PS3 sees my ReadyNAS but not Serviio
cnapan
Post Sun Mar 13, 2011 6:40 pm
I've spent a few hours on this and am stuck... hope you can help.
I have a network with the following machines:
1) Windows 7 with serviio ('PC 1')
2) Another windows box running WMP ('PC 2')
3) A netgear readyNAS duo running readyDLNA
4) A PS3
They're all connected to the same router on a wired network.
The PS3 can see the readyNAS server fine. However, I can't get it to see the serviio server on PC1
When I run devicespy on PC1, it doesn't see the PS3. It does however see PC1, PC2, and the readyNAS.
If I check the status tab in serviio on PC1, then it doesn't seem to detect the PS3.
Yet the PS3 is able to connect to the other DLNA server (readyNAS).
I'm at a loss to explain the issue.
I installed serviio using the windows installer today, and I presume that the firewall is ok, otherwise devicespy wouldn't detect the DLNA settings of PC2 or the readyNAS server.
It can't be the router, because otherwise the PS3 wouldn't see the readyNAS DLNA server either.
Any ideas for what I could do to drill down to the cause here?
Any help gratefully received!
Cheers
Andy
Post Sun Mar 13, 2011 7:25 pm
Re: PS3 sees my ReadyNAS but not Serviio
post the log
cnapan
Post Sun Mar 13, 2011 11:00 pm
Here's the first bit of it. The rest was all 'Added File' lines which isn't really relevant.
I couldn't see anything useful there. BTW, 192.168.0.20 is the ip address of the PC running serviio, and is connected to the same network as all the other devices. I tried binding it manually in case it was binding to the wrong network card.
Cheers
Andy
2011-03-13 17:03:44,675 INFO [MediaServer] ------------------------------------------------------------------------
2011-03-13 17:03:44,676 INFO [MediaServer] Serviio DLNA media streaming server v 0.5 (rev. 975aa458693c)
2011-03-13 17:03:44,676 INFO [MediaServer] Petr Nejedly 2009-2011
2011-03-13 17:03:44,676 INFO [MediaServer] http://www.serviio.org
2011-03-13 17:03:44,676 INFO [MediaServer] Java 1.6.0_20-Sun Microsystems Inc.
2011-03-13 17:03:44,676 INFO [MediaServer] OS Windows 7 amd64 6.1
2011-03-13 17:03:44,676 INFO [MediaServer] File encoding: windows-1252
2011-03-13 17:03:44,676 INFO [MediaServer] ------------------------------------------------------------------------
2011-03-13 17:03:44,868 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2011-03-13 17:03:44,925 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-03-13 17:03:48,247 INFO [DBSchemaUpdateExecutor] Updating DB schema
2011-03-13 17:03:50,755 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-03-13 17:03:51,012 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-03-13 17:03:51,057 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-03-13 17:03:51,093 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-03-13 17:03:51,113 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-03-13 17:03:51,137 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-03-13 17:03:51,156 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-03-13 17:03:51,187 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C-series)' (id=7)
2011-03-13 17:03:51,201 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-03-13 17:03:51,259 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-03-13 17:03:51,406 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player (EU)' (id=10)
2011-03-13 17:03:51,568 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player (US)' (id=11)
2011-03-13 17:03:51,595 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-03-13 17:03:51,645 INFO [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-03-13 17:03:51,782 INFO [VideoDeliveryEngine] Cleaning transcode engine and its data
2011-03-13 17:03:51,796 INFO [WebServer] Socket buffer set to 65535 bytes
2011-03-13 17:03:51,886 INFO [WebServer] WebServer starting on port 8895
2011-03-13 17:03:52,026 INFO [Device] Created UPnP Device with UUID: d527e9e3-bde1-300c-8dab-d8ebc157c4d5, bound address: 192.168.0.20
2011-03-13 17:03:52,041 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-03-13 17:03:52,045 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-03-13 17:03:52,047 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-03-13 17:03:52,047 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-03-13 17:03:52,048 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-13 17:03:52,048 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-03-13 17:03:52,048 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1300035832048, LastAccessTime = 1300035832048, getTimeToLiveSeconds() = -1, createTime = 1300035832048 ]
2011-03-13 17:03:52,049 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-03-13 17:03:52,058 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-03-13 17:03:52,058 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-13 17:03:52,058 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-03-13 17:03:52,058 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-03-13 17:03:52,058 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-13 17:03:52,058 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-03-13 17:03:52,058 INFO [CompositeCacheConfigurator] Finished configuration in 12 ms.
