Plays on BDP-S570 but not on PS3
martinronquillo
Post Fri Aug 05, 2011 6:51 am
Firstly I want to say how great Serviio is for streaming videos from my NAS to my Blu ray and PS through my computer.
I hope that there is a way to natively support straming via Buffalo NAS without having to turn your computer on.
I am relatively new to Serviio and quite frankly I have learned so much from reading the forums and the support pages.
I do however am stuck with a problem, All my videos work and play fine on my BDP-S570 but there is are some files that I can't play on my PS3.
The file loads and is seen but when I try to play it on the PS3, it says file is not supported.
The same file plays great on the 570. So I am stuck. I tried most of the fixes ont the forums but can't get the file to play.
Attached is the ffmpeg of the said file . . .
C:\Program Files\Serviio\lib>ffmpeg.exe -i "\\LS-CHL1FF\Videos\sanctum
.mkv"
686-mingw32-
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
[matroska,webm @ 003dbad0] max_analyze_duration reached
[matroska,webm @ 003dbad0] Estimating duration from bitrate, this may be inaccur
ate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (48000/
1001) -> 23.98 (48000/2002)
Input #0, matroska,webm, from '\\LS-CHL1FF\Videos\sanctum.mkv':
Duration: 01:48:49.60, start: 0.000000, bitrate: 64 kb/s
Stream #0.0(eng): Video: h264, yuv420p, 1280x720 [PAR 1:1 DAR 16:9], 23.98 f
ps, 23.98 tbr, 1k tbn, 47.95 tbc
title : Sanctum 2011
Stream #0.1(eng): Audio: ac3, 44100 Hz, stereo, s16, 64 kb/s
Stream #0.2(eng): Subtitle: [0][0][0][0] / 0x0000
and below is the mediainfo. . .thanks
Unique ID : 200499804891838516646182102672004054068 (0x96D6DB99567984D7AEEB541EF44B7C34)
Complete name : \\LS-CHL1FF\videos\Sanctum.mkv
Format : Matroska
Format version : Version 2
File size : 648 MiB
Duration : 1h 48mn
Overall bit rate : 832 Kbps
Encoded date : UTC 2011-06-07 06:09:02
Writing application : mkvmerge v4.8.0 ('I Got The...') built on May 24 2011 03:12:58
Writing library : libebml v1.2.0 + libmatroska v1.1.0
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Format settings, GOP : M=1, N=7
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 48mn
Bit rate mode : Variable
Bit rate : 767 Kbps
Maximum bit rate : 40.0 Mbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.035
Stream size : 585 MiB (90%)
Title : Sanctum 2011
Writing library : x264 core 115 r1995 c1e60b9
Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / slices=4 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=1 / constrained_intra=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=1 / weightp=0 / keyint=60 / keyint_min=6 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=767 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=40000 / vbv_bufsize=30000 / nal_hrd=vbr / ip_ratio=1.40 / aq=1:1.00
Language : English
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 1h 48mn
Bit rate mode : Constant
Bit rate : 64.0 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 49.8 MiB (8%)
Language : English
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Language : English
Post Fri Aug 05, 2011 7:35 am
Re: Plays on BDP-S570 but not on PS3
mkv file probably delivered in native format for BDP-S570 and transcoded/remuxed for PS3.
Could you enable detailed logging (see signature link), post result here, and check how file is delivered?
If transcoded, post here the ffmpeg command used.
martinronquillo
Post Fri Aug 05, 2011 9:27 pm
Here is the log file . . .
2011-08-05 09:38:20,104 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-08-05 09:38:20,104 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-08-05 09:38:20,104 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-08-05 09:38:20,104 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-08-05 09:38:20,104 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1312562300104, LastAccessTime = 1312562300104, getTimeToLiveSeconds() = -1, createTime = 1312562300104 ]
2011-08-05 09:38:20,104 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-08-05 09:38:20,135 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-08-05 09:38:20,135 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-08-05 09:38:20,135 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-08-05 09:38:20,135 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-08-05 09:38:20,135 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-08-05 09:38:20,135 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-08-05 09:38:20,135 INFO [CompositeCacheConfigurator] Finished configuration in 46 ms.
