Mon Apr 02, 2012 7:36 pm
Helllo there,
If it can help, I have a TX-P50VT30E (bought in France), and 3D movies work all fine through DLNA, though I have sometimes to reencode them (using Tipard Video Converter), though I haven't understood why :shock:
Firmware is in version 1.801
Hope this will help...
Return to Panasonic