2011-03-13 17:03:52,060 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-03-13 17:03:52,060 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-03-13 17:03:52,061 INFO [EventDispatcher] Starting EventDispatcher
2011-03-13 17:03:52,063 INFO [RendererSearchSender] Searching for Renderer devices
2011-03-13 17:03:52,063 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-03-13 17:03:52,101 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Broadcom NetLink (TM) Gigabit Ethernet) and address 192.168.0.20, timeout = 0
2011-03-13 17:03:54,172 INFO [RendererManager] Stored a new renderer: uuid='e60f1a7e-23cd-407c-b54a-d5f0edc2545c', name = 'Windows Media Player', ipAddress='192.168.0.16', profile = '1'
2011-03-13 17:04:00,780 INFO [ServiioConsole] Starting Serviio Console
2011-03-13 17:04:01,452 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-03-13 17:04:02,790 INFO [Messages] Loaded console message bundle for locale: en
2011-03-13 17:04:03,637 INFO [Messages] Loaded console message bundle for locale: en
2011-03-13 17:04:03,761 INFO [UpdateChecker] Checking if a new version is available
2011-03-13 17:04:09,614 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-03-13 17:04:09,854 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-03-13 17:04:15,972 INFO [ServiioConsole] Leaving Serviio Console
2011-03-13 17:04:18,192 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-03-13 17:04:18,194 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-03-13 17:06:43,223 INFO [RendererManager] Stored a new renderer: uuid='21e0e57f-f28d-436f-a321-25dd951cbb8d', name = 'PS3', ipAddress='192.168.0.15', profile = '4'
2011-03-13 17:06:43,235 INFO [WebServer] WebServer shutting down
2011-03-13 17:06:43,235 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-03-13 17:06:43,235 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-03-13 17:06:43,235 INFO [EventDispatcher] Leaving EventDispatcher
2011-03-13 17:06:43,341 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-03-13 17:06:43,344 INFO [Device] Updated bound IP address of Device with UUID: d527e9e3-bde1-300c-8dab-d8ebc157c4d5, bound address: 192.168.0.20
2011-03-13 17:06:43,347 INFO [WebServer] WebServer starting on port 8895
2011-03-13 17:06:43,348 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-03-13 17:06:43,348 INFO [EventDispatcher] Starting EventDispatcher
2011-03-13 17:06:43,348 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-03-13 17:06:43,348 INFO [RendererSearchSender] Searching for Renderer devices
2011-03-13 17:06:43,368 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Broadcom NetLink (TM) Gigabit Ethernet) and address 192.168.0.20, timeout = 0
2011-03-13 17:06:44,532 INFO [RendererManager] Stored a new renderer: uuid='e60f1a7e-23cd-407c-b54a-d5f0edc2545c', name = 'Windows Media Player', ipAddress='192.168.0.16', profile = '1'
2011-03-13 17:06:47,074 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2011-03-13 17:06:47,196 INFO [WebServer] WebServer shutting down
2011-03-13 17:06:47,196 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-03-13 17:06:47,196 INFO [EventDispatcher] Leaving EventDispatcher
2011-03-13 17:06:47,296 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-03-13 17:06:58,896 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-03-13 17:38:03,612 INFO [ServiioConsole] Leaving Serviio Console
2011-03-13 17:38:03,618 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-03-13 17:38:03,818 INFO [DatabaseManager] Shutting down database
2011-03-13 17:38:04,708 INFO [VideoDeliveryEngine] Cleaning transcode engine and its data
2011-03-13 17:38:19,335 INFO [MediaServer] ------------------------------------------------------------------------
2011-03-13 17:38:19,336 INFO [MediaServer] Serviio DLNA media streaming server v 0.5 (rev. 975aa458693c)
2011-03-13 17:38:19,336 INFO [MediaServer] Petr Nejedly 2009-2011
2011-03-13 17:38:19,336 INFO [MediaServer] http://www.serviio.org
2011-03-13 17:38:19,336 INFO [MediaServer] Java 1.6.0_20-Sun Microsystems Inc.