2011-08-05 09:38:20,135 INFO [EventDispatcher] Starting EventDispatcher
2011-08-05 09:38:20,135 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-08-05 09:38:20,151 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-08-05 09:38:20,151 INFO [RendererSearchSender] Searching for Renderer devices
2011-08-05 09:38:20,151 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-08-05 09:38:20,198 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Broadcom NetXtreme 57xx Gigabit Controller) and address 192.168.1.113, timeout = 0
2011-08-05 09:38:46,780 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-08-05 09:38:46,812 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-08-05 09:38:57,717 INFO [ServiioConsole] Starting Serviio Console
2011-08-05 09:38:58,912 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-08-05 09:39:02,411 INFO [Messages] Loaded console message bundle for locale: en
2011-08-05 09:39:05,113 INFO [Messages] Loaded console message bundle for locale: en
2011-08-05 09:39:05,245 INFO [UpdateChecker] Checking if a new version is available
2011-08-05 09:39:26,241 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-08-05 09:39:26,952 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-08-05 09:39:39,286 INFO [ServiioConsole] Leaving Serviio Console
2011-08-05 09:40:42,908 INFO [ServiioConsole] Leaving Serviio Console
2011-08-05 09:41:09,177 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-08-05 09:41:09,446 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-08-05 09:41:09,446 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-08-05 09:41:22,525 INFO [ServiioConsole] Leaving Serviio Console
2011-08-05 09:42:06,112 INFO [LibraryUpdatesCheckerThread] Updated 'TRON Legacy {2010} by Mr. KickASS' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\TRON Legacy {2010} by Mr. KickASS.mp4) in Library
2011-08-05 09:42:51,667 INFO [LibraryUpdatesCheckerThread] Updated 'Despicable Me' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Despicable Me.mp4) in Library
2011-08-05 09:44:09,837 INFO [LibraryUpdatesCheckerThread] Updated 'pac-jmm-2' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\pac-jmm-2.wmv) in Library
2011-08-05 09:45:04,148 INFO [LibraryUpdatesCheckerThread] Updated 'Faster {2010} by Mr. KickASS' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Faster {2010} by Mr. KickASS.mp4) in Library
2011-08-05 09:46:23,943 INFO [LibraryUpdatesCheckerThread] Updated 'Just Go With It {2011} - Mr KickASS' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Just Go With It {2011} - Mr KickASS.mp4) in Library
2011-08-05 09:46:44,189 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-08-05 09:47:53,785 INFO [MediaServer] ------------------------------------------------------------------------
2011-08-05 09:47:53,801 INFO [MediaServer] Serviio DLNA media streaming server v 0.5.2 (rev. 4e3210bd9ff3)
2011-08-05 09:47:53,801 INFO [MediaServer] Petr Nejedly 2009-2011
2011-08-05 09:47:53,801 INFO [MediaServer] http://www.serviio.org
2011-08-05 09:47:53,801 INFO [MediaServer] Java 1.6.0_26-Sun Microsystems Inc.
2011-08-05 09:47:53,816 INFO [MediaServer] OS Windows 7 x86 6.1
2011-08-05 09:47:53,816 INFO [MediaServer] File encoding: windows-1252
2011-08-05 09:47:53,816 INFO [MediaServer] ------------------------------------------------------------------------
2011-08-05 09:47:53,988 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2011-08-05 09:47:54,066 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-08-05 09:47:56,921 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-08-05 09:47:57,654 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-08-05 09:47:57,857 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-08-05 09:47:57,950 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-08-05 09:47:58,028 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-08-05 09:47:58,138 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-08-05 09:47:58,216 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-08-05 09:47:58,372 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-08-05 09:47:58,418 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-08-05 09:47:58,715 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-08-05 09:47:59,136 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-08-05 09:47:59,245 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-08-05 09:47:59,339 INFO [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-08-05 09:47:59,510 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-08-05 09:47:59,526 INFO [WebServer] Socket buffer set to 65535 bytes
2011-08-05 09:47:59,573 INFO [WebServer] WebServer starting on port 8895
2011-08-05 09:47:59,916 INFO [Device] Created UPnP Device with UUID: ee0616d5-435a-38f5-b546-b92dd884093e, bound address: 192.168.1.113
2011-08-05 09:47:59,947 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-08-05 09:47:59,947 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-08-05 09:47:59,963 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-08-05 09:47:59,963 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-08-05 09:47:59,963 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-08-05 09:47:59,963 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-08-05 09:47:59,963 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1312562879963, LastAccessTime = 1312562879963, getTimeToLiveSeconds() = -1, createTime = 1312562879963 ]
2011-08-05 09:47:59,963 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-08-05 09:47:59,978 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-08-05 09:47:59,978 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-08-05 09:47:59,978 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-08-05 09:47:59,978 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-08-05 09:47:59,978 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-08-05 09:47:59,978 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-08-05 09:47:59,978 INFO [CompositeCacheConfigurator] Finished configuration in 15 ms.