2011-03-13 17:38:19,336 INFO [MediaServer] OS Windows 7 amd64 6.1
2011-03-13 17:38:19,336 INFO [MediaServer] File encoding: windows-1252
2011-03-13 17:38:19,336 INFO [MediaServer] ------------------------------------------------------------------------
2011-03-13 17:38:19,402 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2011-03-13 17:38:19,438 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-03-13 17:38:20,085 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-03-13 17:38:20,371 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-03-13 17:38:20,425 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-03-13 17:38:20,457 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-03-13 17:38:20,479 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-03-13 17:38:20,507 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-03-13 17:38:20,532 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-03-13 17:38:20,570 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C-series)' (id=7)
2011-03-13 17:38:20,590 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-03-13 17:38:20,650 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-03-13 17:38:20,810 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player (EU)' (id=10)
2011-03-13 17:38:20,990 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player (US)' (id=11)
2011-03-13 17:38:21,019 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-03-13 17:38:21,072 INFO [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-03-13 17:38:21,098 INFO [VideoDeliveryEngine] Cleaning transcode engine and its data
2011-03-13 17:38:21,109 INFO [WebServer] Socket buffer set to 65535 bytes
2011-03-13 17:38:21,133 INFO [WebServer] WebServer starting on port 8895
2011-03-13 17:38:21,137 INFO [Device] Created UPnP Device with UUID: d527e9e3-bde1-300c-8dab-d8ebc157c4d5, bound address: 192.168.0.20
2011-03-13 17:38:21,150 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-03-13 17:38:21,153 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-03-13 17:38:21,155 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-03-13 17:38:21,155 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-03-13 17:38:21,156 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-13 17:38:21,156 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-03-13 17:38:21,156 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1300037901156, LastAccessTime = 1300037901156, getTimeToLiveSeconds() = -1, createTime = 1300037901156 ]
2011-03-13 17:38:21,157 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-03-13 17:38:21,165 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-03-13 17:38:21,165 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-13 17:38:21,165 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-03-13 17:38:21,165 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-03-13 17:38:21,165 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-03-13 17:38:21,165 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-03-13 17:38:21,165 INFO [CompositeCacheConfigurator] Finished configuration in 11 ms.
2011-03-13 17:38:21,167 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-03-13 17:38:21,167 INFO [EventDispatcher] Starting EventDispatcher
2011-03-13 17:38:21,167 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-03-13 17:38:21,170 INFO [RendererSearchSender] Searching for Renderer devices
2011-03-13 17:38:21,170 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-03-13 17:38:21,191 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Broadcom NetLink (TM) Gigabit Ethernet) and address 192.168.0.20, timeout = 0
2011-03-13 17:38:28,255 INFO [ServiioConsole] Starting Serviio Console
2011-03-13 17:38:28,320 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-03-13 17:38:28,985 INFO [Messages] Loaded console message bundle for locale: en
2011-03-13 17:38:29,811 INFO [Messages] Loaded console message bundle for locale: en
2011-03-13 17:38:29,934 INFO [UpdateChecker] Checking if a new version is available
2011-03-13 17:38:35,206 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-03-13 17:38:35,460 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-03-13 17:38:37,503 INFO [ServiioConsole] Leaving Serviio Console
2011-03-13 17:38:47,304 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-03-13 17:38:47,305 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-03-13 17:39:23,342 INFO [WebServer] WebServer shutting down
2011-03-13 17:39:23,342 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-03-13 17:39:23,342 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-03-13 17:39:23,342 INFO [EventDispatcher] Leaving EventDispatcher
2011-03-13 17:39:23,450 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-03-13 17:39:24,356 INFO [WebServer] WebServer starting on port 8895
2011-03-13 17:39:24,358 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-03-13 17:39:24,358 INFO [EventDispatcher] Starting EventDispatcher
2011-03-13 17:39:24,358 INFO [RendererSearchSender] Searching for Renderer devices
2011-03-13 17:39:24,358 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-03-13 17:39:24,380 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Broadcom NetLink (TM) Gigabit Ethernet) and address 192.168.0.20, timeout = 0
2011-03-13 17:39:26,174 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2011-03-13 17:43:23,634 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-03-13 17:43:23,925 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-03-13 17:43:23,926 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-03-13 17:43:24,940 INFO [LibraryAdditionsCheckerThread] Added file 'chichesterharbour-1.jpg' (title: chichesterharbour-1) to Library
2011-03-13 17:43:25,319 INFO [LibraryAdditionsCheckerThread] Added file 'chichesterharbour-10.jpg' (title: chichesterharbour-10) to Library
2011-03-13 17:43:25,664 INFO [LibraryAdditionsCheckerThread] Added file 'chichesterharbour-100.jpg' (title: chichesterharbour-100) to Library
2011-03-13 17:43:25,927 INFO [RendererManager] Stored a new renderer: uuid='c5bebbe6-4961-46ea-9326-dfd39e8f6f83', name = 'Unrecognized device', ipAddress='192.168.0.20', profile = '1'
2011-03-13 17:43:25,963 INFO [LibraryAdditionsCheckerThread] Added file 'chichesterharbour-101.jpg' (title: chichesterharbour-101) to Library
2011-03-13 17:43:26,319 INFO [LibraryAdditionsCheckerThread] Added file 'chichesterharbour-102.jpg' (title: chichesterharbour-102) to Library
2011-03-13 17:43:26,595 INFO [LibraryAdditionsCheckerThread] Added file 'chichesterharbour-103.jpg' (title: chichesterharbour-103) to Library
2011-03-13 17:43:26,876 INFO [LibraryAdditionsCheckerThread] Added file 'chichesterharbour-104.jpg' (title: chichesterharbour-104) to Library
2011-03-13 17:43:27,173 INFO [LibraryAdditionsCheckerThread] Added file 'chichesterharbour-105.jpg' (title: chichesterharbour-105) to Library
2011-03-13 17:43:27,560 INFO [LibraryAdditionsCheckerThread] Added file 'chichesterharbour-106.jpg' (title: chichesterharbour-106) to Library
Post Mon Mar 14, 2011 12:10 am
any chance of another firewall on the PC? maybe an antivirus
cnapan
Post Mon Mar 14, 2011 10:34 pm
I guess it's got to be something like that.