2011-08-05 09:47:59,994 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-08-05 09:47:59,994 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-08-05 09:47:59,994 INFO [EventDispatcher] Starting EventDispatcher
2011-08-05 09:47:59,994 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-08-05 09:47:59,994 INFO [RendererSearchSender] Searching for Renderer devices
2011-08-05 09:48:00,059 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Broadcom NetXtreme 57xx Gigabit Controller) and address 192.168.1.113, timeout = 0
2011-08-05 09:48:12,734 INFO [ServiioConsole] Starting Serviio Console
2011-08-05 09:48:14,029 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-08-05 09:48:18,116 INFO [Messages] Loaded console message bundle for locale: en
2011-08-05 09:48:19,563 INFO [Messages] Loaded console message bundle for locale: en
2011-08-05 09:48:19,701 INFO [UpdateChecker] Checking if a new version is available
2011-08-05 09:48:26,648 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-08-05 09:48:26,650 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-08-05 09:48:28,462 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-08-05 09:48:29,514 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-08-05 09:50:01,544 INFO [LibraryUpdatesCheckerThread] Updated 'Love And Other Drugs {2010}' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Love And Other Drugs {2010}.mp4) in Library
2011-08-05 09:50:38,905 INFO [LibraryUpdatesCheckerThread] Updated 'Narnia The Voyage of the Dawn Treader {2010} by Mr. KickASS' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Narnia The Voyage of the Dawn Treader {2010} by Mr. KickASS.mp4) in Library
2011-08-05 09:50:43,143 INFO [LibraryUpdatesCheckerThread] Updated 'Red 2010 English 480p BRRip' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Red 2010 English 480p BRRip.avi) in Library
2011-08-05 09:50:46,387 INFO [LibraryUpdatesCheckerThread] Updated 'The American [2010]' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\The American [2010].avi) in Library
2011-08-05 09:51:04,269 INFO [LibraryUpdatesCheckerThread] Updated '13 Assassins {2010} Limited - Kickassddl.blogspot.com' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\13 Assassins {2010} Limited - Kickassddl.blogspot.com.mp4) in Library
2011-08-05 09:52:49,481 INFO [LibraryUpdatesCheckerThread] Updated '28 Days Later' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\28 Days Later.m2ts) in Library
2011-08-05 09:52:50,209 WARN [VideoExtractionStrategy] Couldn't resolve H264 profile/level for file 'Andre Berto vs Victor Ortiz - 720p.M2TS' because Sequence parameter set header was not recognized
2011-08-05 09:54:17,888 INFO [LibraryUpdatesCheckerThread] Updated 'Andre Berto vs Victor Ortiz - 720p' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Andre Berto vs Victor Ortiz - 720p.M2TS) in Library
2011-08-05 09:54:27,225 INFO [LibraryUpdatesCheckerThread] Updated 'Boxing.Cotto.vs.Margarito.HDTV.Xvid.CHILLIN' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Boxing.Cotto.vs.Margarito.HDTV.Xvid.CHILLIN.avi) in Library
2011-08-05 09:54:31,904 INFO [LibraryUpdatesCheckerThread] Updated 'For.get me.not.dvdrip.xvid-n3HAL' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\For.get me.not.dvdrip.xvid-n3HAL.avi) in Library
2011-08-05 09:55:06,010 INFO [LibraryUpdatesCheckerThread] Updated 'Gnomeo and Juliet {2011} - Mr. KickASS' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Gnomeo and Juliet {2011} - Mr. KickASS.mp4) in Library
2011-08-05 09:55:35,010 INFO [LibraryUpdatesCheckerThread] Updated 'Harry Potter and the Deathly Hallows Part 1 - Mr. KickASS' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Harry Potter and the Deathly Hallows Part 1 - Mr. KickASS.mp4) in Library
2011-08-05 09:56:50,426 INFO [LibraryUpdatesCheckerThread] Updated 'HBO Fernando Montiel vs. Nonito Donaire x264.720p.60fps.MAGICPOTATOES' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\HBO Fernando Montiel vs. Nonito Donaire x264.720p.60fps.MAGICPOTATOES.mkv) in Library
2011-08-05 09:58:14,591 INFO [LibraryUpdatesCheckerThread] Updated 'HBO Paul Williams vs Sergio Martinez II x264.720p.60fps MAGICPOTATOES' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\HBO Paul Williams vs Sergio Martinez II x264.720p.60fps MAGICPOTATOES.mkv) in Library
2011-08-05 09:59:52,313 INFO [LibraryUpdatesCheckerThread] Updated 'HBO PPV Manny Pacquiao vs. Antonio Mararito x264.720p.60fps MAGICPOTATOES' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\HBO PPV Manny Pacquiao vs. Antonio Mararito x264.720p.60fps MAGICPOTATOES.mkv) in Library
2011-08-05 10:00:24,503 INFO [LibraryUpdatesCheckerThread] Updated 'I Am Number Four {2011} - Mr. KickASS' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\I Am Number Four {2011} - Mr. KickASS.mp4) in Library