I'm running the standard windows 7 firewall, and the inbound and outbound rules for serviio are wide open.
I'll list the other things I tried before using Serviio in case they're the reason:
WMP: Worked, but was slow (far slower than the readyNAS DLNA server, which only runs on a lowly Netgear DUO)
Fuppes: I couldn't seem to get that going, and has an odd install. I wonder if somehow this is affecting it?
Having said that, if the problem was a firewall, it serviio wouldn't be able to see the other PC. That correctly appears with a green light in the setup tab, and device spy has no problem seeing it too (along with all the readynas DUO). If I manually add the PS3, it has an amber light.
One last thing... On the PS3, I enabled Qriocity. Could that have anything to do with it? I've since disabled that, but doesn't seem to make a difference.
Thanks for the help so far.
Andy
Post Mon Mar 14, 2011 10:37 pm
It can see the other PC because the other PC doesn't have firewall on the ports the other app (WMP?) is using. You can try running AV Media Controller or Device Spy on the other PC to see if it displays Serviio on your main box (tools are part of Intel tools, link in my signature)
cnapan
Post Wed Mar 16, 2011 7:09 pm
Thanks for the suggestion - will have to try it later (I'll let you know how it went)
Cheers
Andy
72hundred
Post Wed Jun 29, 2011 9:27 am
Any resolution on this issue? I'm in a similar situation.
I installed Serviio, several months ago, and it never actually worked and never could I see it on my ps3. I didn't investigate further, but didn't uninstall either - hoping that a future update might solve the problem. (I'm using USB sticks for my media from PC to PS3 currently).
On my laptop I've W7 Ultimate x64 running with Comodo firewall and Avira antivirus.
Serviio has been added to the accepted programs for the firewall.
The router is wired to the laptop and wireless to the ps3.
Previously the ps3 was able to see TVersity (which I just got sick of), and Windows Media Player on the laptop, so I don't think its related to the network/router.
Upon inspection of the Serviio console now... I can see that the PS3 (192.168.0.6), is not among the listed IP addresses that Serviio can see.
PS: I've manually added the PS3 at 192.168.0.6 to the list in the Serviio console and still no joy.
PS-2: Is it possible that the Windows Media Player that's running concurrently, could be interfering with the Serviio port/connection/etc?
Thanks for any help!
72oo
Post Wed Jun 29, 2011 10:07 am
It will most likely be the firewall. Try turning both those programs off to see if that's the case. Also check the log to see if Serbiio binds to the right IP address, if not put the PC's IP address into the Bound IP address field in the console.
72hundred
Post Wed Jun 29, 2011 12:48 pm
Ok, bound the ip to 192.168.0.4 (it was previously incorrectly bound to 192.168.0.5 from when I was using the laptop's wireless card).
I've quit out of Comodo Firewall, and quit as much as I can (without too much hassle) Avira (the program is still running but not in Active Mode).
Restarted the PS3, researched. And no joy!
I've a second PC, a desktop, on the same network that's running Window's XP. I'm going to install Serviio on that and see if I get any luck. (although where I really need it installed is on the laptop).
72oo
Post Wed Jun 29, 2011 1:44 pm
You can show your open ports by running the command on this page.
You run the following command from the command line and it will show the computers open ports.
netstat -an |find /i "listening"
You can download a program called Angry IP Scanner here that will scan the computers on your network and you can set it up to look for open ports. You can use this on your second computer to verify that the required ports are in fact open and not being blocked. You will have to enable port scanning in the options of the program.
Users browsing this forum: No registered users and 50 guests