2011-08-05 10:00:31,940 INFO [LibraryUpdatesCheckerThread] Updated 'HBO.Boxing.Ricky.Hitman.Hatton.vs.Floyd.Money.Mayweather.[Lloyd]' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\HBO.Boxing.Ricky.Hitman.Hatton.vs.Floyd.Money.Mayweather.[Lloyd].avi) in Library
2011-08-05 10:01:50,341 INFO [LibraryUpdatesCheckerThread] Updated 'HBO.PPV.Mayweather.VS.Mosley.x264.720p.60fps.MAGICPOTATOES' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\HBO.PPV.Mayweather.VS.Mosley.x264.720p.60fps.MAGICPOTATOES.mkv) in Library
2011-08-05 10:02:25,322 INFO [LibraryUpdatesCheckerThread] Updated 'Iron.Man.2.2010.720p.BRRiP.x264.AAC(5.1).mkv-Zen_Bud' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Iron.Man.2.2010.720p.BRRiP.x264.AAC(5.1).mkv-Zen_Bud.mkv) in Library
2011-08-05 10:03:00,355 INFO [LibraryUpdatesCheckerThread] Updated 'Jackass 3.5 {2011} - Kickassddl.blogspot.com' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Jackass 3.5 {2011} - Kickassddl.blogspot.com.mp4) in Library
2011-08-05 10:03:45,276 INFO [LibraryUpdatesCheckerThread] Updated 'Jonah Hex 2010 720p BRrip[Dual-Audio][Eng-Hindi]~BONIIN' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Jonah Hex 2010 720p BRrip[Dual-Audio][Eng-Hindi]~BONIIN.mkv) in Library
2011-08-05 10:04:23,098 INFO [LibraryUpdatesCheckerThread] Updated 'Knight And Day' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Knight And Day.mp4) in Library
2011-08-05 10:04:26,907 INFO [LibraryUpdatesCheckerThread] Updated 'MJF3zOYr_Manny Pacquiao vs Juan Manuel Marquez I' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\MJF3zOYr_Manny Pacquiao vs Juan Manuel Marquez I.avi) in Library
2011-08-05 10:05:14,367 INFO [LibraryUpdatesCheckerThread] Updated 'Pacquiao vs. Mosley 720p 30fps' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Pacquiao vs. Mosley 720p 30fps.mkv) in Library
2011-08-05 10:05:37,898 INFO [LibraryUpdatesCheckerThread] Updated 'Rango {2011} - Kickassddl.blogspot.com' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Rango {2011} - Kickassddl.blogspot.com.mp4) in Library
2011-08-05 10:05:44,927 INFO [LibraryUpdatesCheckerThread] Updated 'Russell.Peters.Red.White.And.Brown.2008' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Russell.Peters.Red.White.And.Brown.2008.avi) in Library
2011-08-05 10:06:14,841 INFO [LibraryUpdatesCheckerThread] Updated 'Shrek.Forever.After.2010.720p.BRRiP.x264.AAC(5.1).ENG.SWE_SUB.mkv-Zen_Bud' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Shrek.Forever.After.2010.720p.BRRiP.x264.AAC(5.1).ENG.SWE_SUB.mkv-Zen_Bud.mkv) in Library
2011-08-05 10:06:20,448 INFO [LibraryUpdatesCheckerThread] Updated 'SMTF-russell-part2' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\SMTF-russell-part2.avi) in Library
2011-08-05 10:06:53,624 INFO [LibraryUpdatesCheckerThread] Updated 'The Dilemma {2011} 720p BRRip x264 - Mr. KickASS' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\The Dilemma {2011} 720p BRRip x264 - Mr. KickASS.mp4) in Library
2011-08-05 10:07:32,620 INFO [LibraryUpdatesCheckerThread] Updated 'The Hangover {2009} - Mr. KickASS' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\The Hangover {2009} - Mr. KickASS.mp4) in Library
2011-08-05 10:08:23,056 INFO [LibraryUpdatesCheckerThread] Updated 'The Joneses (HD)' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\The Joneses (HD).m4v) in Library
2011-08-05 10:08:29,451 INFO [LibraryUpdatesCheckerThread] Updated 'The.Switch[2010]DvDrip-aXXo' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\The.Switch[2010]DvDrip-aXXo.avi) in Library
2011-08-05 10:09:01,480 INFO [LibraryUpdatesCheckerThread] Updated 'Transformers {2007} - Mr. KickASS' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Transformers {2007} - Mr. KickASS.mp4) in Library
2011-08-05 10:09:41,515 INFO [LibraryUpdatesCheckerThread] Updated 'Transformers 2 {2009} - Mr. KickASS' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Transformers 2 {2009} - Mr. KickASS.mp4) in Library
2011-08-05 10:10:20,645 INFO [LibraryUpdatesCheckerThread] Updated 'Unstoppable 2010 720p BRRip x264 5.1 AAC-GokU61[HDScene-Release]' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Unstoppable 2010 720p BRRip x264 5.1 AAC-GokU61[HDScene-Release].mp4) in Library
2011-08-05 10:11:33,506 INFO [LibraryUpdatesCheckerThread] Updated 'Winters Bone' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Winters Bone.mp4) in Library
2011-08-05 10:11:40,318 INFO [LibraryUpdatesCheckerThread] Updated 'The.Conspirator.2010.DVDRip.XviD' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\The.Conspirator.2010.DVDRip.XviD.avi) in Library
2011-08-05 10:11:48,823 INFO [LibraryUpdatesCheckerThread] Updated 'Bad.Teacher.2011.R5.LiNE.XviD-ViP3R' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Bad.Teacher.2011.R5.LiNE.XviD-ViP3R.avi) in Library
2011-08-05 10:11:55,727 INFO [LibraryUpdatesCheckerThread] Updated 'Largo.Winch.2.The.Burma.Conspiracy.2011.BRRip.XviD-ViP3R' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Largo.Winch.2.The.Burma.Conspiracy.2011.BRRip.XviD-ViP3R.avi) in Library
2011-08-05 10:12:02,632 INFO [LibraryUpdatesCheckerThread] Updated 'sprinter-turbulentskies2010' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\sprinter-turbulentskies2010.avi) in Library
2011-08-05 10:12:35,314 INFO [LibraryUpdatesCheckerThread] Updated 'Sanctum' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Sanctum.mkv) in Library
2011-08-05 10:13:03,894 INFO [LibraryUpdatesCheckerThread] Updated 'The Fighter {2010} by Mr. KickASS' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\The Fighter {2010} by Mr. KickASS.mp4) in Library
2011-08-05 10:13:33,508 INFO [LibraryUpdatesCheckerThread] Updated 'Ironclad {2011} - Kickassddl.blogspot.com' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Ironclad {2011} 720p BRRip x264 - Kickassddl\Ironclad {2011} - Kickassddl.blogspot.com.mp4) in Library
2011-08-05 10:14:02,631 INFO [LibraryUpdatesCheckerThread] Updated 'Rio {2011} - Kickassddl.blogspot.com' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Rio {2011} 720p BRRip x264 - Kickassddl\Rio {2011} - Kickassddl.blogspot.com.mp4) in Library
2011-08-05 10:14:38,257 INFO [LibraryUpdatesCheckerThread] Updated 'Chocolat {2000}' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Chocolat {2000} 720p BRRip x264 - HDMiCRO by Mr. KickASS\Chocolat {2000}.mp4) in Library
2011-08-05 10:15:06,751 INFO [LibraryUpdatesCheckerThread] Updated 'Hobo with a Shotgun {2011} Limited - Kickassddl.blogspot.com' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Hobo with a Shotgun {2011} Limited - Kickassddl\Hobo with a Shotgun {2011} Limited - Kickassddl.blogspot.com.mp4) in Library
2011-08-05 10:15:32,845 INFO [LibraryUpdatesCheckerThread] Updated '13 {2010} - Mr. KickASS' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\13 {2010} 720p BRRip x264 - Mr. KickASS\13 {2010} - Mr. KickASS.mp4) in Library
2011-08-05 10:15:49,726 INFO [LibraryUpdatesCheckerThread] Updated 'Wicker Park' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Wicker Park 2004 H264 DVDRip AAC-SecretMyth\Wicker Park.mp4) in Library
2011-08-05 10:16:15,551 INFO [LibraryUpdatesCheckerThread] Updated 'Unknown {2011} - Mr. KickASS' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Unknown {2011} 720p BRRip x264 - Mr. KickASS\Unknown {2011} - Mr. KickASS.mp4) in Library
2011-08-05 10:16:44,794 INFO [LibraryUpdatesCheckerThread] Updated 'Battle Los Angeles {2011} - Mr. KickASS' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Battle Los Angeles {2011} - Mr. KickASS\Battle Los Angeles {2011} - Mr. KickASS.mp4) in Library
2011-08-05 10:17:07,653 INFO [LibraryUpdatesCheckerThread] Updated 'Black Swan {2010} by Mr. KickASS' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Black Swan {2010} 720p BRRip x264 - HDMiCRO by Mr. KickASS\Black Swan {2010} by Mr. KickASS.mp4) in Library
2011-08-05 10:17:37,335 INFO [LibraryUpdatesCheckerThread] Updated 'Burlesque {2010} by Mr. KickASS' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Burlesque {2010} 720p BRRip x264 - HDMiCRO by Mr. KickASS\Burlesque {2010} by Mr. KickASS.mp4) in Library
2011-08-05 10:17:42,040 INFO [LibraryUpdatesCheckerThread] Updated 'Casino Jack [2010] DvDRiP XviD - ExtraTorrentRG' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Casino Jack [2010] DvDRiP XviD - ExtraTorrentRG\Casino Jack [2010] DvDRiP XviD - ExtraTorrentRG.avi) in Library
2011-08-05 10:18:09,570 INFO [LibraryUpdatesCheckerThread] Updated 'Charlie.St.Cloud.2010.BRRiP.720p.x264~PlutO~' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Charlie.St.Cloud.2010.BRRiP.720p.x264~PlutO~\Charlie.St.Cloud.2010.BRRiP.720p.x264~PlutO~.mp4) in Library
2011-08-05 10:18:41,182 INFO [LibraryUpdatesCheckerThread] Updated 'Drive.Angry.2011.5_1.BRRiP.720p.x264~PlutO~' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Drive.Angry.2011.5_1.BRRiP.720p.x264~PlutO~\Drive.Angry.2011.5_1.BRRiP.720p.x264~PlutO~.mp4) in Library
2011-08-05 10:19:06,540 INFO [LibraryUpdatesCheckerThread] Updated 'Fair Game {2010} by Mr. KickASS' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Fair Game {2010} Limited 720p BRRip x264 - Mr. KickASS\Fair Game {2010} by Mr. KickASS.mp4) in Library
2011-08-05 10:19:14,911 INFO [LibraryUpdatesCheckerThread] Updated 'Gulliver's.Travels.2010.DVDRiP.x264~PlutO~' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Gulliver's.Travels.2010.DVDRiP.x264~PlutO~\Gulliver's.Travels.2010.DVDRiP.x264~PlutO~.mp4) in Library
2011-08-05 10:19:40,798 INFO [LibraryUpdatesCheckerThread] Updated 'Hall Pass {2011} - Mr. KickASS' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Hall Pass {2011} 720p BRRip x264 - Mr. KickASS\Hall Pass {2011} - Mr. KickASS.mp4) in Library
2011-08-05 10:20:08,405 INFO [LibraryUpdatesCheckerThread] Updated 'Inception {2010}' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Inception {2010} 720p BRRip x264 - HDMiCRO by Mr. KickASS\Inception {2010}.mp4) in Library
2011-08-05 10:20:48,993 INFO [LibraryUpdatesCheckerThread] Updated 'Kill The Irishman {2011} 720p BRRip x264 - Mr. KickASS' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Kill The Irishman {2011} 720p BRRip x264 - Mr. KickASS\Kill The Irishman {2011} 720p BRRip x264 - Mr. KickASS.mp4) in Library
2011-08-05 10:21:24,015 INFO [LibraryUpdatesCheckerThread] Updated 'London Boulevard {2010} by Mr. KickASS' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\London Boulevard {2010} 720p BRRip x264 - Mr. KickASS\London Boulevard {2010} by Mr. KickASS.mp4) in Library
2011-08-05 10:21:50,229 INFO [LibraryUpdatesCheckerThread] Updated 'Megamind {2010} by Mr. KickASS' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Megamind {2010} 720p BRRip x264 - HDMiCRO by Mr. KickASS\Megamind {2010} by Mr. KickASS.mp4) in Library
2011-08-05 10:22:07,254 INFO [LibraryUpdatesCheckerThread] Updated 'Monsters {2010} by Mr. KickASS' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Monsters {2010} Limited 720p BRRip x264 - HDMiCRO by Mr. KickASS\Monsters {2010} by Mr. KickASS.mp4) in Library
2011-08-05 10:22:33,312 INFO [LibraryUpdatesCheckerThread] Updated 'No Strings Attached {2011} - Mr. KickASS' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\No Strings Attached {2011} 720p BRRip x264 - Mr. KickASS\No Strings Attached {2011} - Mr. KickASS.mp4) in Library
2011-08-05 10:23:01,640 INFO [LibraryUpdatesCheckerThread] Updated 'Sucker Punch {2011} Extended Cut - Kickassddl.blogspot.com' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Sucker Punch {2011} Extended Cut 720p BRRip x264 - Kickassddl\Sucker Punch {2011} Extended Cut - Kickassddl.blogspot.com.mp4) in Library
2011-08-05 10:23:37,374 INFO [LibraryUpdatesCheckerThread] Updated 'Tangled {2010} by Mr. KickASS' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Tangled {2010} 720p BRRip x264 - HDMiCRO by Mr. KickASS\Tangled {2010} by Mr. KickASS.mp4) in Library
2011-08-05 10:24:01,526 INFO [LibraryUpdatesCheckerThread] Updated 'The Green Hornet {2011} - Mr.KickASS' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\The Green Hornet {2011} 720p BRRip x264 - Mr. KickASS\The Green Hornet {2011} - Mr.KickASS.mp4) in Library
2011-08-05 10:24:28,035 INFO [LibraryUpdatesCheckerThread] Updated 'The Kings Speech {2010} by Mr. KickASS' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\The Kings Speech {2010} 720p BRRip x264 - Mr. KickASS\The Kings Speech {2010} by Mr. KickASS.mp4) in Library
2011-08-05 10:24:54,293 INFO [LibraryUpdatesCheckerThread] Updated 'The Lincoln Lawyer {2011} - Kickassddl.blogspot.com' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\The Lincoln Lawyer {2011} 720p BRRip x264 - Kickassddl.blogspot.com\The Lincoln Lawyer {2011} - Kickassddl.blogspot.com.mp4) in Library
2011-08-05 10:25:35,377 INFO [LibraryUpdatesCheckerThread] Updated 'The Mechanic {2011} - Mr. KickASS' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\The Mechanic {2011} 720p BRRip x264 - Mr. KickASS\The Mechanic {2011} - Mr. KickASS.mp4) in Library
2011-08-05 10:25:41,606 INFO [LibraryUpdatesCheckerThread] Updated 'The Next Three Days' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\The Next Three Days (2010) DVDRip XviD By MegaPlay\The Next Three Days.avi) in Library
2011-08-05 10:25:43,219 INFO [LibraryUpdatesCheckerThread] Updated 'The Next Three Days Sample' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\The Next Three Days (2010) DVDRip XviD By MegaPlay\SAMPLE\The Next Three Days Sample.avi) in Library
2011-08-05 10:26:08,994 INFO [LibraryUpdatesCheckerThread] Updated 'The Resident (2011) by Mr. KickASS' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\The Resident {2011} 720p BRRip x264 - HDMiCRO by Mr. KickASS\The Resident (2011) by Mr. KickASS.mp4) in Library
2011-08-05 10:26:47,030 INFO [LibraryUpdatesCheckerThread] Updated 'The Rite {2011} - Mr. KickASS' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\The Rite {2011} 720p BRRip x264 - Mr. KickASS\The Rite {2011} - Mr. KickASS.mp4) in Library
2011-08-05 10:27:13,512 INFO [LibraryUpdatesCheckerThread] Updated 'The Social Network {2010}' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\The Social Network {2010} 720p BRRip x264 - HDMiCRO by Mr. KickASS\The Social Network {2010}.mp4) in Library
2011-08-05 10:27:33,448 INFO [LibraryUpdatesCheckerThread] Updated 'The Way Back {2010} - Mr. KickASS' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\The Way Back {2010} 720p BRRip x264 - Mr. KickASS\The Way Back {2010} - Mr. KickASS.mp4) in Library
2011-08-05 10:27:37,814 INFO [LibraryUpdatesCheckerThread] Updated 'Sample' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\The.Adjustment.Bureau.2011.5_1.BRRiP.720p.x264~PlutO~\Sample.mp4) in Library
2011-08-05 10:28:06,497 INFO [LibraryUpdatesCheckerThread] Updated 'The.Adjustment.Bureau.2011.5_1.BRRiP.720p.x264~PlutO~' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\The.Adjustment.Bureau.2011.5_1.BRRiP.720p.x264~PlutO~\The.Adjustment.Bureau.2011.5_1.BRRiP.720p.x264~PlutO~.mp4) in Library
2011-08-05 10:28:30,422 INFO [LibraryUpdatesCheckerThread] Updated 'The.Roommate.2011.BRRiP.5_1.720p.x264~PlutO~' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\The.Roommate.2011.BRRiP.5_1.720p.x264~PlutO~\The.Roommate.2011.BRRiP.5_1.720p.x264~PlutO~.mp4) in Library
2011-08-05 10:28:51,088 INFO [LibraryUpdatesCheckerThread] Updated 'The.Town.Extended.2010.BRRiP.720p.x264~PlutO~1_Output-muxed' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\The.Town.Extended.2010.BRRiP.720p.x264~PlutO~\The.Town.Extended.2010.BRRiP.720p.x264~PlutO~1_Output-muxed.mp4) in Library
2011-08-05 10:29:27,408 INFO [LibraryUpdatesCheckerThread] Updated 'Arthur {2011} - Kickassddl.blogspot.com' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Arthur {2011} 720p BRRip x264 - Kickassddl\Arthur {2011} - Kickassddl.blogspot.com.mp4) in Library
2011-08-05 10:29:32,738 INFO [LibraryUpdatesCheckerThread] Updated 'nedivx-chloe' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Chloe.LIMITED.DVDRip.XviD-NeDiVx\nedivx-chloe.avi) in Library
2011-08-05 10:29:56,720 INFO [LibraryUpdatesCheckerThread] Updated 'Henrys Crime {2010} - kickassddl.blogspot.com' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Henrys Crime {2010} 720p BRRip x264 - Kickassddl\Henrys Crime {2010} - kickassddl.blogspot.com.mp4) in Library
2011-08-05 10:30:29,333 INFO [LibraryUpdatesCheckerThread] Updated 'How Do You Know {2010} - Mr. KickASS' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\How Do You Know {2010} 720p BRRip x264 - Mr. KickASS\How Do You Know {2010} - Mr. KickASS.mp4) in Library
2011-08-05 10:30:57,330 INFO [LibraryUpdatesCheckerThread] Updated 'Limitless {2011} Unrated - Kickassddl.blogspot.com' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Limitless {2011} Unrated 720p BRRip x264 - Kickassddl\Limitless {2011} Unrated - Kickassddl.blogspot.com.mp4) in Library
2011-08-05 10:30:58,642 INFO [LibraryUpdatesCheckerThread] Updated 'sample' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Source Code (2011) DVDRip XviD-MAXSPEED\sample.avi) in Library
2011-08-05 10:31:05,214 INFO [LibraryUpdatesCheckerThread] Updated 'Source Code (2011) DVDRip XviD-MAXSPEED www.torentz.3xforum.ro' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Source Code (2011) DVDRip XviD-MAXSPEED\Source Code (2011) DVDRip XviD-MAXSPEED www.torentz.3xforum.ro.avi) in Library
2011-08-05 10:31:36,266 INFO [LibraryUpdatesCheckerThread] Updated 'The Company Men {2010} - Mr KickASS' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\The Company Men {2010} 720p BRRip x264 - Mr. KickASS\The Company Men {2010} - Mr KickASS.mp4) in Library
2011-08-05 10:31:59,006 INFO [LibraryUpdatesCheckerThread] Updated 'The Eagle {2011} - Kickassddl.blogspot.com' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\The Eagle {2011} 720p BRRip x264 - Kickassddl\The Eagle {2011} - Kickassddl.blogspot.com.mp4) in Library
2011-08-05 10:32:20,856 INFO [LibraryUpdatesCheckerThread] Updated 'True Grit {2010} - Mr KickASS' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\True Grit {2010} 720p BRRip x264 - Mr. KickASS\True Grit {2010} - Mr KickASS.mp4) in Library
2011-08-05 10:32:48,768 INFO [LibraryUpdatesCheckerThread] Updated 'Trust {2010} Limited - Kickassddl.blogspot.com' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Trust {2010} Limited 720p BRRip x264 - Kickassddl\Trust {2010} Limited - Kickassddl.blogspot.com.mp4) in Library
2011-08-05 10:33:09,326 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-08-05 10:33:09,525 INFO [WebServer] WebServer shutting down
2011-08-05 10:33:09,525 INFO [EventDispatcher] Leaving EventDispatcher
2011-08-05 10:33:09,526 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2011-08-05 10:33:09,526 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2011-08-05 10:33:10,167 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2011-08-05 10:33:10,167 INFO [DatabaseManager] Shutting down database
2011-08-05 10:33:10,542 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2011-08-05 10:33:13,755 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-08-05 10:34:22,699 INFO [MediaServer] ------------------------------------------------------------------------
2011-08-05 10:34:22,715 INFO [MediaServer] Serviio DLNA media streaming server v 0.5.2 (rev. 4e3210bd9ff3)
2011-08-05 10:34:22,715 INFO [MediaServer] Petr Nejedly 2009-2011
2011-08-05 10:34:22,715 INFO [MediaServer] http://www.serviio.org
2011-08-05 10:34:22,715 INFO [MediaServer] Java 1.6.0_26-Sun Microsystems Inc.
2011-08-05 10:34:22,715 INFO [MediaServer] OS Windows 7 x86 6.1
2011-08-05 10:34:22,715 INFO [MediaServer] File encoding: windows-1252
2011-08-05 10:34:22,715 INFO [MediaServer] ------------------------------------------------------------------------
2011-08-05 10:34:22,965 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2011-08-05 10:34:23,074 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-08-05 10:34:28,393 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-08-05 10:34:29,033 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-08-05 10:34:29,298 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-08-05 10:34:29,454 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-08-05 10:34:29,563 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-08-05 10:34:29,782 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-08-05 10:34:29,907 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-08-05 10:34:30,219 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-08-05 10:34:30,297 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-08-05 10:34:30,796 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-08-05 10:34:31,513 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-08-05 10:34:31,669 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-08-05 10:34:31,888 INFO [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-08-05 10:34:32,527 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-08-05 10:34:32,574 INFO [WebServer] Socket buffer set to 65535 bytes
2011-08-05 10:34:33,089 INFO [WebServer] WebServer starting on port 8895
2011-08-05 10:34:34,138 INFO [Device] Created UPnP Device with UUID: ee0616d5-435a-38f5-b546-b92dd884093e, bound address: 192.168.1.113
2011-08-05 10:34:34,289 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-08-05 10:34:34,302 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-08-05 10:34:34,308 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-08-05 10:34:34,309 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-08-05 10:34:34,312 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-08-05 10:34:34,312 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-08-05 10:34:34,312 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1312565674312, LastAccessTime = 1312565674312, getTimeToLiveSeconds() = -1, createTime = 1312565674312 ]
2011-08-05 10:34:34,316 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-08-05 10:34:34,348 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-08-05 10:34:34,348 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-08-05 10:34:34,349 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-08-05 10:34:34,349 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-08-05 10:34:34,349 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-08-05 10:34:34,349 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-08-05 10:34:34,349 INFO [CompositeCacheConfigurator] Finished configuration in 43 ms.
2011-08-05 10:34:34,354 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-08-05 10:34:34,360 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-08-05 10:34:34,365 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-08-05 10:34:34,367 INFO [RendererSearchSender] Searching for Renderer devices
2011-08-05 10:34:34,367 INFO [EventDispatcher] Starting EventDispatcher
2011-08-05 10:34:34,819 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Broadcom NetXtreme 57xx Gigabit Controller) and address 192.168.1.113, timeout = 0
2011-08-05 10:34:40,890 INFO [ServiioConsole] Starting Serviio Console
2011-08-05 10:34:42,528 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-08-05 10:34:45,226 INFO [Messages] Loaded console message bundle for locale: en
2011-08-05 10:34:47,353 INFO [Messages] Loaded console message bundle for locale: en
2011-08-05 10:34:47,570 INFO [UpdateChecker] Checking if a new version is available
2011-08-05 10:34:48,040 INFO [ServiioConsole] Leaving Serviio Console
2011-08-05 10:34:57,208 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-08-05 10:34:57,838 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-08-05 10:35:06,180 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-08-05 10:35:06,182 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-08-05 10:35:55,344 INFO [LibraryUpdatesCheckerThread] Updated 'Little Fockers {2010} - Mr. KickASS' (\\LS-CHL1FF\VIDEOS\PIRATEBAY\Little Fockers {2010} - Mr. KickASS.mp4) in Library
2011-08-05 14:25:37,578 DEBUG [ServiioConsole] Initializing Serviio Console
2011-08-05 14:25:37,625 DEBUG [ApplicationInstanceManager] Port is already taken. Notifying first instance.
2011-08-05 14:25:37,625 DEBUG [ApplicationInstanceManager] Successfully notified first instance.
2011-08-05 14:25:37,625 INFO [ServiioConsole] Leaving Serviio Console
Thanks for helping and sorting this out . . .
